KingBolete
Reged: 09/13/07
Loc: Alamosa, CO
CG-5GT Polar Scope Hole Blocked new
      #3394700 - 10/17/09 02:21 PM Attachment (17 downloads)
I just unpacked a new CG-5GT mount. I had it all set an pulled the cap off the upper end of the polar scope hole. I expected to find a hole but instead found a big bracket. My first guess is that something was mounted 90 degrees off of where it's supposed to be. Is there a quick way to fix this?
Here's two shots
-- Jim
Celestron C4R 4" achromatic refractor (1000mm f/10)
Zhumell 10" Dob (1250mm f/4.9)
Chris Erickson
Reged: 05/08/06
Loc: Waikoloa Village, Hawaii
Re: CG-5GT Polar Scope Hole Blocked new [Re: KingBolete]
      #3394715 - 10/17/09 02:31 PM
Rotate the DEC axis and a hole in that bracket will rotate into view.
"My Advice is always free and worth every penny!"
-Christopher Erickson
Network Design Engineer
Waikoloa Village, HI 96738
N19°57' W155°47'
Meade 16" LX200 SCT
www.data-plumber.com
Gary
Reged: 06/12/05
Loc: Southeast, Ga
      #3394717 - 10/17/09 02:32 PM
It's suppose to be that way. Just turn the dec until you see a hole, after loosening the clutch.
CS
garylr
drksky
Reged: 09/01/09
Re: CG-5GT Polar Scope Hole Blocked new [Re: Gary]
      #3394847 - 10/17/09 03:55 PM
When polar aligning the mount, the main scope in the saddle needs to be pointed side-to-side. You can't point the scope at polaris and sight through the alignment axis.
Tony C
AT8RC
C6-R
CG-5 ASGT
ST80 w/StarShoot Autoguider
Canon EOS 450D (Stock)
The Drinking Bird
KingBolete
Reged: 09/13/07
Loc: Alamosa, CO
Re: CG-5GT Polar Scope Hole Blocked [Re: Gary]
      #3395275 - 10/17/09 10:02 PM
Thanks. I never noticed that on my cg3 mount.
-- Jim
6 registered and 13 anonymous users are browsing this forum.
