mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Ham.....I'd take and dab the entire area with vaseline. Then lay it face down on clean card board and spray away. When the paint dries simply wipe the vaseline off along with any overspray or leakage of paint underneath. Or spray it right side up. Mike
-------------------- 7x35 and 10x50 sears tower binocs, 3" f/10 edmunds reflector, 2.4" f/11.7 manon refractor, 6" f/8 jaegers refractor, "The 8 Ball" 8" f/13.3 brandt refractor, 3" f/15.8 sans&streiffe refractor, 3.1" f/15 selsi refractor(towa 339), 2.4" f/15 sears refractor, selsi 30x30mm spyglass, criterion 5-draw 25x45x75x spyglass(1957), 4.25" f/14.8 tasco 20te.
deSitter
Reged: 12/09/04
Hi folks.. I finally got around to taking a couple of pictures now that I am all done. The only thing I would like to do yet is paint the actual objective holder, but I can't think of a way to keep the white writing that shows the objective size and focal length which is in white..How would one go about making a dew shield instead of painting? Outside of that all seems to be well with the scope.
Painting recessed lettering is very easy if you use good quality smooth black paint as the base and let it dry a long time - use white Latex applied with a damp cloth - it goes right into the lettering and you just wipe off the excess.
It's a pretty little scope, very Japanese looking, like an early Tak or Vixen.
-drl
deSitter
Reged: 12/09/04
The dew shield can be made from a length of aluminum tubing with self-adhesive felt bumpers of sufficient thickness to grab the outer rim of the objective cell. Check with Hastings to start.
-drl
dawsonian2000
Reged: 07/26/06
Loc: Riverview, FL, USA
Hi Ham Radio,
Your 80mm looks fantastic! As for painting the objective cell without covering the white lens specs lettering, you could apply Painter's Tape over the entire flat surface where the lens specs are locate, then trimming the access with a sharp utensil. Doe the surface with the specs need painting as well? If parts of this surface needs painting, you could just mask the objective specs and any other surface area with the painter's tape before painting; this includes the threads. Please post a photo of the lens cell so I/ we can make a better determination.
As for a dew shield, you can use a section of PVC or aluminum tubing. Was the original dew shield of the screw-on, slide-on type?
Mel
-------------------- Clear Skies, Forever!
The Vega Sky Center
10" (254mm) F/5.65 Home Built Fork Mounted Newtonian Reflector
5" (127mm) F/9.4 Home Built Refractor (under construction)
3.5" (90mm) F/11.1 "Vixen-Spec Modified" Konus Refractor
3.1" (80mm) F/6 Scopos ED APO Refractor
4.5" (114mm) F/8 Tasco 11te-5 Newtonian (under restoration)
2.4" (60mm) F/16.7 Tasco 7te-5 Refractor
2.4" (60mm) F/15 Jason Discoverer 313 Refractor
http://www.vega-sky-center.com
Edited by dawsonian2000 (10/26/09 09:49 AM)
Ham Radio
Reged: 09/18/09
Loc: Hampton, Mn
The only reason I was thinking of painting it is the fact that the gray color is slightly darker than the rest of the gray paint. I am beginning to think maybe a dew shield might be a better way to go. It didn't have one when I got it. It would be a slide on type.
Bonco
Reged: 04/17/06
Loc: Florida
Following advice on this thread I sent My Towa model 339 lens cell and damaged lens to Sheldon for replacement. If the Carton lens lives up to its reputaion, I'll have a fine 80mm f/15. Bill
-------------------- RV6
Meade 2045
6 inch f/4 RFT R. Fagin Optics
TV Genesis
2.4 inch Lafayette Equitorial
3 inch Polarex/Unitron Equitorial
10 inch Zhumell
PST 40mm Solar scope
4 inch F/15 Antares
2.4 inch Unitron Equitorial
Tasco 10K 80mm/1200mm
Towa 339 Restored
dawsonian2000
Reged: 07/26/06
I understand, Ham Radio. A dew shield is a must. Just make certain to flock it well with flocking material (such as adhesive felt, or Protostar flocking paper), or with flat black enamel.
