lawrie
Reged: 01/31/06
Loc: Okanagan Valley
NGC 891 new
      #3393981 - 10/17/09 01:02 AM Attachment (22 downloads)
Here's my NGC 891,
36x360s lights, 29x360s dirks
Registered in DSS
Levels and curves, horizontal banding
np101-40D
Any comments and processing advise please
Clear Skies
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
Nils_Lars
Reged: 01/04/08
Re: NGC 891 new [Re: lawrie]
      #3393987 - 10/17/09 01:06 AM
Love the detail in the dust lane and the colors show well in the galaxy and the stars , couple of other fuzzies in there even
Erik
Orion ED 80
Williams Optics VII reducer
Celestron 8" SCT
Orion Starshoot Autoguider
PHD guide
NexImage webcam
Agnotio
Reged: 08/29/08
Loc: Ottawa, Canada
Re: NGC 891 new [Re: Nils_Lars]
      #3394160 - 10/17/09 07:45 AM
This image has very nice depth, and the color is good too. The only thing I would say by way of constructive criticism is that some of the larger stars look irregular, which may indicate a problem with your guiding for the 6 min subs. Maybe take down the subs to a shorter time or try to determine what is causing the guiding error?
Sky-Watcher Equinox 80ED
EQ6 Pro with EQMOD
Canon 450D
Sky-Watcher 10" f/4.7 Dob
lawrie
Reged: 01/31/06
Re: NGC 891 new [Re: Agnotio]
      #3395022 - 10/17/09 06:49 PM
Your right, I hadn't noticed that.
It seems to be going two ways which leads me to think it was the seeing, but I don't really know.
I just hypertuned the mount, and am waiting for a clear night to run pempro and see what the PEC and backlash are like, hopfully as good as Eric's and David's.
Clear Skies
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
Rankinstudio
Reged: 04/05/08
Loc: Salt Lake City, UT, Lake Powel...
      #3395536 - 10/18/09 01:38 AM
The atlas can be a pain to fine tune. I dont know how many times I have disassembled mine tweaking things out. I have noticed one thing tho. I use PHD to guide, and if you set the calibration ms up to high you will get more errors. I have found I get the best results with my scope (1200mm FL) when I calibrate with 520 - 560 ms steps. Getting the gear meshes tight is important as well (not to tight). I have noticed big improvements by tightening up the motor gear to the idle gear, and the worm to the main gears. I have totally regreased my mount with Super Lube, cleaned it up, and replaced the worm gear bearings with 7 ball ceramic bearings. I plan to replace those with 9 ball ceramic bearings. The altas is a nice mount. I am getting very decent tracking up to 5 minutes with close to 40lbs just in the OTA assembly. (In PHD I also set the min motion really low as well. I think the default is .15, I usually go with .02 or .03)
David Rankin
http://www.rankinstudio.com
Astro Gallery
Orion 254mm F4.7 (imaging scope)
Baader MPCC
Quickcam pro 9000 (guider, imager)
Canon Rebel XSi (self modified)
Atlas EQ-G (EQ MOD)
Canon 50mm F1.8 II Lens
Canon 28-200 F3.2 Lens
DSLR peltier cooler
Edited by Rankinstudio (10/18/09 01:56 AM)
lawrie
Reged: 01/31/06
Re: NGC 891 new [Re: Rankinstudio]
      #3396030 - 10/18/09 11:28 AM
I use a 590mm scope to guide with so mine is a little larger, I was using a new beta version,I may go back to a released version.
It sure sounds terrible when it stalls.
What is the idle gear?
Clear Skies
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
waassaabee
Reged: 11/26/07
Loc: Central California Coast
      #3396522 - 10/18/09 04:01 PM
Image looks great! I've never worked this target, but it just seems a tad red..
Maybe increase the RA aggressiveness?
Gary
34N 120W
-My kingdom for blue squares!-
WO Megrez 90FD/TV 0.8x FR/FF
AT8RC
mini Borg 50/Q-Guide/PHD
CGEM
Canon 350D Hap Griffin Baader mod - o.o
My Friend Flickr
lawrie
Reged: 01/31/06
Re: NGC 891 [Re: waassaabee]
      #3396905 - 10/18/09 07:53 PM
Good idea Gary.
Clear Skies
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
3 registered and 9 anonymous users are browsing this forum.
