Privacy Policy |
Please read our Terms
of Service | Signup and
wmyers
Reged: 01/23/08
Loc: High Point, NC
I have a laptop with a dead motherboard. The screen is in working order. I want to remove the screen and use it for making flats. Is it possible to somehow wire the screen where it just displays solid white and just turns on and off. I'm not sure if this is possible, I know enough about electronics to be dangerous. Any help is greatly appreciated!!
wynn
-------------------- Orion 120 ED Refractor
Feathertouch Focuser
Orion Atlas EQ-G goto mount
Orion 80 guidescope w/Starshoot autoguider
AstroTech 2" quartz diagonal
Canon Rebel XT
grendel
Reged: 04/12/09
Loc: Canterbury, Kent, UK
the screen backlight is fed from its own supply from an inverter, so that bits easy, all you then have to do is turn all the pixels on at once, which may be possible if you can get the pinout for the monitor cable. grendel
Darenwh
Reged: 05/11/06
Loc: Covington, GA
a screen like this with a piece of Monolyth attached would be great with star charts printed on transparency's. This way, you could just set the chart on the screen you want, turn it on, and you have black on read easy to read star charts. No shining a flashlight around the page trying to read it.
-------------------- Daren
Covington, GA
wmyers
Reged: 01/23/08
Loc: High Point, NC
Any idea how to figure what voltage to input to the inverter?
Canon Rebel XT
Darenwh
Reged: 05/11/06
Loc: Covington, GA
Sure, if the laptop still powers on at all then just check the voltage across the leads...
Covington, GA
13 registered and 13 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
