Privacy Policy |
Please read our Terms
of Service | Signup and
ebusinesstutor
Reged: 07/01/09
Loc: Nanaimo, BC, Canada
I recently ordered a used Siebert Binoviewer with a 1.6x optical corrector (OCA).
I hope to use it in my Orion XT8i, an 8" dob with a focal length of 1200mm.
The binoviews will come with a pair 20mm Burgess WAs with a FOV of 67 degrees which is a good starting point.
Using the 20mm Burgess eps with the binoviewer in my dob along with the 1.6x OCA (which I think I will need to get enough back focus) I think will give me a magnification equivalent to 12.5mms or about 96x.
So now I need to decide what other eyepiece pairs to put with it. I did think of getting a second Hyperion 8-24mm Click Zoom, but two of them plus the binoviewer may be too heavy.
I think I need both a higher magnification for viewing planets and the moon plus a lower magnification for just finding things. I usually use a 24mm non-barlowed ep for finding which is a 60x magnification.
Budget wise, I usually don't purchase top of the line, but I usually don't purchase the cheapest ones either. But, because I have to buy in pairs for the binoviewer, it really adds up quickly.
I did notice some nice prices on some ultra wide eyepieces at Owl Astronomy and thought I might pick up 2-3 inexpensive pairs in different sizes there and then upgrade later for the magnifications I used most.
If I buy some of the pairs in 2" ultrawide versions, can I just use an adapter to put them in the binoviewer as the binoviewer only takes 1.25"? The 2" versions cost more, but I like the wider field of view for when I use them without the binoviewer.
Any suggestions for eyepiece sizes/magnification for binoviewers?
-------------------- Garland Coulson
Orion XT8i Dob & Celestron 80 ED on a Vixen Porta Mount Mini
Baader Hyperion 8-24mm Click Zoom & Siebert Observatory 36mm
Siebert Black Knight Binoviewers
SkyWatcher Observing Chair
Celestron Skymaster 15x70mm binos
Joe Ogiba
Reged: 02/14/02
Loc: NJ USA
16 MM Ultra-Wide Angle - 1.25 inch Design: 6-elements in 4 groups Field of View: 80° Eye Relief: 20 mm Price: $44.95
Right, 20mm eye relief and 80° AFOV in a 16mm 1.25" eyepiece for $44.95 . Poor Televue, they only could get 10mm eye relief with their 16mm Nagler.
-------------------- Pentax PF-80ED,Meade 102ED APO,Orion EON 72,120ST
Apex 127,C6 XLT,CR150,C9.25,XT10
Zeiss 7x42 FL,Canon 10x42L IS WP,15x50 IS
12x36 IS II
Garrett Optical 28x110 HD-WP Signature Series
Oberwerk BT-80 45, Apogee RA-88-SA
Denk II Power x Switch binoviewer w/13mm Ethos, 20mm Pentax XW's, 20mm Widescan III's.
17mm Ethos, 22mm Nagler, 40mm Pentax XW, 14mm Pentax XL, 5.2mm Pentax XL, 8-24mm Pentax XL Zoom
Covey32
Reged: 12/09/04
Loc: Georgia
The 1.6 OCA will allow you to go to 30mm easily without vignetting, which works out to about 18mm or so actual magnification. The 16mm widefields work well in a BV, with no vignetting at all. Actually, with a 1.6X oca in the Sieberts, you may even be able to go all the way to 35mm or even 40 without too much vignetting considering those in 1.25 size are all orthos or plossls. Be wary of anything over 24mm that has a fov over 65 degrees, because that's where you may encounter some vignetting.
-------------------- Hank
12.5" Mag1 Portaball
Orion 120mm F5 Refractor
Skywatcher 120ED F7.5 Refractor
1982 Celestron C8 Orange tube
Celestron ED80 Refractor with Lunt 50mm HA
ebusinesstutor
Reged: 07/01/09
Well, a good thing I'm not considering Televues then!
jack45
Reged: 07/07/03
Loc: Lacey WA
Meade 5000s plossls should work well, 60 deg FOV. The 26mm and 14mm can be found cheap at times. I use the 26mm and 14mm and there great with good ER. IMO!
Clear Skies!
