Privacy Policy |
Please read our Terms
of Service | Signup and
nickatnight
Reged: 04/14/08
Loc: Santa Clarita, CA (LA Suburbs)
Hi Folks. I shot this about a month ago somewhere between Cygnus and Cepheus I believe. The target was listed in Cartes du Ciel as an open cluster, with a description that said something like "cluster and neb, within a circle of stars." I liked the description and started shooting it, but never wrote down what it was. I've spent more than an hour or two clicking around Cartes du Ciel trying to find it again, but I can't see it anywhere.
So I'm asking if anyone can give a bit of help identifying it.
I do have the image stats, which are 32 minutes of 2 minute subs with the Canon XTi @ iso800 through the EON 72mm @ f4.8, piggybacked on the CPC925 on a Mitty wedge.
Here's a link to a big version with all the surrounds:
http://farm4.static.flickr.com/3503/4033608637_bf23c47404_o.jpg
and the small version for here. Thanks for any feedback.
nickatnight
Reged: 04/14/08
and here's a 100% crop of the tiny cluster within the circle of stars.
David Pavlich
Reged: 05/18/05
Loc: Mandeville, LA USA 30.22 X 90....
I have no clue, Nick, but because of the red nebulosity, you may have one of the Sharpless objects. I'd take note of the position you were shooting and look in the Sharpless catalog for what sits there. Just a shot in the dark, as it were. Oh yea, the image looks good, too.
David
-------------------- Proud Member; PAS NOLA,
"If we knew what we were doing, it wouldn't be called research..."
A. Einstein
waassaabee
Reged: 11/26/07
Loc: Central California Coast
If I recollect correctly, there is a group on Flickr that can take your image and give you the coordinates, and objects included in the image... that should make identifying a bit easier.
Once you find the group that is...
-------------------- Gary
34N 120W
-My kingdom for blue squares!-
WO Megrez 90FD/TV 0.8x FR/FF
AT8RC
mini Borg 50/Q-Guide/PHD
CGEM
Canon 350D Hap Griffin Baader mod - o.o
My Friend Flickr
jgibson1@emich
Reged: 06/11/06
Hey Nick,
Thats a nice shot you have there. I know for sure that the emission nebula is IC1311 in Cygnus as I have observed and imaged this before. I am not 100 percent certain of a catalog number for the cluster but the brighter star in the ring around it is HD 191944. Its a magnitude 6.96 star at about 117 parsecs distant. I will take a look at my Sky Atlas when I get home and my copy of the Sky 6 to see if it shows up with a name. Also the location of the star is 20h 10' 44.3" and +41Degrees 14' 49.3".
Good luck, Jason
jgibson1@emich
Reged: 06/11/06
FYI - If you arent aware of this online star map check it out. I love this thing and its a great tool to plan for imaging sessions. http://www.sky-map.org/?ra=20.181101354467856&de=41.4281207015867&zoom=7&show_grid=1&show_constellation_lines=1&show_constellation_boundaries=1&show_const_names=0&show_galaxies=1&img_source=DSS2
Jason
Tonk
Reged: 08/19/04
Loc: Leeds, UK, 54N
Nice ident - good job you weren't thrown by the "some where between Cygnus and Cepheus" as its smack in the middle of Cygnus
I use sky-map.org too - anyone notice if you make this particular field wider there are two dirty great aircraft induced tramlines bisecting the vista - you would have thought that imaging at the end of a runway would be a problem
-------------------- Televue 85, GM-8/Gemini, Canon 40D (unmodded), Canon 450D (modded w/Astronomiks clip-ins - UV/IR, OWB)
Coronado SM60/BF10, Baader Herschel Wedge
Leeds Sky Clock Ripon Sky Clock
Grouptele
Reged: 08/11/07
Loc: Qcy, IL
Indeed. SkyAtlas2000 shows same nebular mass and star pattern.
Nick, if you enter IC1311 in CDC you'll get the coordinates.
Victor
-------------------- C8-XLT, G5, AT66
EQ-G
Starshoot color CCD
Canon XS, HapMod
SPC900NC webcam
Nils_Lars
Reged: 01/04/08
Very nice shot , the dim glob in the ring of stars is cool.
The group that Gary is talking about is the Astrometry group on Flickr , just submit and image and they identify most stuff in it.
-------------------- Erik
Orion ED 80
Williams Optics VII reducer
Celestron 8" SCT
Orion Starshoot Autoguider
PHD guide
NexImage webcam
nickatnight
Reged: 04/14/08
Thanks for the great info. Interesting that IC 1311 shows up on searches as both a cluster and nebula. I've also now read that the core of the cluster is the little knot of stars within the circle. I checked in CDC and the description is a bit off from what i remember reading and shooting...but I think I might now be mixing up the description with something else. I really need to keep a journal.
Great link too Jason. I didn't have it before, so thanks.
-------------------- nickatnight
Celestron CPC 9.25" GPS
Lumicon 2" LumiBrite Diagonal
Meade s5000 18mm UWA, Meade 6.7mm UWA,
Parks G.S-5 10mm, Celestrom 40mm Plossl
Parks 2x Barlow, Meade Tele-Extender
Celestron f6.3 Focal Reducer
Lumicon UHC Filter and Deep Sky Filter
Canon Rebel XTi (prime)
Canon Powershot G9 (afocal)
Canon EOS T-Ring and Parks T-Adapter
Lumicon Univ DigiCam Adapter
Tonk
Reged: 08/19/04
Loc: Leeds, UK, 54N
Keep a journal!!!!!! I do and I've been able to go back and shoot star fields for some of my old comet shots. Otherwise (given that comets go all over the place) I would never find the fields again
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Yes I'll second the comment about a journal ... my memory is never good enough. Mine (when I'm smart enough to remember to use it) has even helped me diagnose imaging problems time and time again.
Low tech - spiral pad and something to write with on a string Hi tech - one of those digital voice activated recorders, they are much cheaper now than just a few years ago and are very convenient. I even know a guy who pins a lapel mic on himself, the recorder goes into his pocket for all of his observing and imaging sessions. Taking verbal notes about even just visual stuff really enhances the experience and is invaluable you're updating a written log or sketching.
-------------------- Mark
C11, C6, APM/TMB115, and AT80ED - Tandem mount CGE and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - Modded 350D, DSI-P, SPC900, Mallincam
Just because you can doesn't necessarily mean that you should
9 registered and 8 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
