Privacy Policy |
Please read our Terms
of Service | Signup and
morden8uk
Reged: 03/01/05
Loc: Southampton, England
Been looking this product
http://www.cloudynights.com/item.php?item_id=1767
Which I think is this sold in the UK
http://www.orionoptics.co.uk/MOUNTS/gsomount.html
Is it true you can swap the tripod to a EQ5/CG5 steel legged tripod?.
Thanks Rob
-------------------- Orion Optics [UK] SPX200 8" f6 Newtonian
Celestron ED80 f7 Refractor
EQ5 with DK3 photo drives on a steel leg tripod
* 7mm Antares Ortho *
* 10.5mm Research Grade Ortho
* 12.5mm Smart Astro SPL *
* 20mm Parks Gold *
* 25mm Sterling *
TONGKW
Reged: 01/16/07
The Voyager AltAz mount can be put on the CG-5 tripod (2” stainless steel leg) without any modification. All you need to do is to remove the small peg on top face.
K W TONG
C8+CG-5GT, TSA102+HEQ5 PRO, MK67+Voyager, NexStar 6SE, C5+Mizar K, WO ZS80FD+Kenko NES, Megrez 72FD+Kenko KDS, Mini Borg 50, PST
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Yes, the head of the Voyager mount can be attached to mounts that have the M10 central bolt and can have the index post removed. The index post is 1cm square and about 3cm long and is bolted to the top of the tripod mount so it's usually easily removed.
I and many others use a CG-5 tripod with a Voyager mount. With the heavier tripod it's a very nice combination.
-------------------- Mark
C11, C6, APM/TMB115, and AT80ED - Tandem mount CGE and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - Modded 350D, DSI-P, SPC900, Mallincam
Just because you can doesn't necessarily mean that you should
morden8uk
Reged: 03/01/05
Thats great.. thanks guys
* 20mm Parks Gold *
* 25mm Sterling *
morden8uk
Reged: 03/01/05
I'm looking to bolt a 8" 1200mm focal length newt on there and wanted to make sure it could take it.....
* 20mm Parks Gold *
* 25mm Sterling *
8 registered and 10 anonymous users are browsing this forum.
Moderator: Charlie Hein, lineman_16735
