Privacy Policy |
Please read our Terms
of Service | Signup and
tim53
Reged: 12/17/04
Loc: Highland Park, CA
A while back, I had a couple of counterweights get stuck together on my NJP, such that I had to take the whole shaft off with the two stuck weights attached in order to put the mount back in the scopeguard case.
I was able to get the weights apart by tightening the shaft, and now I'm making sure I use the rubber spacers between the weights all the time now...
...but now the shaft is stuck on the mount. Can't budge it to save my life. I just left it in my shop with penetrating oil soaking in it, but I'm not optimistic I'll be able to just twist it off tomorrow.
Short of using a pipe wrench on it, which would score up the knurling on the shaft, I can't figure out what to try next.
Any suggestions??
When I bought the mount used some years back, it came with a Casady shaft, but no weights. maybe when I get this puppy off, finally, I should get me some weights for that shaft and sell off the Tak shaft and weights!
-Tim.
-------------------- "We`re just waiting looking skyward as the days come down.
Someone promised there`d be answers, if we stayed around."
-Orchestral Maneuvers in the Dark, "The Romance of the Telescope"
Billydee
Reged: 01/23/08
Loc: Winter Haven, FL
Cold shrinks metal and heat expands it. If you apply cold to the shaft it may shrink enough to come loose (a very small shrinkage will do it). I have used a can of computer dust off and you point the plastic shaft on the article not what holds it. I have also used a can of freon with the hose and valve attached.
For leverage that won't mar use a leather strap or a hard rubber belt (like a used cam shaft belt from a car). I attach it to a wooden handle with a slot cut in it to get the power to move the item.
Luck, Bill
tim53
Reged: 12/17/04
I used to have a strap wrench for removing oil filters without tearing them apart. Don't know if I still have it, though. Can't be a very expensive tool, though.
Thanks for the cold suggestion. I can't heat the mount without burning the paint, of course.
-Tim.
Al Canarelli
Reged: 12/06/07
Loc: Central New Jersey
The next time you take it apart, use a product called "Never Seize" on the threads. You can buy it in any auto store.
Rusty
Reged: 08/06/03
Loc: Brooker, FL
I'd avoid Never-Seez, as it contains graphite, not a Good Thing for aluminum. Anyway, mine also got stuck, and I wrapped the knurled knob with several layers of electrician's tape and used a pipe wrench. Since then, I applied a thin layer of Super Lube grease to both the threads and the top of the collar. No problems since.
-------------------- N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
tidroplane
Reged: 10/02/06
Loc: Everett, Wa. USA
I would go for the strap wrench, zero chance of hurting your CW shaft. Before re inserting the shaft into the mount, use a small amount of super lube on the threads of the shaft and you should never have this problem again.
-------------------- Clear skies.....David
AT111EDT
AT80EDT-CF
AT66ED
G-11, Gemini
ST2000XCM
16 registered and 6 anonymous users are browsing this forum.
Moderator: Charlie Hein, lineman_16735
