Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
Siebert black night 22mm vs Denk standard/earthwin
      #3402792 - 10/21/09 06:08 PM
Which do you recommend? The 22mm ca of the black night doesn't bother me at all.
Are these three in the same optical quality category or is one better.
I am asking about the optical quality of the bino itself not the fact that there is a powerswitch option with the denk and earthwin and a powermag wheeletc. with the siebert.
Eon 120 ED
Stellarvue bv3
Gas is only worth it in the stars not at the pump
Covey32
Reged: 12/09/04
Loc: Georgia
Re: Siebert black night 22mm vs Denk standard/earthwin new [Re: Itz marcus]
      #3402798 - 10/21/09 06:12 PM
In that case I consider it a tossup. They are both optically excellent, to my eyes.(I can only speak of the Denk standards, since I've not used the enhanced Denks.)
Hank
12.5" Mag1 Portaball
Orion 120mm F5 Refractor
Skywatcher 120ED F7.5 Refractor
1982 Celestron C8 Orange tube
Celestron ED80 Refractor with Lunt 50mm HA
Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
Re: Siebert black night 22mm vs Denk standard/earthwin new [Re: Covey32]
      #3402837 - 10/21/09 06:31 PM
Hi Hank,
I really appreciate your answers and thank you for the support.
Clear Skies
Eon 120 ED
Stellarvue bv3
Edited by Itz marcus (10/21/09 06:32 PM)
arowana
Reged: 01/02/06
Loc: Pleasant View,Tennessee
      #3403332 - 10/21/09 11:01 PM
Never used the Siebert brand of binoviewers before.
But I have viewed through the Denk Standards and the EarthWin standards during the same night.
They were like twins. Neither,out done the other visually.
Same with the Denk II's and the EarthWin Dielectrics.
They are one in the same visually.
Mechanically, the edge goes to the EarthWin since they have
camber adjust diopiters rather than the screw type of the Denks.
CS's
Joey
CPC 1100
Earthwin Binoviewer with Dielectric P/F Switch
Matched Pair of 24 Pan's
LDb
Reged: 02/01/08
Loc: Cleveland, Ohio
Re: Siebert black night 22mm vs Denk standard/earthwin new [Re: arowana]
      #3407007 - 10/23/09 08:19 PM
Hi
I have the Black Knight 22 Bino and it is terrific. Harry Siebert makes excellent optical equipment and I unreservedly recommend his products. Also -- I have the Power Mag wheel and it is also an incredibly good accessory to use with the binoviewer. one ep with either 3, 4, or 5 mags. You might consider it an essential accessory. You would not regret getting Siebert equipment.
Hope this helps,
Howard
10" LX200R-UHTC (on ScopeBuggy which is terrific)
ETX-90-RA
ATM'ed-8"f/8 and 4.25"f/10 planetary Newtonians
Brandon eyepieces: 48mm,32mm,24mm,7/8",12mm,16mm,8mm,6mm,4mm (yes-4mm; special build in 1985 from 1960 optics)
Double set for binoviewing
Dakin 2.4x Barlow
Vintage ep's:
Gailand 7mm WF, 16.3mm (THE Galoc), Bertele 18mm
Siebert Optics:
Black Knight BinoViewer, 0.6x-1x-2x Power Wheel, 4x-8x telecentric zoom barlow
Astro-Tech Titan WF ep's: 38mm, 32mm, 26mm, 20mm, 15mm, 10mm
Edited by LDb (10/23/09 08:21 PM)
Itz marcus
Reged: 02/12/06
Loc: Brooklyn NY
Re: Siebert black night 22mm vs Denk standard/earthwin new [Re: LDb]
      #3409985 - 10/25/09 01:33 PM
Thanx so much for the replies. They have really helped!
Eon 120 ED
Stellarvue bv3
ruachsheavens
Reged: 07/17/05
Loc: Northern IL
denk vs earthwin new [Re: arowana]
      #3435973 - 11/08/09 09:07 AM
what is a camber adjust diopter?
thanks!
There is no "high" like the Most High
davidpitre
Reged: 05/10/05
Loc: Central Texas
      #3436467 - 11/08/09 02:12 PM
As far as I can tell from their advertising, the Earthwin binoviewer is the same whether it is purchased with their standard or dielectric diagonal.
David
arowana
Reged: 01/02/06
Re: Siebert black night 22mm vs Denk standard/earthwin new [Re: davidpitre]
      #3436486 - 11/08/09 02:23 PM
You are right about the Binoviewers David. You get the same diopter adjust with either binoviewer.
The body's are the same.
The only difference in the binoviewer is the beam splitter.
You get standard coatings on the basic binoviewer and dielectric coatings on the Dielectric version.
CS's
Joey
CPC 1100
arowana
Reged: 01/02/06
Re: denk vs earthwin new [Re: ruachsheavens]
      #3436491 - 11/08/09 02:24 PM
CS's
Joey
thanks!
Sent you a PM with an explination.
CS's
Joey
CPC 1100
warf
Reged: 10/25/04
Loc: Wisconsin
Re: denk vs earthwin new [Re: arowana]
      #3442555 - 11/11/09 05:39 PM
I wanted to know too
Marsh
Celestron NS 11 GPS, Denk Standard Binoviewer, Pair of Denk 21 EP, Denk PowerSwitch Diagonal, Denk PST Corrector, Coronado PST Double Stacked, WO ZS80 Anniversary,Celestron 15x70 Binoculars
1 registered and 3 anonymous users are browsing this forum.
Moderator:  EdZ, jrcrilly
