Privacy Policy |
Please read our Terms
of Service | Signup and
acey
Reged: 01/09/09
I want to make a 3 point mirror cell for an 8" f6 and I would rather not use clips that intrude on the mirror.
Is there a way to do it without glue?
If I use glue, how do I remove the mirror for cleaning etc?
Ideally I'd like a set-up where the mirror is easily removable as my project is a travel scope.
This is my first ever ATM project so I'm right at the bottom of the learning curve!
Vincent Becker
Reged: 09/16/08
Loc: France
My first (and only so far) ATM project was a 8" f/6 travel scope too
I glued the mirror to the cell. To clean the mirror I simply remove the cell with the mirror still glued on it.
More on the mirror cell here:
http://www.cloudynights.com/ubbthreads/showthreaded.php/Cat/0/Number/2881245/page/0/view/collapsed/sb/5/o/all/vc/1
With a f/6 scope I strongly recommend a front-collimatable cell. It makes life much easier.
-------------------- Vincent Becker
10" dobsonian on EQ platform (home-made by my father)
8" string newtonian as travelscope (home-made by myself )
Orion 80ED and GSO 200/1000 on Atlas EQ-G for astro-imaging
acey
Reged: 01/09/09
Thanks Vincent that's really useful - the front-collimatable cell looks like a very good idea.
But my mirror is old and needs recoating - I plan on doing it once I've made the scope and know it works. So any gluing I do during construction would need to be undone as soon as the project is finished.
How would you remove the mirror from the cell for recoating? It looks like it would be a delicate operation involving a thin blade or maybe wire to get through the glue. Then presumably the removal of any residue. This is what's putting me off the glue idea. Though nor am I enamoured of diffraction- and stress-inducing clips.
Vincent Becker
Reged: 09/16/08
Loc: France
Silicon can be easily removed with a thin blade. What bothers me most is ideed the residue.
As you want to do just a try, that is just check that you can obtain an image and focus, maybe you could pake temporay clips for the try and glue the mirror once it's recoated.
Do you know how good the mirror is? Was it hand-made or is it an industrial mirror?
acey
Reged: 01/09/09
I'm using the mirror set from my Orion SkyQuest. One option would be to use the mirror cell from the scope but it only supports the mirror round its edge and I'm hoping to come up with something better. I could always use the clips from it, as you suggest, at least until I get things working.
Galaxyhunter
Reged: 01/02/06
Properly installed clip do NOT induce stress.
-------------------- Carl
My lousy skies at Hawkeye Observatory
7 registered and 2 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
