Privacy Policy |
Please read our Terms
of Service | Signup and
guyroch
Reged: 01/22/08
Loc: Ottawa, Canada
I'm currently in the process of building a dark library. But I've been questioning myself as to how many darks should I take for each set of different iso/duration/temperature in 10 degrees increment? I had my mind set on 25 darks for each set but I’m not sure if this is too much. How many darks to you take before you start to loose efficiency to the point where additional darks won’t necessarily add more value?
-------------------- Skywatcher 750mm 6" Reflector f/5
Celestron CG5-GT mount
Orion ST80 + SSAG autoguider + PHD
Canon 40D (unmod) + TC-80N3 remote timer
Astronomik CLS clip filter
Orion SkyGlow light polution filter
Orion AccuFocus + homemade Bahtinov mask
Bushnell 8x42 h2o® Waterproof Binoculars
Sky Atlas 2000.0 Field Version (Laminated)
Plenty of patience and a wife that doesn’t quite understand my love for clear skies, but let’s me go out anyway ~ thanks honey bunny
Psyire
Reged: 06/24/07
Loc: 55* North
There is a good thread around here somewhere discussing this.. I can't remember exactly what was said but I do know that after reading it I settled on the number 30. Perhaps someone can explain it better, lol..
-------------------- Celestron CPC 1100 XLT, Sky-Watcher Equinox 80ED
TV 31T5-Nagler, 8&13mm-Ethos
EarthWin Binoviewers w/ 24mm Panoptics
Elusive Photons.com
Jerry Lodriguss
Vendor
Reged: 07/19/08
Loc: Voorhees, NJ
If you're going to shoot darks on a cloudy night in your garage, just shoot all night long and put as many as you can into your master dark.
On some, I have up to 64 sub-darks in my master dark.
As a very very general rule of thumb, 9 darks would be an absolute minimu. 16 is better, but really as many as possible. The improvement goes up with the square root of the total number... in other words, 16 gives you a 4x improvement over 1 single frame, 64 gives you an 8x improvement.
Jerry
-------------------- A Beginner's Guide to DSLR Astrophotography
http://www.astropix.com
guyroch
Reged: 01/22/08
Loc: Ottawa, Canada
Thanks Psyire, I believe the thread you are refering to is this one.
Jeff in Austin
Reged: 02/26/07
Loc: TEXAS
I'm running 40 darks a night in my garage...It's interesting, the first few look different than the rest, so I throw them out. I believe the camera warms up and reaches equilibrium after the first few shots.
-------------------- There's nothing like having a supportive family, including Second Grader w/ scope, curious toddler, and lovely wife.
Supporter of Austin CSC, Austin CalSky.
guyroch
Reged: 01/22/08
Loc: Ottawa, Canada
Jerry, I know from reading other threads that you've been using the same master darks since 2005 and have been very successful doing so.
In the thread link above you say the following
Using bias frames will allow you to scale your darks. This means if you shoot 10 minute darks, you can use them to calibrate shorter exposures taken at the same nominal temperature and the same ISO. This saves a lot of work. You certainly don't need one for every 30 second increment.
How do you calibrate your darks using bias frames? Is this something Image Plus does automatically for you?
I'm using Nebulosity2 for acquisition and stacking and it does have an autoscaling dark feature but it's documentation clearly indicates that if you are using darks you should not use bias as the dark already contains the bias error, so the bias error will actually be removed twice, therefore adding noise.
However, Nubulosity2 has a feature called Bad Pixel Mapping which allows to use the same dark for different exposure time as long as the dark duration is of longer duration as the light frames. With BPM however, bias frames should be used.
guyroch
Reged: 01/22/08
Loc: Ottawa, Canada
Good to know, it never occurred to me to check the consistency. Thanks.
stevecoe
"Astronomical Tourist"
Reged: 04/24/04
Loc: Arizona, USA
A beginners question: must the darks always be the same exposure time and ISO as the images of the object? Just wondering if I can shorten the time compared to the actual exposure.
Thanks; Steve Coe
-------------------- TeleVue 102 refractor on CGEM mount
10 inch f/4.7 Newtonian
Author "Deep Sky Observing" Springer-Verlag
Author "Nebulae and How to Observe Them" Springer
Canon Xt astrocamera with Hutech modification
Jerry Lodriguss
Vendor
Reged: 07/19/08
Loc: Voorhees, NJ
Images Plus does it if you just check the box that says "automatic master dark frame matching".
Yes, there is bias contained in the darks, so you don't want to subtract the bias twice, but to you need bias frames to scale darks.
I'm sorry, I can't help you with Nebulosity.
Jerry
guyroch
Reged: 01/22/08
Loc: Ottawa, Canada
Thanks; Steve Coe
ISO Yes. For duration it depends on the software you use for sacking. If your software has an "autoscale dark" feature then duration is not as important as long as your dark is longer than your lights. Darks are also temperature sensitive but you can do just fine with darks within 5 degrees of your lights IF you use autoscale dark, otherwise temperature should be the same as your lights.
guyroch
Reged: 01/22/08
Loc: Ottawa, Canada
Jerry
Thanks Jerry, I will follow the 'letter of the law' as per Nebulisity's documentation and not prodive BIAS frames initially. If I'm unsatisfied, I'll shoot a bias library, It will only take a few minutes anyway and compare the results with and without bias.
Much appreciated.
8 registered and 7 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
