Privacy Policy |
Please read our Terms
of Service | Signup and
mattyfatz
Reged: 12/27/06
Loc: Boise Idaho
Can an SCT or MAK primary be used for a rich field newtonian primary? Will the coma be too much to bear? Has anyone done this in the past? thanks. Matty
-------------------- **Matty**
Stimulating the economy, one piece of equipment at a time.
DAVIDG
Reged: 12/02/04
Loc: Hockessin, De
Usually the primary in both SCT or a Mak is spherical so at f/4 or less, the spherical abberation will be huge. Only a classical cassegrain uses a parabolic primary that would work in a Newtonian. A dual focus cassegrains use a removal secondary that is replaced with a newtonian diagonal so the telescope can be used both as a high and low power system. I believe that both Cave and Starliner sold commerical versions of this setup.
- Dave
-------------------- Homemade 'scopes 8"f/7,6" f/5", 6"f/4, 4.25" Schief. 60mm Coronagraph,60mm H-alpha system, 4.25" White-light Solar Newtonian,solar spectroscope, 4.5" f/16 Schupmann Medial refractor, 14 Stellafane awards 7 in optics
Engineering = Taking what you have and making what you need.
gregj888
Reged: 03/26/06
Matty,
There are designs with correctors at various places, but you pretty much need a corrector of some sort. Houghtons, Wrights both have full App. correctors and both would be better at F/4 than f/2 (most SCTs at at F/2).
Several field corrector designs are also around. Sorry, no names off the top of my head.
Greg
mattyfatz
Reged: 12/27/06
Loc: Boise Idaho
Thanks for the advice
1 registered and 3 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
