Prof M
Reged: 07/26/09
Loc: Southwest Utah
Modified 40D?
      #3419454 - 10/30/09 12:48 AM
I have a Canon 40D and have noticed a number of posts where the camera was referred to as a "modified" 40D. Just how is a 40D (or any DSLR) modified for astrophotography?
JSeay86
Reged: 04/26/09
Loc: Norman, OK
Re: Modified 40D? new [Re: Prof M]
      #3419492 - 10/30/09 01:34 AM
These cameras come stock with an IR blocking filter. This blocks Hydrogen-alpha emissions which are common in many nebula. Modified means they removed this filter and replaced it. See here for more
Jared
Orion XX12 Dob
Ten Acre Observatory
Edited by JSeay86 (10/30/09 01:35 AM)
Prof M
Reged: 07/26/09
Loc: Southwest Utah
Re: Modified 40D? new [Re: JSeay86]
      #3424078 - 11/01/09 04:37 PM
Thanks for the information, Jared. Very helpful link.
Keith
nofxrx
Vendor (HyperCams & Mods)
Reged: 07/12/05
Loc: Palm Bay,Florida
      #3424483 - 11/01/09 08:39 PM
It is not entirely correct to say that the stock filters block IR only.The filters that you replace the stock filter with is an "IR Block Filter" made by Baader(this is the most widely used,accepted filter for AP use since it opens your sensor up to the entire spectrum,while blocking only IR,and it is the same thickness as the stock filter,which means that the AF on your cam will work as perfectly as it did before the mod)..
Infact the stock filters block alot more than just IR:
They block everything below ~400nm,and everything above ~650-700nm(granted that is the majority of wavelengths that we use anyways..lol)..but they also block a certain level of each wavelength in between those lines.This is to keep the sensor's "view" the same as our "white light evolved receptors/cells" in our eyes..
You gain so much from removing those stock filters for AP use that it really doesnt make sense NOT to.In fact,with all the technology today,with things like a custom white balance,"stock replicating filter" like the X-nite CC1 Filter,you can still use your expensive camera for all the daytime imaging you want with absolutely no hinderance in performance.
So,my point is simply,if you are interested in doing DSLR AP,think about modding your cam,or having someone do it for you(like the link to Hap's service.although,there are a ton of "one man shows" that also do these mods for much cheaper) .There are plenty of instructional tutorials online for just about every model Canon and Nikon out there..
But,go with a Canon.They are the absolute best performers for AP.period.
Hope this helps....
CS!
Brent Oliver
WO-66SD*WO-Megrez102ED-Special Edition*Super C8 Plus*
CGE Pier-Mounted
Some Cameras,some Filters
HyperCams&MODS
My Gallery
JSeay86
Reged: 04/26/09
Loc: Norman, OK
Re: Modified 40D? new [Re: nofxrx]
      #3424816 - 11/02/09 12:25 AM
Brent, thanks for clearing that up, your post was very informative!
Jared
Orion XX12 Dob
Edited by JSeay86 (11/02/09 12:30 AM)
supercoolone
Reged: 07/25/07
      #3442789 - 11/11/09 08:08 PM
Please have a look at the following:
http://astrosurf.com/buil/baader/eval_us.htm
This is from the creator of IRIS, I believe, it posts spectral shots with/without IR cut filter.
one more page related to filters
http://astrosurf.com/buil/filters/curves.htm#Protocol
Edited by supercoolone (11/11/09 08:21 PM)
nofxrx
Reged: 07/12/05
Re: Modified 40D? new [Re: supercoolone]
      #3442972 - 11/11/09 10:06 PM
Jared,
Not a problem..I am just glad it was useful to someone
I have been modding cams for ~4 years.First my my brand new Nikon D50(same sensor as the QHY8,SX-MX25C,etc)..
It was so much fun modding that I decided I wanted to do it again...and again,and again....
Prof M,
Try to look at it like this..:
You can start out using the cam unmodded and get "aquainted"/the swing of things..then,once you are ready to take the next step,get your cam Modded..
Or,you can start out with the modded cam,and the only thing holding the progress of your imaging back is your own lack of experience...which,that comes pretty quickly and with images that you are proud of(thanks to the amount of signal in the modded cam) it also encourages your progress..
Good luck. I sent you a PM...
CS!
Brent Oliver
CGE Pier-Mounted
HyperCams&MODS
My Gallery
14 registered and 7 anonymous users are browsing this forum.
