Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Ive had a mad idea for some time now about cutting relief channels into a pitch lap, but have never tried it. Instead of cutting channels, why not drill a series of holes spaced apart, in a grid formation, using a 1/2 inch drill driven by a the slow speed on a screw driving drill. This would be a lot easier to do than channeling. Comments please, and has anybody tried the same idea and actually used it.
perfessor
Reged: 12/30/07
Loc: Northern Illinois
Are you talking about walking the drill bit along, perhaps joining previously drilled individual holes? I would imagine that a lot of flaking would occur, and you wouldn’t get a clean cut. Then also, the bit would heat up, melt the pitch and completely foul the flutes of the bit. Maybe at that point, your heated bit would melt its way through the pitch to create a channel. Might as well use a soldering iron, in that case. So it doesn’t sound promising to me. But feel free to try it out and give us a report.
-------------------- Tom
"Don't always know what I'm talkin about"
8" f/7
Gary Fuchs
Reged: 05/22/06
Loc: Easton, PA, USA
John, that sounds like an interesting idea. Maybe a Forstner or custom bit would work, and soft pitch might need chilling?
I'm wondering if those holes might act like suction cups? If so maybe some light scratched channels between them would take care of that?
Maybe I'll experiment tonight.
Gary
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
I have actually tried a specimin pitch tool, cast flat on a glass plate, the pitch was about a 1/4 inch thick,I then drilled holes in rows to form a matrix, I did not drag the bit or connect the holes with channels. I spaced the holes about 3/4 inch apart, and the depth of the holes I kept to about 1/4 inch. The drill was 3/8 inch diameter. By using a slow speed of about 50 RPM I succeeded in drilling the holes without flaking or fracturing. The drilling heated up the pitch locally and prevented this from happening. The drill did clog but it made no difference. Afterwards I lightly scraped a steel rule over the holes to remove the burrs. Making a lap this way was easier than channeling, and it was quick. I have not yet tried it on an optic. The clog in the drill flukes was easily removed by a screwdriver. Subsequent dressing of the lap is easier too, as all you have to do is lightly go over the holes with the drill; the speed of the drill must be low.
Mark Harry
Reged: 09/05/05
Loc: Northeast
"I have not yet tried it on an optic." ======================================= I think you'll be disappointed when you do. Probably have very high/inconsistent drag, but I might be wrong. M.
-------------------- So many projects, so little time!
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Yeah! you are probably right.
Gary Fuchs
Reged: 05/22/06
John,
I tried a 5/8" Forstner bit - with very gentle pressure - at about 600 RPM in the drill press and it seemed to work fine with the build up around the edge of the hole coming off easily.
Gary
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Gary, are you going to try it on a mirror polish, it would be interesting to see what happens when you test it, probably get a load of garsely ring zones. I am not making mirrors at the moment, so I cannot do this for myself, anyone else want to try? John.
Gary Fuchs
Reged: 05/22/06
John,
I just did one cut as a test but it so happens I made a new lap last night and it's not channeled and I'm curious so may try it. If disk-shaped facets can work it would seem reasonable that round holes might also. This pitch is softer than what I tested though so may not cut nicely.
Gary
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
I await your verdict with bated breath. John.
Gary Fuchs
Reged: 05/22/06
John,
Bearing in mind that I'm no expert, here's my report:
I made about 35 5/8" holes in a 6 1/2" lap using a Forstner bit in the drill press. It does melt the pitch pretty quickly but most of the pitch rides up on the bit and there's just a slight rim around the hole.
At first I cleaned the bit after one or two holes but then found I could drill a bunch and just pick off pieces from the bit without bothering to clean it.
So that only took a few minutes. Removing that rim is easy, either fingers or a piece of steel as you described. I put a board on the press table and a plastic bag on that to contain the pitch. Altogether not too messy. The pitch is on the soft side so I was surprised the holes came out well.
