Orion_PKFD
Reged: 01/22/08
Loc: Vieira do Minho, Portugal
Perseus Double Cluster new
      #3393367 - 10/16/09 04:57 PM
Hi folks,
This is a "quicky" taken on September 27:
SkyView Pro 8" f/5
12x30s
20 Darks
Bigger version and description at: http://astro-andregoncalves.blogspot.com/2009/10/perseus-double-cluster.html
Comments and suggestions are welcome!
André Gonçalves
André Gonçalves
SkyView Pro 8" EQ
Dob 4,5" (ATM)
60mm achromatic refractor
10x50 WA
10x25
SPC900NC
DSI
Canon 1000D
s58y
Reged: 12/12/04
Loc: Eastern NY
Re: Perseus Double Cluster new [Re: Orion_PKFD]
      #3393660 - 10/16/09 08:53 PM
Nice, with good star colors
Hutech 30D, SBIG ST-402 autoguider
SV80S, TV102iis
Old camera lenses: 800mm f/5.6, 180mm f/3.4
AP900, Barndoor tracker
http://www.pbase.com/s58y
drksky
Reged: 09/01/09
Re: Perseus Double Cluster new [Re: s58y]
      #3393723 - 10/16/09 09:43 PM
Allow me to ask something not so obvious to me. Why so many darks when you only have 12 subs? Just curious
Tony C
AT8RC
C6-R
CG-5 ASGT
ST80 w/StarShoot Autoguider
Canon EOS 450D (Stock)
The Drinking Bird
Doubleglaze
Reged: 11/01/07
Loc: Pacific NW
Re: Perseus Double Cluster new [Re: drksky]
      #3393764 - 10/16/09 10:09 PM
Nicely done with good colors and definition. I use this target as a motivation for improvements in my imaging and processing techniques and still haven't gotten it quite right. Yours is close!
Lots of darks is good and not really correlated to how many light frames were taken. I use 30X to 50X for all my darks. The down side is the data collection time, which I generally take care of the next day after imaging if I can match temp correctly. I need a cooled CCD, among all sorts of other things
Dark frames are used to determine what the non-light (i.e. dark) signal is from the camera. Once the many dark frames are combined together you can generate a "master dark" which is used to subtract out the dark signal from the image you acquired. Each dark frame has a signal associated with each pixel, and a noise component which changes the measurement of the dark signal on a frame by frame basis. Using lots of darks reduces the uncertainty of what dark signal to subtract out of each image.
Vixen VMC260L / Sphinx SXD
Pentax 75 SDHF
Canon 40D / 50mm f1.4 / 100mm f2.8 macro / 28-135 f/3.5-5.6 / 200mm f2.8L
http://www.astrophotogallery.org/showgallery.php/cat/500/ppuser/166
Orion_PKFD
Reged: 01/22/08
Re: Perseus Double Cluster new [Re: Doubleglaze]
      #3394185 - 10/17/09 08:25 AM
Thank you all,
drksky, I had to throw away some subs, but 20 darks arent too much, as Doublegaze said. I was expecting 25 good lights...
It was interesting to process because it's difficult not to saturate the stars
André Gonçalves
André Gonçalves
SkyView Pro 8" EQ
Dob 4,5" (ATM)
10x50 WA
10x25
SPC900NC
DSI
Canon 1000D
drksky
Reged: 09/01/09
      #3394496 - 10/17/09 12:10 PM
I'm new to digital imaging, so I was just curious.
The last time I took astrophotos, I was using hypered Tech-Pan and guiding by hand.
Tony C
AT8RC
C6-R
CG-5 ASGT
The Drinking Bird
Javier1978
Reged: 02/12/09
Loc: Buenos Aires, Argentina
      #3396280 - 10/18/09 02:15 PM
Very nice image André!
6" f5 Sky Watcher Reflector
Eq3 mount (Dual Axis)
Unmodded Canon 300 D
nofxrx
Vendor (HyperCams & Mods)
Reged: 07/12/05
Loc: Palm Bay,Florida
Re: Perseus Double Cluster new [Re: Javier1978]
      #3397231 - 10/18/09 11:09 PM
Agreed,very very nice ,Andre!!
Well done.Star colors look great too!
CS!!
Brent Oliver
WO-66SD*WO-Megrez102ED-Special Edition*Super C8 Plus*
CGE Pier-Mounted
Some Cameras,some Filters
HyperCams&MODS
My Gallery
Orion_PKFD
Reged: 01/22/08
Re: Perseus Double Cluster [Re: nofxrx]
      #3401610 - 10/21/09 06:37 AM
Thank you very much Brent and Javier!
André Gonçalves
SkyView Pro 8" EQ
Dob 4,5" (ATM)
10x50 WA
10x25
SPC900NC
DSI
Canon 1000D
5 registered and 3 anonymous users are browsing this forum.
