Observing >> Deep Sky Observing
nytecam
Reged: 08/20/05
Loc: London UK
galaxy group JKCS041 @ 10BLY
      #3405982 - 10/23/09 10:52 AM
Anyone observing JKCS041 reported in Science Daily Quite a challenge for the DSO Forum
ps: any idea as to its RA and Dec?
Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+e-finder+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9+Lodestar CCDs/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-my videos
Edited by nytecam (10/23/09 10:55 AM)
tatarjj
Reged: 04/20/04
Loc: Austin, TX
Re: galaxy group JKCS041 @ 10BLY new [Re: nytecam]
      #3406385 - 10/23/09 02:19 PM
My 25" can see large elliptical galaxies out to 3 billion light years. My 18" can see large elliptical galaxies out to around 2 billion light years. This indicates a trend that if you have a telescope with twice the diameter, then you can see twice as far- which makes sense if you plug in the numbers for dimming caused by distance (proportional to 1/d^2) and light gathering power (proportional to r^2). This would mean that roughly, for every inch of aperture, you can see big ellipticals another 111 MLY out into space. So, by this analysis, you would need a 10/0.111 = 90" telescope to see large elliptical galaxies out to 10 billion light years.
HOWEVER, the above analysis is NOT a valid far-field approximation in an expanding universe. A couple factors come into play. First, a galaxy 10 billion light years away first emitted its light when it was alot closer to us, and then the expanding space "slowed" the light down so that it took 10 billion years to reach us. So, angularly, a 10 BLY distant galaxy is going to look a lot closer than 10 BLY. More importantly, however, is that galaxies emit a black-body spectrum- more accurately, a sum of 100 billion or so black body spectrums. That means they emit comparetively little electromagnetic radiation above longer wavelength UV. This is especially true for an old, red, elliptical galaxy. So all that visible and long wavelength UV light will be red-shifted down to IR or at least, red, where are eyes are blind and insensitive, respectively.
One final factor: Big elliptical galaxies didn't even EXIST in the early universe. So the whole premise is flawed. However, in balance, I would assume that some very blue, bright galaxies full of young stars did exist; it's possible that they may have rivaled older and bigger galaxies in luminosity- however, I doubt it.
So with all these factors- redshift, extreme faintness, lack of huge, bright galaxies- I HIGHLY doubt anyone will ever see these objects. The only hope that may exist is if you have some INCREDIBLY powerful UV emitting galaxies that are downshifted to visible light, and you're visually observing with, like, the 5 meter Hale telescope. But from the above anaylsis, I can say with good certainty that even if some large galaxy existed that had a respectable peak in the visible spectrum post-redshift, you'd still need something along the lines of a 100" telescope visually see it. I am not sure of the amount of redshifting that occurs at 10 billion LY, I would have to dig out the forumlas for relativistic redshift, and I have better things to do.
John T.
Austin, TX
25" f/4.2 Dob
18" Obsession #701
4" Stellar Vue Achromat
8X56 Binos
Edited by tatarjj (10/23/09 02:31 PM)
LumpyDarkness
Reged: 08/06/07
Loc: San Francisco bay area
      #3406457 - 10/23/09 02:58 PM
Anyone observing JKCS041?
Darn, I thought you'd imaged it!
Mark Wagner
Deep Sky Observing Blog
SF Bay Area Observers - TAC
Adventures In Deep Space
NGC/IC Project
nytecam
Reged: 08/20/05
Loc: London UK
Re: galaxy group JKCS041 @ 10BLY new [Re: LumpyDarkness]
      #3406732 - 10/23/09 05:15 PM
Well maybe I'll try IF someone gives me the co-ordinates
Nytecam 51N 0.1W
Alvin Huey
Reged: 10/18/05
Loc: NorCal
      #3406832 - 10/23/09 06:20 PM
Let's get the coordinates and see if Jimi can see it in his scope. I'll pass it on to him.
We have seen some stuff that I thought was not possible. The jet in 3C273 comes to mind. Three of us (Jimi, Gary Myers and myself) saw it, sketched it independently and all three matched...so I doubt that we were seeing things. We did NOT look at the image before going to the eyepiece. We used a 4 or 6mm Zeiss on the 48".
