Privacy Policy |
Please read our Terms
of Service | Signup and
X-Lurker
Underpaid Slacker
Reged: 09/12/06
Loc: N.W. Ark.
Hey all, I just recently built a permanent pier and I want to keep my EQ-6 mounted on it for polar alignment purposes (Astro Imaging). I've been using visqueen, trash bags, t-shirts, cotton beach towels and what not to keep it dry, but I'm running into condensation(sweating)issues. I will eventually frame a observatory over it, but that will be some time later and I'm afraid I'll end up destroying an expensive mount if I don't do something soon. Does any body have solutions they would like to share?
Thank you,
-------------------- Clear Skies,
Larry
I wasn't sick...I just called in uninterested
Glob
AOAS Member
10" Reflector (Cloud Magnet)
AT66ED
EQ-G (Powered by EQMOD)
Orion SVP 127
DSIc
SPC 900NC
Cloud Filter (On Order)
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
Telegizmos 365
Hubert
www.smoggybottom.org
Luigi
Reged: 07/03/07
Loc: MA
Put a cover over it that doesn't touch the mount itself and is open at the bottom for ventilation. The cover will get wet, perhaps on the inside too, but the mount won't. An inverted plastic trashcan or similar can work well.
-------------------- 17.5" f/5 Dob. IM-715 MCT. 120ED. Lunt 60mm Ha.
Zeiss, Leica, Fujinon, Nikon, Pentax, Bushnell bins
X-Lurker
Underpaid Slacker
Reged: 09/12/06
Loc: N.W. Ark.
OK I took Luigi's advice and ran down to our local big box store and purchased not one, but two trash cans...
I have another question for you Guru's.
Should I drape some kind of material over the mount to help keep the moisture or dust off?
Larry
Glob
AOAS Member
AT66ED
Orion SVP 127
DSIc
SPC 900NC
bbbriggs
Reged: 04/10/09
You might want to run an extension chord out to it and keep a small 20W light bulb burning. That is a really nice mount and certainly worth protecting.
-------------------- 18" reflector
14.5" reflector
televue ranger
denk II power x 14's and 21's
20x110 binoculars
16x70 binoculars
31,17,9 nagles
timo4352
Reged: 04/16/07
Loc: Northeast Ohio
Now how about cutting yourself a nice plywood ring to fit the top of the lower can for a nifty eyepiece holder.  Tim
-------------------- Orion 3.6CA Reflector
and 2 homebrew scopes --
8" Hubble Bubble ballscope
8" F/8 CHief - nearing completion
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
I like the trash can solution. But it would probably be a good idea to cover the mount with a black plastic trashbag, tied securely around the bottom, just in case the upper trash can blows off.
X-Lurker
Underpaid Slacker
Reged: 09/12/06
Loc: N.W. Ark.
I do plan to use bungie cords or something to hold both cans down, but I kind of got into watching some of todays games and enjoyed a few of my favorite beverages... I have a big rock on top of it for now.
Larry
Glob
AOAS Member
AT66ED
Orion SVP 127
DSIc
SPC 900NC
X-Lurker
Underpaid Slacker
Reged: 09/12/06
Loc: N.W. Ark.
Here is my "Rubbermaid Observatory AKA the Rubber Dome" completeted. 30hrs. of non-stop rain and no moisture to be found! I also have 1250 grams of desiccant on it's way, just in case...
Larry
Glob
AOAS Member
AT66ED
Orion SVP 127
DSIc
SPC 900NC
4 registered and 11 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
