Thomas A Davis
Reged: 03/25/05
Decided to give the 2" Lumicon Deep Sky Filter a try I've had laying around. I used a modded Canon XS at ISO1600 using a TMB80/480 at F/4.8 (TeleVue .8X reducer). 5x6m, 4x8m and 1x5m summed. Full frame rotated and reduced.
Nils_Lars
Reged: 01/04/08
Thats a super looking NA nebula , smooth and detailed with tight stars.
Great shot Tom.
-------------------- Erik
Orion ED 80
Williams Optics VII reducer
Celestron 8" SCT
Orion Starshoot Autoguider
PHD guide
NexImage webcam
Skyshooter
Reged: 04/07/08
Loc: S. Utah, U.S.A.
A testament to that TMB scope. Those stars are miniscule and tight. Very, Very nice processing...
-------------------- C8 SCT, f/6.3 reducer, WO ZS66SD
Losmandy GM8, SSAG, Canon XS (stock)
Toshiba NB205 (field computer)
DSS, PS Elements 7, Bahtinov Mask
Plethora of eyepieces and lots of patience !
s58y
Reged: 12/12/04
Loc: Eastern NY
Very good shot -- the level of detail almost looks like what you get with narrowband H-alpha filters.
-------------------- Hutech 30D, SBIG ST-402 autoguider
SV80S, TV102iis
Old camera lenses: 800mm f/5.6, 180mm f/3.4
AP900, Barndoor tracker
http://www.pbase.com/s58y
Thomas A Davis
Reged: 03/25/05
Thanks. I was a bit concerned about using this filter due to my experience with other Lumicon nebula filters I've had. Most have had pretty badly distorted star images. This one seems to work well. It does greatly reduce the background brightness. To get to a 50% black level, I think it would take about 15 minutes on the exposure time (took me 5 without the filter). It does increase the contrast quite a bit.
Thomas A Davis
Reged: 03/25/05
The TMB80/480 is a really sweet little scope. Using the TeleVue .8X reducer corrector with it, It is tack sharp right to the edge of the frame. I really like this scope for grab-and-go and imaging.
Thomas A Davis
Reged: 03/25/05
The Lumicon Deep Sky filter really does block out a lot of the sky glow. I was happy with the result. Only issue is that the sky becomes greenish-blue with it. To get the magenta appearance to the nebula some like is an issue, due to the curves tool in PhotoShop pushing everything red when you use the background to set it.
Here is the result done that way.
Thomas A Davis
Reged: 03/25/05
I went to the Lumicon website and looked at the transmission
graph for the Deep Sky filter. What I found interesting
was that the entire H-Alpha band is covered just the same
as a dedicated H-Alpha filter with a sharp cutoff between
540 and 640 nonometers. By shifting the balance to the red
channel in PhotoShop, I got this result. While not pretty,
it gives an idea how much H-Alpha is covered by this filter.
Note how much more nebulosity becomes visible.
Thomas A Davis
Reged: 03/25/05
This is processed using Gradient XTerminator with the color balance background checked. The problem with this filter is getting proper color balance, since the section from 540nm to 640nm is completely blocked. This one is about the best I can get. The HA component is very strong on this filter (full HA spectrum pass, with a stronger HA component that OII and H-Beta), and it has the effect of creating a strong green-blue background. Not really sure how to color balance with this, since using either white stars (Maxim DL), or trying for a black background (PS CS4), leaves something missing on either end.
Mike Clemens
Reged: 11/26/05
Loc: Wasilla, Alaska 61N
All are nice but this last one really pops!
historius apochromaticus
Thomas A Davis
Reged: 03/25/05
Thanks Mike. I'm trying to figure the best way to process images with the Lumicon filter. It really does boost the contrast, but getting color balance right is the issue. So far, Gradient XTerminator seems to do this the best (don't need it for gradient issues so much with this scope, but it seems to have the best color balance function for this filter). I'll gladly look at any other ideas out there.