Clear Skies,
Alvin #26
22" f/4.0 reflector and 30" f/4.3 StarMaster
FaintFuzzies | TAC | TAC-Sac
Hrundi
Reged: 02/06/08
Loc: Estonia
Re: galaxy group JKCS041 @ 10BLY new [Re: Alvin Huey]
      #3406842 - 10/23/09 06:25 PM
ra,dec=(36.695,-4.68)
Those seem to be the location values.
Alvin Huey
Reged: 10/18/05
Loc: NorCal
Re: galaxy group JKCS041 @ 10BLY new [Re: Hrundi]
      #3406867 - 10/23/09 06:44 PM
Is that 2h 26m 46.8s -4.68 degrees? Too bad that the Sloan doesn't cover that area.
Clear Skies,
Alvin #26
Hrundi
Reged: 02/06/08
Loc: Estonia
      #3406988 - 10/23/09 08:02 PM
It's in the constellation of Cetus, so I think it should be, yes.
tatarjj
Reged: 04/20/04
Loc: Austin, TX
      #3407260 - 10/23/09 10:45 PM Attachment (15 downloads)
Well, Jim can certainly try, but it's a pipe dream. The field of the galaxy cluster is shown below. This is a POSS red image acquired via SIMBAD (http://simbad.u-strasbg.fr/simbad/)
There ARE galaxies in this image. However, they are almost certainly ALL foreground objects. I can tell you this for two reasons:
1) I have extensive experience both observing very faint and distant galaxy clusters, and looking at DSS images of them. I've looked at around 2000 of the Abell galaxy clusters on the POSS plates. I know what distant galaxies look like on the POSS plates, and these appear to be run-of-the-mill galaxies at 1, 2, or 3 BLY.
2) More importantly, this field is very well studied. All the galaxies that I checked on this plate had redshifts of less than about 0.2, or a little under 3 billion light years.
None of the galaxies seen on this plate appear to be members of the cluster.
John T.
Austin, TX
25" f/4.2 Dob
18" Obsession #701
8X56 Binos
Edited by tatarjj (10/23/09 10:51 PM)
tatarjj
Reged: 04/20/04
Loc: Austin, TX
Re: galaxy group JKCS041 @ 10BLY new [Re: tatarjj]
      #3407282 - 10/23/09 10:58 PM Attachment (13 downloads)
Compare that image above to the image from Science Daily, below. As you can see, it's the same field. Furthermore, it's obviously alot deeper, as some of the dots in the POSS image are now full-fledged spirals. Even in the deeper image in Science daily, I can't identify conclusively if any of those galaxies are part of the cluster, and it doesn't look like they are. So not only is this cluster not visible on the POSS images, it doesn't seem to be visible on an image that's WAY deeper than the POSS.
John T.
Austin, TX
25" f/4.2 Dob
18" Obsession #701
8X56 Binos
nytecam
Reged: 08/20/05
Loc: London UK
      #3407611 - 10/24/09 03:09 AM
Thanks - the field [as quoted] is currently wellplaced and worthy of attention so good luck to the eyeballers - I've access to 2m aperture and may try other options
Nytecam 51N 0.1W
Edited by nytecam (10/24/09 03:38 AM)
Alvin Huey
Reged: 10/18/05
Loc: NorCal
      #3407643 - 10/24/09 04:55 AM
Yeah it may be a pipe dream.
Like you, Jimi and I have extensive experience observing galaxies and galaxy clusters and many of them. Both of us been doing this for 30+ years.
I didn't even look deeper at the article...and based on what you showed in the last two posts, it may not be possible. But if anything is possible for visual observers it would be with Jimi's scope. You know where it is...same area where you spent this past June in Fort Davis, TX...and 48" of high quality glass is nice to have.
Clear Skies,
Alvin #26
LumpyDarkness
Reged: 08/06/07
      #3408119 - 10/24/09 12:47 PM
Hi Alvin,
John has got it right. This is an object that is beyond the "Ainto Catalog" (http://www.astronomy-mall.com/Adventures.In.Deep.Space/aintno.htm)... Jimi's scope is great, but how many of us own, let alone have ever even looked through a 48" instrument? The chances of one of us on this CN forum observing this target, or even imaging it, are probably non-existent.
