dancam
journeyman
Reged: 10/09/09
Loc: Miwaukee Wisconsin
Looking to buy my first mount.
      #3395626 - 10/18/09 04:05 AM
Deciding between the Meade LXD-75 and Orion Atlas EQ-G any opinions or other recommendations.
adamsp123
Reged: 11/20/08
Loc: welshpool mid wales UK
Re: Looking to buy my first mount. new [Re: dancam]
      #3395670 - 10/18/09 05:51 AM
The Orion Atlas is better, for example the LXD75 cannot realy cope with its own 10" SNT very well at all, the Atlas is easily capable of handling it!
SkyWatcher 120ED PRO, GSO 200mm F4 Astrograph, Meade 10" SNT, WO 72ED & 66ED
Vixen Sphinx and Vixen Atlux with starbook,
QHY5 guider, Modded Canon 1000D, Baader MPCC.
WO Flattener III
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness,' but it doesn't work."
TV is called a "medium" because it is neither rare nor well done.
skybsd
Reged: 02/01/08
      #3395688 - 10/18/09 06:16 AM
Hello Dan,
It might be useful to know your budget, requirements and intended uses for a mount, really.
Having that information will assist others in responding with actual practical advice and suggestions.
skybsd
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: Looking to buy my first mount. new [Re: adamsp123]
      #3395696 - 10/18/09 06:33 AM
The Atlas is bigger, anyway. If the user requires the extra capacity then the LXD75 won't do. If he doesn't require the additional capacity then the LXD75 has advantages (portability, superior controller, etc.). If the poster plans to use it without an external PC the very limited dedicated controller on the Atlas would be a disadvantage. If he needs the additional capacity but wants to use the mount without a PC a CGEM would be a better choice.
John C
Urban Observatory
A&M/Astreya 76mm F/6 APO
TMB/LOMO 80mm F/7.5 APO
Tak FSQ-106N F/5 APO
Meade 178ED F/9 "APO"
Meade ETX-125AT
C14
Teeter 20" F/3.8 truss Newt w/ServoCat
NJP, GPDX/SS2KPC, CG5-GT
ST-10XME, DSI Pro
dancam
journeyman
Reged: 10/09/09
Re: Looking to buy my first mount. new [Re: jrcrilly]
      #3395703 - 10/18/09 06:45 AM
Thanks for the replies so far. I intend to use the mount primarily for AP and visual occasionally. I will currently be using it with my DSLR and lenses but, will eventually be purchasing a scope as well. I am still unsure of the specific scope I will be getting but, it will be a small/medium APO. Most likely a Meade series 5000 127 or Orion EON 120ED.
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
      #3395818 - 10/18/09 09:42 AM
Of your two choices, I would go with the Atlas, particularly with a medium sized refractor. However, the CGEM or Losmandy GM-8 might be a better choice. If you're budget constrained, a CG5-GT could work. With Celestron's polar alignment routine, it becomes a lot easier to get up and running during an imaging session.
For pure DSLR astrophotography with camera lenses under 200-300mm focal length, you might also consider a Vixen GP2 mount with single RA axis drive and polar axis scope. You should be able to image unguided for a minute or two with shorter focal length lenses. That setup is very portable. However, the upgrade path to imaging with a telescope is a little more expensive with that setup.
Patrick
10" f/6 Truss Tube Newtonian
Celestron C6S-GT SCT
AT66ED Refractor
Oberwerk Ultra 15x70 Binocular
475B Geared Tripod & 501HDV Head
Celestron Regal 8x42 Binocular
Canon XSi; Meade DSI;SPC900-NC
Vixen GP2 Photo Guider Mount
My Astronomy Pages
18UCinVA
Reged: 10/24/08
Loc: Virginia
      #3397005 - 10/18/09 08:57 PM
Look at a Losmandy GM8. They are worth three times what they cost. Many good deals on the used market.
Check out Phil Harrington's review in Starware.
Ray
18 UC
Celestron 32, 24, and 20mm Erfle's
dancam
journeyman
Reged: 10/09/09
Re: Looking to buy my first mount. new [Re: 18UCinVA]
      #3397506 - 10/19/09 06:24 AM
Thanks again for the replies. After doing more research and getting some feedback I have eliminated the LXD-75. I am now looking primarily at a CGEM or Atlas. From the reviews I've read, the CGEM sounds like it will suit my needs. However, I still don't fully understand the differences between it and the Atlas. From what I understand, the CGEM is just the latest version of the same mount.
David Pavlich
Reged: 05/18/05
Loc: Mandeville, LA USA 30.22 X 90....
      #3397681 - 10/19/09 09:45 AM
With either of these scopes and with imaging in mind, there is only one choice; the Atlas. The LXD is a good mount, but the combination of weight and the leverage produced by the big refractors, the LXD will be overtaxed.
David
Proud Member; PAS NOLA,
"If we knew what we were doing, it wouldn't be called research..."
A. Einstein
paul11
Reged: 01/30/06
Loc: Essex UK.
Re: Looking to buy my first mount. new [Re: David Pavlich]
      #3398250 - 10/19/09 03:09 PM
Another vote for the Atlas I’ve owned one for about a year now and I can’t fault it and it’s great with the ASCOM.
LX90-10" Canon 350D Toucam 840K Barn-door tracker
8 registered and 9 anonymous users are browsing this forum.
