donsinger1
Reged: 10/28/07
CGE Question
      #3419340 - 10/29/09 11:16 PM
It appears from pictures that the the tripod that comes with the CGE has a pier at the top that houses electronic connections, so how does one attach the mount head to a permanent pier on my porch if it does not have the electronics?
Also, how much does the mount head weigh?
Don
Also,
Fun Stuff:)
Portland, OR
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: CGE Question new [Re: donsinger1]
      #3419351 - 10/29/09 11:22 PM
The electronics "pier" is just a cylinder. It attaches to the tripod head, but you can attach it to a pier plate also. It's the same as a G11 but the opposite sex.
John C
Urban Observatory
A&M/Astreya 76mm F/6 APO
TMB/LOMO 80mm F/7.5 APO
Tak FSQ-106N F/5 APO
Meade 178ED F/9 "APO"
Meade ETX-125AT
C14
Teeter 20" F/3.8 truss Newt w/ServoCat
NJP, GPDX/SS2KPC, CG5-GT
ST-10XME, DSI Pro
AlanT
Reged: 08/20/07
Loc: 122º36' W, 47º37' N, WA USA
Re: CGE Question new [Re: jrcrilly]
      #3419812 - 10/30/09 09:37 AM
The head weighs about 45 lbs. The electronics pier is very light, guess at maybe 3 lbs.
Are you thinking of mounting just the head and repackaging the electronics? If so, then you'd just have to mimic the top of the electronics cylinder. Like John said it's like a losmandy. If I recall, the Cylinder ID is 5.5" (I'd have to measure again to be sure), with a little over 1" of clear bore where the head fits in, and 3 equally spaced clearance holes on the OD for the 3/8"-16 bolts that hold the head.
al
al
Meade 80mm APO
Celestron 6" SCT
CGE, GM-8, & CG-5 GT
ST-2000xcm, DSI Pro II, DSI Pro
( www.alberts-astro.com/astro )
CounterWeight
Reged: 10/05/08
Loc: PDX chronoplast
Re: CGE Question new [Re: AlanT]
      #3427141 - 11/03/09 10:37 AM Attachment (7 downloads)
Don,
I'm not sure I understand the question. Here is an image showing the CGE base (not on the pier)...
CGE (Frankenmount mod.)
Onyx 80ED, Tak FS-128 #02058, TEC APO160ED #030
CCD: Orion SSPDSCIv2, SSI3, SSAG
diags, ep's, tubes, filters, Binocs
My CN Image Gallery
Experience is a difficult teacher, it gives the test first, and gives the lesson later
CounterWeight
Reged: 10/05/08
Re: CGE Question new [Re: CounterWeight]
      #3427147 - 11/03/09 10:42 AM
I think the lower orange portion is to adapt to the electroncs pier and could be done without if you are machining your own plate.
My CN Image Gallery
9 registered and 11 anonymous users are browsing this forum.