-------------------- 16"f/4.5 Discovery Split Tube/TV Paracorr
12.5"f/5 Discovery PDHQ
Orion f/4.9 XT12"Intelliscope
BV's/Bugress Model 24/Stellarvue Model BV3A
TV Smooth Side Plossls,7.4mm,10.5mm,17mm,21mm,26mm
Nagler EPs 9mm T/2,13mm T/1,16mm T/2,20mm T/2,26mm T/5
Axiom EPs 23mm,31mm LX,22mm Panoptic
UO EPs 5MM,6MM,7MM,12.5MM
Baader Hyp 8mm-24mm Zoom
ebusinesstutor
Reged: 07/01/09
Thanks Hank,
That was something I didn't know - the vignetting on the wider fov.
I will take that into account when ordering.
teskridg
Reged: 01/15/08
Loc: PA
My extensive experience with a Burgess binoviewer is that a) you certainly don't need wide angle eyepieces as they aren't as appreciated in a BV as in monovision and that b)high power greater than say, 150x, doesn't work as well in less expensive and more poorly collimated BV's than in the more expensive Denkmeier, TV, and Earthwin units. So, with a 1.6 corrector combined with the bino unit, your focal length will probably effectively exceed 2000mm (see Edz in a number of other threads on this point). Therefore, your 20mm Burgess binolites (which are wonderful in this application),will yield as you noted about 100x and 15mm eyepieces will probably provide as much additional magnification at 133x or so as you'll need or want. I have Hands-on-Optics GTO Plossls and they work great. Traditionally, the bad news about binoviewers is that they obviously require twice the number of eyepieces in a given f/l as monoviewing; the good news is, inexpensive eyepieces give you as much enjoyment in a binoviewer as ultra wide angle, well corrected TV eyepieces do in cyclops mode. At least, in my not so humble opinion. Tim
-------------------- Tim Eskridge
CPC 800
Scopebuggy
Burgess Binoviewer Model 24
8mm Radian
11mm Nagler
15mm GTO
20mm Burgess binolite and Stellar
26mm Meade SP Series 4000
30mm Vixen NPL
ebusinesstutor
Reged: 07/01/09
Thanks Tim,
Just to clarify, the eyepieces are Burgess, but the binoviewer is Siebert.
Godd point about the affordability of the Plossls but I am curious as to why you say that magnifications about 133x are not needed.
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
I would skip buying extra eyepieces, and just use a standard barlow in front of the binoviewer. I have WO binoviewers and I have never bought any additional eyepieces, I use the included 1.6 mini barlow, then I have a Zhumell 2x barlow that the lens assembly actual unscrews from the front of the barlow and screws perfectly on the front of the binoviewer, it actually looks very much like the 1.6x corrector included with the binoviewer, I would guess it provides a around 2.5x screwed on the front of the binoviewer. Then I have a Celestron 2x barlow that I actually use in front of the binoviewer. I would guess it provides a bit over 3x in front of the binoviewer.
The advantage to doing things this way, is you are still using longer focal length eyepieces, which provide plenty of eye relief and also are less sensitive to collimation issues with the binoviewer. Also buying 2 cheaper barlow lenses is much cheaper than buying 4 eyepieces..
Good luck
Ken
-------------------- Telescopes:
Celestron C6 SCT on CG4 mount
Skywatcher 8 inch F/5 Newt on a GEM
Celestron 8 inch Starhopper Dob
Celestron Oynx 80ED
Celestron C130 Mak
Celestron C102HD
Binoculars:
Nikon 7x35 Action
Nikon 7x50 Action
Zen Ray Summit 10x42
Celestron 10x42 Noble
Orion 10x50 Scenix
Celestron 10x50 Noble
Pentax 12x50 PCF WP II
Celestron 15x70 Skymaster
Oberwerk 20x60
Zhumell 20x80
Covey32
Reged: 12/09/04
Loc: Georgia
The interesting thing about good binoviewers is that they make plossls and orthos look like Naglers and Pentaxes, while the Naglers and Pentaxes still look like Naglers and Pentaxes. 'tis a puzzlement.
ebusinesstutor
Reged: 07/01/09
I'm so glad to hear that Hank! Sounds like it would be easier on my budget.
I am actually leaning towards getting a second Hyperion 8-24 mm Click Zoom for the binoviewer since I already have one. If I bought 3 pairs of Plossls in the 8-24 range I would spend close to the price of another zoom anyway and I have the benefit of the zoom. The Hyperion Zoom FOV at lowest power is about 50 degrees. The range would give me magnifications of 240x to 80x. My only worry with the Zoom is the weight with the binoviewers plus the two zooms on my dob.
I looked at the Pleiades for the first time tonight and realized I need some lower power eyepieces as it looked better through my 9x50 finder scope than through my 24mm Click Zoom at 50x. I have a used Siebert Observatory 36mm coming, but it is only a single one.