Mel
The Vega Sky Center
Bonco
Reged: 04/17/06
Loc: Florida
Sent my Towa 80mm cell to Sheldon to have him install a Carton lens. I'll post results once I test it. Cheers, Bill
Meade 2045
TV Genesis
10 inch Zhumell
4 inch F/15 Antares
Towa 339 Restored
Doug76
Reged: 12/05/07
Loc: SE Louisiana, future Texan
Following advice on this thread I sent My Towa model 339 lens cell and damaged lens to Sheldon for replacement. If the Carton lens lives up to its reputation, I'll have a fine 80mm f/15. Bill
It will, trust me.
I recently changed out my Towa 60mm f/11.7 lens for a Carton equivalent (supplied by Sheldon), and find a subtle but noticeable improvement in the view. Stars are more pinpoint, and the background seems darker.
-------------------- Doug
Truckstop Astronomer
The Universe, the light of God, in all it's majesty
6 achro refractors 50mm-150mm
1 apo refractor 90mm
1 SCT 8inch
UO Abbe Volcano Tops
Faworski Ortho's
Panoptic 24mm
Ham Radio
Reged: 09/18/09
Loc: Hampton, Mn
I want to thank everyone who has helped me out with this scope. I have just acquired a Tasco 15TE and the CFO of the household says something will have to go. If anyone is interested in this scope please get with me. I am only looking to get back what I have into the scope.
Bonco
Reged: 04/17/06
Loc: Florida
Installed the lens on my Tasco tube as I'm refurbishing the Towa tube. All I can say is the Carton lens is impressive. Great color control, contrast, and sharpness. It's exceeded my expectations and I plan to get many years of enjoyment using it. I think it on par and maybe better than the outstanding Polarex 76mm that I own. I'm looking forward to doing a comparo. Thanks for the advice to buy this lens. Bill
Meade 2045
TV Genesis
10 inch Zhumell
4 inch F/15 Antares
Towa 339 Restored
dawsonian2000
Reged: 07/26/06
Congrats, Bill! As I continue to read the merits of the Carton objective, everyone's comments makes me want to build one myself. I look forward to reading your comparison on your Carton versus the Polarex.
Mel
The Vega Sky Center
Bonco
Reged: 04/17/06
Loc: Florida
Well, Just sent my Tasco lens and cell to Sheldon for replacement. The Tasco lens is ok but not in the same class of the Carton lens he recently sent me. This could be for several reasons and I've asked Sheldon to comment on it. 1) Could be assembled improperly 2)Might need foil spacers. 3) might not be original which is probably impossible to say. Anyway once I'm done with this project I'll have two 80mm/F15's that optically will likely stand up to any comparo of similar Achro's. If they perform the same I'll toss a coin and offer one of them for sale at a good price. Cheers, Bill
Meade 2045
TV Genesis
10 inch Zhumell
4 inch F/15 Antares
Towa 339 Restored
dawsonian2000
Reged: 07/26/06
Hey Bill,
Have you had the opportunity to compare the Tasco and Carton objectives?
Mel
The Vega Sky Center
Bonco
Reged: 04/17/06
Loc: Florida
Hey Bill,
Yes I have compared them and the Carton is way superior in contrast, sharpness and dark field when viewing Jupiter. Very noticable difference. So I'm replacing the Tasco lens with another Carton. However, it's possible that the Tasco lens could be tweeked into better performance. Also it's possible the lens in the Tasco is not original. Based on many reports I've read the Tasco and Towa lenses can be excellent. I've asked Sheldon to help me evaluate the Tasco lens, hey maybe all it needs is spacers. We'll see.
Mel
Meade 2045
TV Genesis
10 inch Zhumell
4 inch F/15 Antares
Towa 339 Restored
