Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
This might be almost the last Jupiters, still processing and working on techniques. Can't wait for Mars...
Freddy WILLEMS
Reged: 11/13/05
a few minutes later...
Learned again that the histogram is very important while capturing...
-------------------- Freddy
Meade 14" LX200 GPS UHTC GPS on permanent pier
Celestron C 14" Peltier cooled for planetary imaging.
Meade 10" LX200 & TITAN 50:1 mount Gemini 'go to'
Meade 127 mm f/9 APO & TITAN 50:1 mount Gemini 'go to'
W/O 102 mm f/7 APO doublet
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
Canon 10D Unmoddified
Canon 40D Hutech moddified
Edited by Freddy WILLEMS (10/28/09 05:18 AM)
Dean Norris
Reged: 11/05/08
Loc: Santa Cruz, Ca
Freddy, Great image of Jupiter. You can see the dark spot in the STRz that has recently appeared. I viewed it the other night in my scope and made a sketch. It's great to see this object in your image. I also saw the dark patch up above the spot as well in the STZ. It will be interesting to compare your image to my sketch. This dark spot resembles a shadow of a moon. It was brought to my attention by John Sabia's post the other day in the Planetary Solar System observing Forum. I hope you have clear steady skies ahead. Dean
-------------------- 1971 10" Cave Newtonian F/6
MoonLite CR Focuser Telrad Finder 8x50 finder
TV 40mm, 32, 20, 7.4, Meade 6mm, UO 5mm, Meade 2x Barlow
7x50 Binoculars
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Nice work Freddy. That 90 degree angle artifact is a bit perplexing. I see it in both, but more profound in the second.
-------------------- Mars Watch
All images taken with:
Celestron CPC 1100
DBK 21AF04.AS
K3ccd/Registax4/PSP8/Maxim DL IP
ALPO Member #4287
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
Yes, these are nice images Freddy, every time a bit better, way to go! Maybe Joel, that line is due to the Do-all button, not pressed before saving in Registax?? Happens sometimes to me as well
Mert
42º49"N 1º38"W
3" Polarex refractor
6" F12 SW Maksutov,CS2-S
EQ6 + EQMOD
SPC900NC/DFK21AU04.AS
My web-page don't laugh, I should make it better!
Freddy WILLEMS
Reged: 11/13/05
Thanks Lunatiki, must be some dust, will clean the camera again.
Thanks Mert, yep 'do all' button again....
Go to fast sometimes....
Dean I will take a close look at that spot...
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
4 registered and 7 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