So for the binoviewer, if I do get the second zoom, I would like some low power pieces in addition to the zoom but this is difficult to get with the 1.6x OCA.
Owl does offer a 30mm ultra wide eyepiece, but it has a FOV of 80 degrees. It is a 2" eyepiece so I would need an adapter to fit the 1.25" binoviewer. I believe you said that I shouldn't get over 65 degrees over 24mm however so maybe these won't work.
They offer 40mm and 30mm plossls at a good price with a FOV of 52 degrees so perhaps these would work well. But I did want to start getting some wider fields of view eyepieces for when I use the scopes in mono mode as well.
I will wait until the binoviewer arrives and set up the binoviewer with 1 Hyperion Click Zoom and a second click zoom of another brand. This should show me if the weight will work. If it will, I will order a second Hyperion Click Zoom and some 30mm and 40mm plossls.
If the Click Zoom won't work, I will pick up some addition plossls in the 10-25mm range.
Thanks for all your advice Hank.
Covey32
Reged: 12/09/04
Loc: Georgia
I've never tried it, but I have my doubts about using 2" eyepieces with a downshifting adapter (I don't even know who sells those), as it is almost sure to vignette very badly with the 22mm CA of the Siebert BV.
YMMV, but my experience using zooms (TV clickstops) was pretty unsatisfactory. I had a problem with matching up mags because the clickstop locations were not exact...a problem with most zooms. I would take a bit of time and get familiar with using BVs and how things actually stack up before spending too much money ahead of time. The biggest variable is the individual's eye's and how they react to merging, and this and other eye anomolies can quickly change what you actually wind up needing, or wanting.
ebusinesstutor
Reged: 07/01/09
Thanks Hank,
I was planning on waiting until the binoviewers arrived and using the eyepieces with them to see what I think I might want to add or even to see if binoviewing is right for me.
Although my wife wants to know what I want for Christmas and we would need to order soon in order to get it in time. But no rush as I could have it wait until after I get a chance to take out the binoviewers. The problem is that now till Dec is very cloudy here so it may be weeks before I can try them out after they arrive.
For the Click Zooms you were using, was the problem that the two click zooms didn't "click" in identical to each other on the same setting?
I had pretty well come to the same thought on the 2" eyepieces. I can save those for if I upgrade later to a 2" binoviewer.
ebusinesstutor
Reged: 07/01/09
Good luck
Ken
Hi Ken,
Good thought on the barlow. I do have a 2x/1.6x barlow I could use with it.
With the 1.6x OCA, the 20MMs already give me 96x. with the extra barlow, that would give me down to as low as I would likely want to go.
I am concerned about finder eyepieces and low power viewing though, so I will likely pick up some 40mm and 30mm plossl pairs for that.
teskridg
Reged: 01/15/08
Loc: PA
I guess when I said powers above 133 weren't needed, I meant that in the less expensive binoviewers higher powers were more difficult to fuse into one image. In my area, S.C. PA, seeing conditions don't frequently support much higher magnifications than this, either. Tim
CPC 800
Scopebuggy
8mm Radian
11mm Nagler
15mm GTO
30mm Vixen NPL
ebusinesstutor
Reged: 07/01/09
Thanks for explaining that Tim.
I got the binoviewers but was unable to get them to focus. So I ordered a multimag OCA from Siebert Optics.
It hasn't come yet, but this will give me 1.3x, 2x and 2.7x magnification which gives me more choices with the existing 20mm pair of eyepieces.
So the magnifications it will give me in my 8" dob are: 71x 120x 162x
So I think I have the higher magnifications all covered for the dob unless I also use it in my C80ED refractor. Then the magnifications are half that and may need one pair to pump me back up a bit.
Just likely need a couple pairs of lower magnifications now for the dob. Perhaps a pair of 40mm plossls for a magnification of 36x.
I quite like my 36mm Siebert Observatory eyepiece (single only and 2" so can't use it in the binoviewer) which gives me a magnification of about 33x so the 40mm above would come close to the same magnification plus I can use them as the initial finder eyepieces when I am locating objects.
I would really like to try it out though before I order any eyepieces so I am looking forward to the arrival of the OCA.
Plus some clear skies of course...
EdZ
Professor EdZ
Reged: 02/15/02
40mm eyepieces are not really a good match for a binoviewer. Almost without exception, the 40mm eyepiece field of view will be strongly vignetted. It starts out with a 40° Afov and gets vignetted to perhaps 35° Afov. A better selection of a finder eyepiece in a binoviewer would be a 28mm plossl which would show nearly the full 50° Afov, and almost exactly the same (if not slightly more) true field as the 40mm. A 30mm plossl will vignette but still show about the same Tfov as a 40mm.