I am by no means the most experienced observer here, John certainly seems more authoritative, Steve would be another good source, but... ... even looking at the Coma Cluster of Galaxies, they are difficult nearly stellar smudges - at < 0.5BLY! An object at 10BLY, that is not a quasar? Sorry... no.... for heaven's sake, the article itself says this thing was "discovered" using an x-ray space telescope!
Mark Wagner
NGC/IC Project
7331Peg
Reged: 09/01/08
Loc: North coast of Oregon
      #3408346 - 10/24/09 02:50 PM
Thanks for link to the "Aintno" catalog - didn't know that existed. It was certainly worth a few laughs this morning. But "aintno" way I'll see any of those objects with a stable of small refractors.
John
tatarjj
Reged: 04/20/04
Loc: Austin, TX
      #3408378 - 10/24/09 03:10 PM
Hi Alvin,
Well technically, it was discovered with an IR telescope, and confirmed with an x-ray scope. This is because all of its light has a redshift of z = 1.9. With z = wavelength observed/ wavelength emitted - 1, that means that the wavelengths of the light from this cluster have been stretched by a factor of 2.9 times their original value. So, even your 400nm blue light is going to be stretched beyond visible wavelengths. What you would see if you actually had a big enough scope to see this thing (probably at least 5 meters or larger) would be light that was originally ultraviolet. Since galaxies emit more visible light than UV light, these galaxies are fainter in visible light than they would be in a static universe. You would likely need something like a 5 meter scope to see them visually, and that may not even be big enough.
Combine the facts outlined above with my estimation that even in a static universe, you'd need a 90" telescope to see them, having Jimi try to see anything is a waste of time, even with a 50" scope. Maybe if Jimi gets cybernetic implants that allow him to see into the infrared and give him at least 4X light amplification, he'd have a chance. With his budget though, he may be able to afford them!
John T.
Austin, TX
25" f/4.2 Dob
18" Obsession #701
8X56 Binos
Edited by tatarjj (10/24/09 03:20 PM)
JakeSaloranta
Reged: 09/18/08
Loc: Sisu, Sauna, Sibelius...
      #3408393 - 10/24/09 03:16 PM
Regarding distances, I was just browsing Wolfgang Steinicke's homepage and his "Catalogue of Bright Quasars and BL Lacertae Objects". Does anyone know what measurement is used in his distance table? For example 3C 273 is at a distance of 584. Megaparsec perhaps?
http://www.klima-luft.de/steinicke/KHQ/anhang.txt
/Jake
Hrundi
Reged: 02/06/08
Loc: Estonia
Re: galaxy group JKCS041 @ 10BLY new [Re: JakeSaloranta]
      #3408508 - 10/24/09 04:25 PM
Megaparsec doesn't seem to fit with the known distance figures.
sgottlieb
Reged: 07/22/07
Loc: SF Bay area
      #3409305 - 10/25/09 02:21 AM
/Jake
Yes, I'm certain that Wolfgang was using Megaparsecs, as I have a printed copy of his catalogue that gives the header for that column as "Mpc". Of course, his distance depends on the value he was using for the Hubble constant. Unfortunately, the 23 page introduction is all in German, so this may take me awhile to locate the value ;-)
Steve Gottlieb
18" f/4.3 Starmaster
7500+ NGC/IC Visual Descriptions
NGC/IC Project
sgottlieb
Reged: 07/22/07
Loc: SF Bay area
Re: galaxy group JKCS041 @ 10BLY new [Re: sgottlieb]
      #3409313 - 10/25/09 02:37 AM
Actually, it took just a few seconds to find he is assuming H sub 0 = 75 km/sec/Mpc.
Steve Gottlieb
NGC/IC Project
nytecam
Reged: 08/20/05
Loc: London UK
      #3411245 - 10/26/09 03:38 AM
Thanks Steve - keep up the good work I seem to have stirred a hornets-nest amongst big-scopers
I recorded the field last night with a wideangle cam and can confirm the starfield, [and no more ] coincides with the field attributed to JKCS041 below which is ~47arc-minutes wide and presumably the faint chain of stellar objects, within the blue disk, is part of the galaxy group
Nytecam 51N 0.1W
Edited by nytecam (10/26/09 04:15 AM)
2 registered and 3 anonymous users are browsing this forum.
Moderator:  Olivier Biot
