Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Well I certainly needed to get a handle on the movement of the AT 8" F4 mounted on the EZT. I found myself either grabbing the front or rear of the OTA to move it around. If I did this, I would see heat from my hand in the FOV...a little irritating to say the least.
So I headed to the shop with a handle idea and came up with this...
-------------------- Equipment Overload!
Kerry
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
The 16" long by 1/2" round aluminum rod was mated to a 5" piece of 1" hex aluminum for the handle. Not sure if anyone has done anything similar or not, but I would have to think that on this site, there are atleast a few examples being implemented. It is attached to the rings with a couple of metric stainless allen head screws and some press on knobs to match.
Kerry
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Something a little different was the contact point on the rings. I machined two recesses in the alum. rod so it would fit on the face of the ring base better and not want to "roll" around if the screws got a little loose during a viewing. This is a shot of the middle of the handle rod and the end has the same.
Kerry
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Overall length is 20". Moving the scope around on the EZT has made a huge difference. With the handle a little past the end of the OTA, helps give a little extra torque. I also put a few degrees of bend in it so my hand won't hit or touch the side of the OTA.
Kerry
rboe
Reged: 03/16/02
Loc: Phx, AZ
So how do you like it? Does it give you the fine leverage you need? Hope so as I like the way it does not stick out - pretty darn slick.
-------------------- Ron
NS11GPS
Pronto
16" dob
15X70 Obies
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Thanks Ron. I made a smaller (shorter) handle at first and though it was good, but by extending it about 4 more inches, made a world of difference. Even the wife thought it was great for moving the scope around. It does stick out a little, (only 2.5") but since the handle can be removed easily this won't be a problem.
Kerry
jayscheuerle
Reged: 01/16/06
Loc: S. Philadelphia, PA
Kerry, I used a .5" straight section mounted the same way for my old 80mm Vixen. Never as elegant as yours (again), but...
StickŪ
- j
-------------------- Fight indignorance!
The Green Goblin - 12" of dobsonian excellence!
The PortaBowl-a $100 4.5" f/8 ball-scope YOU can build!
Eero2-a 6" f/5 ball-scope you probably can't.
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Thanks Jay, do you have a photo you could post? I'd like to see what others have come up with design wise.
Kerry
jayscheuerle
Reged: 01/16/06
"Design"? This was an axle I used for wheels on my old XT8! (I did file two flat spots). I ended up replacing it with one of Manny Miles' "Pan-handles" - j
square_peg
Reged: 03/26/04
Loc: Maple Valley, WA
OK. Now I see why we stopped for those knobs. Slick little handle, Kerry.
-------------------- Tom (Pegster)
DSH-8 (GSO Dob)
15x70 Oberwerks
SVP/ED80
WO 66 Petzval
Sears Discoverer EQ 60/900
8x42 Regals
History is Philosophy teaching by examples.
Thucydides
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
Uh-ooo, you're finding my local ATM supply hot spots.
Kerry
