   ˇ Get a Cloudy Nights T-Shirt ˇ Submit a Review / Article
Equipment Discussions >> Classic Telescopes
akman1955
Reged: 09/07/09
Loc: Alaska, USA
Re: Jason Discoverer 454 Model 313 new [Re: dawsonian2000]
      #3407871 - 10/24/09 10:15 AM
yes but the one i bought and haven't got yet shows clearly mint in box with seperate finder on bracket. with slr is on lable on outside of box so it doesn't have flip finder. when i get it i'll investigate further, john
dawsonian2000
Reged: 07/26/06
Loc: Riverview, FL, USA
Re: Jason Discoverer 454 Model 313 new [Re: akman1955]
      #3409113 - 10/24/09 11:05 PM
Quite interesting, John.
Well, below is a link to the Jason 313's instruction manual. On the last two pages of this PDF document, it explains the workings and collimation of the SLR Finder. If your scope has the bracketed stand-alone type finder, I do not understand why the designation is labeled on the box.
Click here: => Jason 313 Instruction Manual
Mel
Clear Skies, Forever!
The Vega Sky Center
10" (254mm) F/5.65 Home Built Fork Mounted Newtonian Reflector
5" (127mm) F/9.4 Home Built Refractor (under construction)
3.5" (90mm) F/11.1 "Vixen-Spec Modified" Konus Refractor
3.1" (80mm) F/6 Scopos ED APO Refractor
4.5" (114mm) F/8 Tasco 11te-5 Newtonian (under restoration)
2.4" (60mm) F/16.7 Tasco 7te-5 Refractor
2.4" (60mm) F/15 Jason Discoverer 313 Refractor
http://www.vega-sky-center.com
armchairal
Reged: 01/05/08
      #3409997 - 10/25/09 01:40 PM
Mel
Mel I tried your link and not getting anything,, maybe just my comp,
Al
Al
12"er some EPs and filters
dawsonian2000
Reged: 07/26/06
Re: Jason Discoverer 454 Model 313 new [Re: armchairal]
      #3410911 - 10/25/09 09:55 PM
Hi Al,
You probably don't have a PDF reader installed. You can download and install AcroReader from this link => AcroReader Download Site . If you do not want the McAfee software, just uncheck it. Once AcroReader is installed, you can click on the previous link again and it should open.
Mel
The Vega Sky Center
aa5te
Genial Procrastinator
Reged: 08/30/08
Loc: Clinton, TN
Re: Jason Discoverer 454 Model 313 new [Re: aa5te]
      #3413625 - 10/27/09 08:56 AM
After some more testing, I'm pretty sure my Jason 60mm beats my Sears 80mm - both in FOV and image clarity. The Jason TFOV is 1.25°; the Sears measures in at 0.97°. The Pleiades, the Double Cluster, and Jupiter all looked a little better/sharper in the Jason scope, and the Ring Nebula was just as bright in the Jason. I split Epsilon Lyrae in both, and I was a little better with the split in the Jason scope. The Jason also seems to "snap" to focus better on most objects. Not bad at all...
Shane
Binos: Apogee 25x100 / Burgess Optical 25x100 / Pentax 20x60 PCF WP / Tasco InFocus 10x50
Tripods: Sunpak PlatinumPlus Ultra 7500TM / Quickset Samson
Refractors: Meade DS-2102AT-TC 102mm f/7.8; Sears Discoverer 3 (4454) 80mm f/15; Jason 313 Discoverer 60mm f/15.2
Reflectors (Dob): Hardin Optical DSH10 10" f/5
EP's: Zoom: Zhumell 8-24mm & Circle K 7.5-22.5mm 0.965"; 9-52mm Plössls; Zhumell 2x barlow
Kodak Z760; Orion SteadyPix camera mount; Orion LaserMate Deluxe Collimator
dawsonian2000
Reged: 07/26/06
      #3415370 - 10/28/09 02:01 AM
Congratulations aa5te!
I always looked forward to other amateurs conveying the true attributes of the underrated Jason 313, and you are now a proponent to that belief. But, I am quite surprised it whipped up on the Sears 80mm a bit! What eyepieces did you use?
Mel
The Vega Sky Center
aa5te
Reged: 08/30/08
Loc: Clinton, TN
      #3415550 - 10/28/09 07:13 AM
I used the same 0.965" to 1.25" diagonal adapter with these eyepieces/barlow:
Zhumell 32mm Plossl
Zhumell 8-24mm zoom
Meade 9.7mm Super Plossl
Zhumell 2x barlow
and I also used the Circle K 0.965" 7.5-22.5mm zoom
What really surprised me is that M57 in the Jason seemed every bit as bright as it did in the Sears (60mm vs. 80mm).
One negative though - the SLR finder on the Jason is dimmer and harder to use that the attached finder on the Sears (it is aligned, though).
akman1955
Reged: 09/07/09
Loc: Alaska, USA
Re: Jason Discoverer 454 Model 313 [Re: akman1955]
      #3417306 - 10/28/09 11:22 PM
I recieved the scope in allmost mint condition and could have swore the pictures on ebay listing showed telescope with seperate finder. The one I got is exactly like you said a SLR should be. With the flip focuser...nice scope and mount with all accesary's. Sorry for confusion but seller must have posted wrong pictures then changed them later i guess. thanks,john
BianchiAZ
Reged: 01/04/08
Loc: Fraser, Michigan
      #3462187 - 11/22/09 01:11 PM
Hello again. Well I finally have my new camera and I took some pics this morning of my Jason telescope.
Right after i purchased the Jason it was cloudy almost every night for a few weeks. I was able to do some viewing with it recently though and I must say I like the telescope very much.
First light was very good. I observed the Moon, Jupiter, Pleiades, Cassiopeia areas on interest, and Orion. The telescope performed very well. Stars are very crisp points of light going to the edge of the field of view. I thought the stock eyepieces performed very good. The moon looked great as I could see peaks of mountains while taking advantage of the waning cycle. Looking into the craters depths was not a problem either on the edge of the shadows. I was surprised that I had pretty good seeing at 227 magnification. Though the image was washed washed over a bit I could still make out what I was looking at with definite detail of craters and peaks at the edge of the terminator. The mount was a little nervous at this magnification but I was smiling the whole time.
Jupiter looked very crisp and viewing the planets detail was not a problem. I was not able to make out the great red spot though.
Well here are some pictures of my scope that has been in a box since 1982.
Original Paperwork !
The Telescope ...
And that's it....
Edited by BianchiAZ (11/22/09 02:13 PM)
aa5te
Reged: 08/30/08
Loc: Clinton, TN
Re: Jason Discoverer 454 Model 313 new [Re: BianchiAZ]
      #3462238 - 11/22/09 01:46 PM
Wow man, that scope is in excellent shape. Thanks for those pics. I really like my 313 a lot.
Shane
akman1955
Reged: 09/07/09
Loc: Alaska, USA
      #3462316 - 11/22/09 02:51 PM
Nice scope! just like mine. i'll have too check mark on label too see if circle T. Haven't had chance too use yet as been too cold out. Thanks for report on how it works. glad your happy with it john
9 registered and 3 anonymous users are browsing this forum.
Moderator:  RLTYS, Glassthrower, Clive Gibbons
