astrosharp
Reged: 06/24/08
Jupiter from Barbados - Lots more images new
      #3419613 - 10/30/09 05:04 AM
Hi all,
At last I have found enough time to prepare some more Jupiter images taken from Barbados. Work has been so busy recently I have not found the energy to process them as quickly as I hoped.
I have posted 3 more nights of images: 5/6th, 6/7th and 7/8th September 2009; a total of 26 more images (there are over 40 images available now). There is one web-page per day; the links to these pages are at the end of this main page:
Main Barbados Page
Individual page links are:
5th/6th:
http://www.astro-sharp.com/jupiter2009barbados4.asp
6th/7th:
http://www.astro-sharp.com/jupiter2009barbados5.asp
7th/8th:
http://www.astro-sharp.com/jupiter2009barbados6.asp
Also, Dave Tyler reprocessed one of my images in a 'softer' style, the question is should I reprocess all of mine to this style? I think I may have gone too 'harsh'. Here is Dave's version:
http://www.astro-sharp.com/images/jupiter2009barbados/dave-tyler-processed.jpg
Best Regards
Ian
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Re: Jupiter from Barbados - Lots more images new [Re: astrosharp]
      #3419615 - 10/30/09 05:11 AM
Really outstanding Ian !!
Should make a nice Gif !
Freddy
Freddy
Meade 14" LX200 GPS UHTC GPS on permanent pier
Celestron C 14" Peltier cooled for planetary imaging.
Meade 10" LX200 & TITAN 50:1 mount Gemini 'go to'
Meade 127 mm f/9 APO & TITAN 50:1 mount Gemini 'go to'
W/O 102 mm f/7 APO doublet
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
Canon 10D Unmoddified
Canon 40D Hutech moddified
Max Lattanzi
Reged: 06/27/07
      #3419642 - 10/30/09 06:19 AM
... in a 'softer' style, the question is should I reprocess all of mine to this style?
Hi Ian,
Truly excellent shots...!
If I were you, I would indeed give it a try with a couple of Sept.8, beginning of session and around 3 UT. They look like the sharpest you have.
Then you can make up your mind.
Could you pls post somewhere a 10-20 sec movie of the actual source to have a glimpse of the Barbados skies..?!
You decide the channel and the moment. BW of course... I mean, exactly what the scope saw.
Thank you so much and again congratulations!
Max
astrosharp
Reged: 06/24/08
Re: Jupiter from Barbados - Lots more images new [Re: Max Lattanzi]
      #3419663 - 10/30/09 06:46 AM
Hi Max,
I guess you missed this thread a while back:
http://www.cloudynights.com/ubbthreads/showflat.php?Cat=&Board=Imaging&Number=3351009&Forum=f57&Words=&Searchpage=0&Limit=25&Main=3348436&Search=true&where=bodysub&Name=47928&daterange=1&newerval=10&newertype=w&olderval=&oldertype=&bodyprev=#Post3351009
It contains a link to a 500 frame green AVI you can download and play with.
Cheers
Ian.
Erik Bakker
Reged: 08/10/06
Loc: Haren, The Netherlands, Europe
      #3419709 - 10/30/09 08:01 AM
Hi Ian,
Absolutely astonishing pictures. Inspiring and helped me identifying what I observed visually in my Q7 under very good conditions in that period.
Clear skies,
Erik
Visual astronomer, main instruments:
Fully mounted Questar 7 P-BB
Celestron C 102F f/8.8 fluorite
Vixen FL 70S f/8 fluorite
Celestron C 55F f/8 fluorite
Sets of Zeiss, TeleVue and Brandon eyepieces
Zeiss 7x50 Marine B/GA
Zeiss TM german equatorial
Gitzo 224 with Manfrotto 501 fluid head
Unitron alt-az mount
Max Lattanzi
Reged: 06/27/07
      #3419720 - 10/30/09 08:10 AM
Hi Ian,
You are quite right: I had missed that...
That is a very interesting video !
You guys got really lucky with seeing over there.
Looking forward to the Red channel, which is probably even better than that !
Max
John Boudreau
Reged: 04/06/08
Loc: Saugus, MA
      #3419757 - 10/30/09 08:35 AM
Jaw dropping stuff!
As for the processing, if one's trying to easily identify and monitor smaller scale features, I think your own processing is fine --- I certainly don't think it's overdone. For aesthetics, Dave's processing has than elusive 'natural' appearance, but for my eye perhaps just a bit too soft. Perhaps you should try something in between if you really want to reprocess?
---John
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
Re: Jupiter from Barbados - Lots more images new [Re: John Boudreau]
      #3420715 - 10/30/09 06:44 PM
Hi Ian,
These are certainly great images, all of them!
Wish I could get half as good as your images,
these are really
On processing, could you maybe share an unprocessed
stacked image?
Could be fun to see what others can come up with,
if they also explain what they did, then it would
be learnful for everybody IMHO.
Thanks for sharing such great images!
Mert
42º49"N 1º38"W
3" Polarex refractor
6" F12 SW Maksutov,CS2-S
EQ6 + EQMOD
SPC900NC/DFK21AU04.AS
My web-page don't laugh, I should make it better!
kevin M13
Reged: 03/07/09
Re: Jupiter from Barbados - Lots more images new [Re: Mert]
      #3422329 - 10/31/09 06:14 PM
Outstanding images
I like your images better. As long as not "grainy" and you have signal, I can't see why anybody would want to mush it up.
Great work!
kevin
astrosharp
Reged: 06/24/08
Re: Jupiter from Barbados - Lots more images [Re: kevin M13]
      #3423183 - 11/01/09 05:25 AM
Thanks for your comments. Dave's reasoning behind his version was to more closely resemble the beautiful images from our Aussie collegues such as Messers Wesley and Haese.
4 registered and 5 anonymous users are browsing this forum.