The 2" eyepieces would be a poor choice. Any adapter to use them in a 1.25" scope would modify the fov to that of a 1.25" eyepiece, and you'd be dealing with all that extra weight that would surely cause your diagonaal some heartache.
Best eyepieces for a standard 1.25" binoviewer range between 12-14mm up to 25-28mm.
In actual drift timing tests using Burgess BV and Stellervue BV, both with and without OCS, when the OCS was in use for a refractor, a 26mm Meade 5K plossl (60°) and a 30mm Celestron Ultima (50°) both provided almost exactly the same Tfov (5 seconds time difference, the meade was 1.5% wider), and those were 9.5% and 8% wider than a 40mm TV plossl. The only real gain you get from eyepieces longer than about 26-28mm is lower power and a larger exit pupil, not a wider field of view.
Although I haven't tested it, I have used it, and I would expect the 32mm TV plossl might just give the widest achievable Tfov for a 1.25" eyepiece in a binoviewer. If it doesn't vignette any worse than these two, it's real Afov won't be any larger than that Meade 5K 26mm or that 30mm Ultima, but it will be operating at slightly lower power and may result in a wider Tfov.
For all eyepieces where the field stop is larger than the prism aperture in the binoviewer, the effective Afov is entrely dependant on the distance between the BV inside prism aperture and the field stop in the eyepiece. The closer they are, the more the fov is controlled by the diameter of the BV prism aperture rather than the eyepiece field stop. That's why the 40mm eyepieces do so poorly. The field stop in a 40mm eyepiece is almost right up at the front end of the chrome sleeve which puts it almost right on top of the BV inside prism aperture. Therefore the Tfov, instead of being a result of the 27.3mm field stop, is actually cut to 22.6mm, almost as small as the BV prism aperture.
edz
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
bcuddihee
Reged: 11/04/06
Loc: Cincinnati Ohio
For cheap thrills I'd recommend the edmund 28 rke and or the edmund 28 plossls. They are great choices for a bino. The 28 rke has long eye relief and gives an incredible illusion that the stars are floating in front of you, between the ep and your eyes. The 28 plossls are very sharp with good er. You would enjoy both. "Do not waste your money on the 0wl UWA'S OR or any of their clones. Workmanship is not so great and the er is excruciating. Another nice and inexpensive wide angle ep are the Seibert swa's, and the Smart Astronomy 19 EF's. I use the 19'S
-------------------- B Cuddihee
1968 Jason Empire 60X700mm refractor (my buddy from way back)
Celestron Nexstar8SE aka "The Bumblebee",(there is no way this scope should perform as well as it does...but it does)
Feathertouch Microfocuser
Stellarvue 50mm "Sparrowhawk" finder
Denk bino's with Power x switch
Pair of Smart Astronomy 19 EF's (great ep's for binos)
Pair of Edmund 28 plossls
Pair of Edmund 28 RKE'S
Pair of tv 20mm plossls
ebusinesstutor
Reged: 07/01/09
edz
My plan was to go for a pair of 1.25" 40mm plossls with 52 degree FOV, not 2" 40mms with a wide field of view.
I will wait for the 2" wide ones for if I upgrade to a 2" binoviewer. I might do this if I fall in love with binoviewing.
94bamf
Reged: 12/15/08
Loc: Kansas City,Mo
I would just add after trying my binoviewers in my 8 inch Dob, that they would not come to focus with anything less than my Zhumell 2x barlow lens assembly screwed on the front of the binoviewers, and that was just barely enough travel left to come to focus. The supplied 1.6x corrector that comes with the binoviewers would not even come close to focus. I would guess not all 8 inch newts are the same as far as focus travel, but you could find that your Dob is not going to focus with anything less than a 2x attachment of some kind, which actually ends up being a 2.5-3x increase anyway.. Obviously you could modify the telescope to gain focus, by moving the primary up, low profile focuser, etc, but thats more money, time, effort..
I really enjoy the binoviewers in my C6 SCT, but every other telescope I own has issues with focusing them, even with the 1.6x corrector attached. Niether refractor will reach focus without a 2x barlow/lens assembly either..
Ken
Celestron Oynx 80ED
Celestron C130 Mak
Celestron C102HD
Binoculars:
Nikon 7x35 Action
Nikon 7x50 Action
Orion 10x50 Scenix
Oberwerk 20x60
Zhumell 20x80
Moderator: EdZ, jrcrilly
