QueueCT
Reged: 06/25/08
Can't get rid of the $#@*& gradient and Gradient Xterminator isn't compatible with PS7. Believe me, it was a lot worse when I started.
30 x 240s at ISO1600 20 darks 30 flats (for what they were worth) C8 at 1260mm fl on a CGEM
Suggestions and critiques always welcome
John
Nils_Lars
Reged: 01/04/08
You have good detail and the stars look good , aside from the gradient thing I cant see much else , maybe the color is a little flat and could use a boost.
I think you can still find a copy of PixinsightLE and update it which lets you use the DBE to fix gradients.
-------------------- Erik
Orion ED 80
Williams Optics VII reducer
Celestron 8" SCT
Orion Starshoot Autoguider
PHD guide
NexImage webcam
QueueCT
Reged: 06/25/08
Erik--
You're right about the color. I tried to pump the saturation but it accentuated the blue cast in the upper left quadrant. Kind of a trade off. I'll need to revisit this later once I've given my eyes a rest. Fresh start and all that.
John
Nils_Lars
Reged: 01/04/08
You can always post the Tiff someplace like Mediafire and I can run it through GradX for ya.
Orion ED 80
Celestron 8" SCT
PHD guide
NexImage webcam
QueueCT
Reged: 06/25/08
Erik--
Thanks for the offer. Below is the URL for the file.
http://www.mediafire.com/?sharekey=574575418d4e4613d8f14848abf485dde04e75f6e8ebb871
John
scully1234
Reged: 09/04/07
Loc: Rush, NY
Nice data John !
I copied the JPEG off your post and did the following :
Lasso the blue corner, feather selection, crank down the levels in blue and green
Lasso the gradient on the left of the spiral, working carefully around the spiral arms. Feather, and used a curves adjustments to bring the black points input levels a little higher at the left side of the curve, while leaving the highlights the same level to keep the stars bright.
I then used the magic wand on the red blobs, feathered, and boosted the reds with curves adjust.
I then used Noels tools to do an increase star colors to make the star colors pop a bit.
I then did an overall Vibrancy and saturation boost by +20 to make the image colors pop out.
What do you think ?
-------------------- Astrophotographer ! Finally ! (thanks to everyone's help on CN)
My webpage = www.starsinmybackyard.com
Celestron C8 XLT on the CG-5GT mount
Meade 70mm AZ guide scope
Canon EOS 450D (xsi)
DSI color (guide cam)
Acer mini-laptop (for guiding and xsi tethered shooting)
Canon A530 point-n-shoot
Edited by scully1234 (10/21/09 12:59 PM)
QueueCT
Reged: 06/25/08
Thanks for the taking the time on adjustments. I like the boost in saturation in the core. It was a valiant effort on the background gradient/color issues with some improvement.
J
Mike Clemens
Reged: 11/26/05
Loc: Wasilla, Alaska 61N
Another idea, download a CCDstack trial and use the tools in it to fix the gradient... at least for 30 days : )
Nils_Lars
Reged: 01/04/08
Ok here is the file with just a GradientX run on it with balance background turned on.
I also took the same file and went a bit farther with it with some curves and color boost in match color and then an inverse mask with noise ninja.
There both posted here on Mediafire again.
http://www.mediafire.com/?sharekey=3fd88085f834d31fab1eab3e9fa335ca6d94a3970d5bfbb9
Orion ED 80
Celestron 8" SCT
PHD guide
NexImage webcam
QueueCT
Reged: 06/25/08
Great job on the adjustments. I appreciate the help eliminating the gradient. Gets me thinking about upgrading PS and picking up GradientX. Hope you don't mind but I've posted the adjusted file so everyone can see the differences.
John