I pressed with mesh and scratched a few criss cross lines with a single edge blade then ran it fixed post style with my 9" mirror on the bottom at about 36 RPM with about 10lbs weight.
Because of the softness I could only do about 10 min before it needed the mesh and a press. I did 3 sessions and then redrilled some of the holes to open the up. They'd reduced to about half their original size. Fewer holes would have been better as I couldn't open all of them.
Anyway, one more session after that. As far as I can tell, the lap behaved pretty well. The mirror isn't quite polished out and had been very zoney but is considerably improved.
My concern about vacuum proved to be unwarranted.
I did a few strokes by hand and it felt very good. Perhaps mostly due to the soft pitch but still.
I'm going to continue with this at least a bit more.
Gary
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Gary that is encouraging, if you can complete the polish, and figure the mirror with the tool then we have something. The holes will not close up so rapidly with a harder pitch of course, but you have found that it is easier to rout out the holes than to re channel a standard lap. You can zonally tune a perforated lap by arranging the holes to reduce the surface area on parts of the lap, say more holes closer together at the center one third than the rest to reduce a torus, and vice versa to reduce a hump. I feel that one can fill up the holes with pitch and redrill then press far more easily than completely rechanneling. John.
Gary Fuchs
Reged: 05/22/06
Still a ways to go...
Here's what the lap looked like with 10 min of work after redrilling some holes.
A close-up showing the finish the bit leaves and also how the other holes look closed up somewhat.
And the bit after some of the accumulated pitch has been broken off.
I think I forgot to mention it earlier but my first session was with just the mesh microfaceting and no additional scratching. That seemed to work fine but since the pitch was a little too soft I wanted to extend the time a bit.
Gary
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Gary two of your pix fail to show. Here is a diagram of the perforated lap showing a regular polisher, and two ' tuned ' laps. The black and white holes are just for emphasis.
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
Gary your pix are now showing,it's about the result I am getting, spacing wise. John.
Gary Fuchs
Reged: 05/22/06
John,
It's odd about pictures, sometimes they show up after waiting awhile, and like now, needed a screen refresh.
I'm thinking maybe 5/8" was a bit big for this lap so might try 3/8" which would make the variable spacing you describe easier to manage.
Also want to try hand turning the bit. That would be more work but less heat and easier to control for rechanneling. An end mill might work too and might be easier to remove the clog of pitch from.
Gary
Kalle
newbie
Reged: 06/29/09
Loc: Germany
How messy was your action? What about pieces flying around?
-------------------- Kalle
Gary Fuchs
Reged: 05/22/06
Not bad. I had the plastic bag on a 12"x12" piece of scrap plywood, and that on the press table and just let the bag edges up an inch or so to contain the pieces. Mostly the pitch melted in contact with the bit. Certainly much less mess than with a blade, but not as neat as melting channels.
Even with the hard pitch I tested first the pieces didn't go far.
Possibly a larger lap with 1" or bigger holes might be more of a problem.
Gary
Crayfordjon
Inventor
Reged: 06/17/09
Loc: UK
No I had no problem with bits flying around as the bit tended to melt the pitch locally thus holding particles in place, the flukes are deep and broad and will allow a lot of pitch to stick to the drill, which can be peeled off. A 3/8 twist drill, as used in machine shops is about the right size, I use a Bosch drill/ screwdriver set on screwdriving, you can vary the speed by pressing the trigger in and out, The speed should be about 50RPM to make the holes. The drill is a stub about an inch long, a short drill allows better control
Gary Fuchs
Reged: 05/22/06
John,
You've probably been through all these but just in case, hand turning an end mill didn't work well - chipped a lot even with very light pressure. I'm not going to bother trying it powered.
I'd previously tried a 5/8" Forstner bit and last night switched to a 3/8". That seemed to work fine too, though I suspect the twist drill you suggest would be easier and maybe safer to clean.
I may repour tonight and start fresh with the smaller holes. One problem with the larger holes was chunks breaking off where the holes were too close to the edge.
Gary
