Telescope Specific Forums >> Meade ETX
edgley
Reged: 01/22/05
Loc: Surbiton, England
Autostar version
      #3396619 - 10/18/09 05:15 PM
Getting a bit confused as to what version I should be running.
I have a 497, and according to this page:
http://www.meade.com/support/auto.html
The latest version is 5BE2, but that has no working link. The version that does is 43EG, which I have already installed, but that is over 2 years old.
Please say there is newer software available than that?
New ETX 125PE owner
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
Re: Autostar version new [Re: edgley]
      #3396804 - 10/18/09 07:02 PM
There are TWO 497 hand controllers now.
The old one, and a newer version.
43Eg is the most recent version for the older controller.
The newer version has 5CE1 and reports itself as 497EP when you first turn it on-- BUT make sure you have the newest release of the Autostar Updater software ver. 5.9 located 1/2 way down this web site page: Read it: MANY BUGS! with the new 497 that the lastest version of the firmware corrects.
This newer software can determine which hand controller is plugged-in and apply the proper update automatically.
LX90 8" LNT, SV Nighthawk & TelePOD, SV 80/9D & M4 mount, ETX 90, Orion XT10i, 20x80 binoculars, SV-BV3s-- www.texasastro.org
"Great minds discuss ideas;Average minds discuss events;Small minds discuss people." Unknown
Edited by Joe Lalumia (10/18/09 07:05 PM)
edgley
Reged: 01/22/05
Re: Autostar version new [Re: Joe Lalumia]
      #3396820 - 10/18/09 07:09 PM
Thats what I thought.
However, on the Meade site, there is this:
07/27/09
#497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.9 AUTOSTAR UPDATER.
No mention that it is for the newer version only, have they just forgotten to add that?
New ETX 125PE owner
Joe Lalumia
Reged: 01/24/07
      #3396841 - 10/18/09 07:22 PM
I believe the one I posted is the newer version???
However just use the new software and it will apply the most up to date version. It's already changed versions 3 or 4 times now since the new controller appeared on the market.
The ORIGINAL firmware version had so many bugs one of which was IT COULD NOT FIND JUPITER!
edgley
Reged: 01/22/05
      #3396855 - 10/18/09 07:28 PM
It is the newer version, but I don't have the PE version of the Autostar, so I cannot use it. Hence my posting of the other version, which looks like it does run on the older Autostar.
New ETX 125PE owner
CharlesStG
Reged: 01/01/06
Loc: Kansas USA
      #3397065 - 10/18/09 09:26 PM
Hi Gents,
I just went through this same issue. I now know I have one of the "old" 497 controllers, simply known as the "497", which came with my new ETX-125AT. The new controller is called the "497EP", but I understand the only easy way to know it is a 497EP is to turn it on when it then briefly displays 497EP. I've read there is a slight physical difference between the two controllers, but quite subtle -- check here to see 497 and 497EP Pics I was able to confirm using the pics that I have a "classic 497" controller -- the female plug receptacles are different on the 497 vs the 497EP.
Bottom line is this: the latest firmware for the old 497 is version 43Eg, period. As this is now an outdated model, Meade may not come out with any more updates for this old controller. The new 497EP controller, which has a faster processor and more memory is getting lots of updates because the bugs are a real problem for the new controller and its latest firmware version is 5CE1.
For either 497 or 497EP controller, here are a couple of quick tips.
First, be sure to use the Meade #505 patch cord for your firmware upgrade and be sure to connect the multi-pin side of this cord to your laptop or desktop PC's RS-232 port and the phone jack end to the SMALLER RJ telephone jack found on the bottom of your 497 (and NOT NOT NOT to one of the two smaller RJ jacks on the base of your telescope - unless you want real trouble).
Then, plug your controller's normal Meade connection cord into the usual larger jack on the base of your 497 and plug the other end into the usual jack on the base of the telescope. Next, be sure you have downloaded and installed Meade's latest autostar updater (ASU) program to your PC or laptop, which at this time is their version 5.9 found here
Meade download page
Next, with either your 497 or 497EP fully connected as described above, turn on your telescope's power which also powers-up your 497. Then, open the Meade autostar updater (ASU) version 5.9 on your PC and press the "Upgrade Autostar Software Now" button, seen on your PC's screen. If you are then also connected to the internet, the ASU program will automatically detect 1) your telescope type, 2) your controller type of either 497 or 497EP and 3) the firmware version presently on your controller and will then select and AUTOMATICALLY install the LATEST firmware version for your particular controller, whether it's a 497 or 497EP.
Notes:
1) The ASU software version 5.9 is NOT firmware for your controller, but software for your PC which really must be used for fairly fool-proof updating of the FIRMWARE on your 497 or 497EP controller.
2) For the 497 controller, firmware 43Eg is the latest and perhaps the last update we will ever see for the old 497.
3) For the 497EP controller (only), firmware 5CE1 is the latest version.
4) Firmware 5BE2 is an outdated version and only for the 497EP -- use the 5.9 ASU and it will install what you need which is the 43Eg for the 497 and 5CE1 for the 497EP.
5) The upgrade of my 497 from firmware version 43Ed to version 43Eg took about 45 minutes -- so don't hurry it up and don't do anything else on your PC other than keep it from going into sleep mode until the update is done.
6) When complete, your controller will reboot automatically and the ASU will tell you it's done on your PC screen.
Enjoy!
Charles
2X Meade/Terabeam ETX-125 variants w/DDII Control
One more Meade ETX-125AT UHTC
Just one APM/TMB 80/480 LZOS Super APO, FT Focuser
Working on 8"f/12 D&G folded bino-refractor
Denk binoviewers until work is done on above
Still working on elevated observatory/spaceship
2 registered and 3 anonymous users are browsing this forum.
Moderator:  Shadowalker, oldsalt
