PeterAllday
Reged: 03/24/06
Slightly different image drift problem. new
      #3390697 - 10/15/09 07:19 AM
I have an image drift problem, if anyone can help that would be great. I am also autoguiding, and the stars in the bottom corner are nice and round, whereas the ones in the top left have trails.
Example here
http://picasaweb.google.co.uk/lh/photo/Z27R3OfEjuEtr6tiysLogw?feat=directlink
I believe that the mount is pretty level, and as well polar aligned as I can get it.
Does anyone have any thoughts as to what is causing it?
Peter
Jerry Lodriguss
Vendor
Reged: 07/19/08
Loc: Voorhees, NJ
Re: Slightly different image drift problem. new [Re: PeterAllday]
      #3390708 - 10/15/09 07:32 AM
Hi Peter,
This is almost certainly from field rotation because the mount was not polar aligned accurately enough.
What mount is it? Have you tried taking the time to drift align it and then checking that against the polar alignment scope?
Jerry
A Beginner's Guide to DSLR Astrophotography
http://www.astropix.com
PeterAllday
Reged: 03/24/06
Re: Slightly different image drift problem. new [Re: Jerry Lodriguss]
      #3390741 - 10/15/09 08:04 AM
It is an EQ6 mount. I have tried drift aligning it once, but with not a great deal of success. I guess that it is time I tried again.
Peter
Jerry Lodriguss
Vendor
Reged: 07/19/08
Loc: Voorhees, NJ
      #3390782 - 10/15/09 09:04 AM
Hi Peter,
You should take the time to accurately polar align the mount with the drift method at least one time, to check the accuracy of the Polar Alignment scope.
You should also make sure that the reticle is correctly centered in the polar alignment scope.
I have a page on drift alignment here:
http://www.astropix.com/HTML/I_ASTROP/TRACKED/POLAR.HTM
It will initially seem much more complicated than it really is in practice. It is a little bit time consuming. But it is something you can do in your driveway on a night when the moon is up.
Jerry
PeterAllday
Reged: 03/24/06
      #3393052 - 10/16/09 01:56 PM
Thanks Jerry,
I will give this a go tonight assuming that it stays clear.
Peter
dgpilot
Reged: 09/25/09
Loc: San Ramon, California
      #3393387 - 10/16/09 05:11 PM
Also, I've heard that having the guidescope pointed too far away from the imaging scope's target, it can produce the same results.
LXD75 8" SN f/4
Canon 50D, 350D (unmodded)
Orion ST80 Guidescope
Meade DSI II Pro
My Astro Gallery
PeterAllday
Reged: 03/24/06
Re: Slightly different image drift problem. [Re: dgpilot]
      #3394559 - 10/17/09 12:53 PM
Well, it wasn't clear, so I haven't tied the drift alignment. I think that the guidescope is fairly well aligned, at least from looking at it, I haven't tested it.
The other change that I made recently was trying to get rid of cone error, which was noticable when going from one half of the sky to the other. This is now greatly improved, but this new problem has only arisen since then.
Peter
3 registered and 0 anonymous users are browsing this forum.
