O.F.L.I. Eyepiece World Cup: Target Selection? new
      #3423738 - 11/01/09 12:49 PM
The second annual Eyepiece "resolution(TM)" World Cup is fast approaching. This January, I would like to compare ten to a dozen 4mm and 5mm eyepieces using a 5.5" apochromatic refractor on three challenging winter double stars, Sirius being one of them. I am specifically looking for target suggestions for the other two doubles. They need to be stars that are only just resolvable in a 140mm f/7 scope under better than average, but not perfect, seeing.
For context, last year we used the Trapezium, twenty 7mm and 8mm eyepieces and 4" f/8.6 ED doublets. See the following for an idea of how we did things last time:
http://www.cloudynights.com/item.php?item_id=1934
The format will be just as unscientific and whimsical as last year, so "luck of the draw" in setting up the match-ups, as well as variability of seeing, will play a role in the outcome. That said, the criteria will be similar - simply "Could you see the companion(s)?" and "If so, how clearly?" I'll likely use the same rating scale as well.
Because we'll be using fewer eyepieces this year (10 rather than 20), I would like to increase both the number of targets and number of observers who participate. It will help, therefore, if we have targets that cross the meridian consecutively about an hour apart. The trick is identifying well-positioned targets (for our 37-degree N location) that are at the edge of capability for a 140mm refractor running 196x to 245x. That's where I need your help.
- Jim
"I do not know what I may appear to the world; but to myself I seem to have been only like a boy playing on the seashore, and diverting myself in now and then finding a smoother pebble or a prettier shell than ordinary, whilst the great ocean of truth lay all undiscovered before me."
- Sir Issac Newton
Edited by jrbarnett (11/02/09 01:09 PM)
PJ Anway
Reged: 06/04/03
Loc: Michigan's U.P.
Re: O.F.L.I. Eyepiece World Cup: Target Selection? new [Re: jrbarnett]
      #3424233 - 11/01/09 06:12 PM Attachment (8 downloads)
Hi Jim,
Looking forward to you 2nd annual shootout. Here are a few double-star targets I would suggest for a 140mm.
I picked doubles whose magnitude should make them relatively easy to find - “naked eye” under dark skies. Next, I picked doubles of near equal magnitude, which seem to be less affected by seeing. Two are in Cephus, high in the sky where there will be less atmosphere to deal with. The last one is in Cancer; coming up higher later in the evening. A beautiful trio with A-B being a good test.
PJ
_________________
Lookum Observatory
Re: O.F.L.I. Eyepiece World Cup: Target Selection? new [Re: PJ Anway]
      #3424356 - 11/01/09 07:28 PM
Thanks P.J. I will check them out. My only concern is that (a) at the magnifications contemplated, and (b) given that our seeing in January in Sonoma County is generally good with periods of very good, but not great, 0.8" separations might be overly challenging. No harm in waiting until December and giving these targets some early morning attention though to see if the concern is realistic.
If you were going to limit your targets to ~1" separation at equal brightness or perhaps ~1.5" at a delta of >2 magnitudes, can you suggest a couple of other targets?
- Sir Issac Newton
PJ Anway
Reged: 06/04/03
      #3424425 - 11/01/09 08:08 PM Attachment (5 downloads)
Jim,
Here are some others - similar criteria, different separation.
PJ
_________________
Lookum Observatory
lionel
Reged: 08/12/07
Loc: Delaware
      #3424699 - 11/01/09 10:58 PM Attachment (13 downloads)
Hi Jim,
I'm really looking forward to your ep evaluation since I have a new 5" refractor on the way and challenging doubles happen to be a primary interest. Here are a few unequal doubles that may work for you.
Lionel
Tak Mewlon 250
Powerstar C8
1960s Bushnell 60mm f12 refractor
Sphinx SXD
CG5-ASGT
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: O.F.L.I. Eyepiece World Cup: Target Selection? new [Re: lionel]
      #3425059 - 11/02/09 07:43 AM
For the powers you will be using, I think you are going to be needing targets not much less than 1 arcsec, maybe more like 1 to 1.2", and for uneven doubles, perhaps targets of 1.3 to 1.5 arcsec. I doubt you would see a 0.8" pair at 200x in a 140mm scope. Maybe at 300x-400x, and maybe if it is a blue pair.
Here's an example:
Zeta Cancri, 16 Cnc, Stf 1196, 5.3-6.2, when it was at 0.98" PA59 F8 G0
Call it 1 arcsecond. Using a 5" SCT, st 240x, elongation was very obvious. It jumped right out at me. I saw this as very clearly elongated with ever-so-slight a notch, not a very deep notch, but definitely a slight shallow notch. So at 1 arcsecond, best I could see was just a slight notch with a 5" scope. And it was seen at 240x. Keep in mind, that is a 1" pair.
Here's another example: scope CR150 6" refractor
16Vul as 5.8-6.2 / 0”.8 PA115, The spectral class F2, yellow/white, supports the normal Airy disk formula.
Both 6mm and 5mm orthos produced an elongated image and I recorded the 4mm UO ortho as much elongated. The 4mm is 300x.
I've spent a considerable amount of time on 16Vul testing the magnification needed to detect the discrete parts of the diffraction pattern. One night I put a 2.5x Powermate in the diagonal and ran right down thru my box of eyepieces.
It was easy enough to identify the fainter component following even at relatively low magnifications of 250x to 275x. At 250x there appeared the very slightest dip between the two members. At 275x I could see partial diffraction ring.
At 300x, the components were easily notched, two members are noticed and diffraction ring is noticed, but not whole.
At 333x, the components are more notched, the secondary following is definitely seen as the smaller of the two. 375x confirmed the view. PA was recorded as 120 at several of these lower magnifications.
At 400x, the components are still touching, but now diffraction ring appears solid all the way around.
At 430x the notch appears fairly deep and I noted components appear to be overlapped by maybe only 20% to 25%.
At 500x, I still could not see separation. Diffraction and notching were about the same as 430x.
At 600x, although components were still touching, not only could I see the deep notching in the disks but also I could see a depression in the first diffraction ring. This was the only magnification that I was clearly able to identify the diffraction rings belong to two separate components.
The Airy disk for my 6" scope has a radius of 138/150 = 0.92. Even assuming light most readily stimulating scotopic vision at 510nm rather than 555nm photopic vision, the Airy disk for my scope still only has a best radius of 0.92 x 510/555 = 0.84 arcseconds. Depending on the magnitude of the pair, the visible disks are 50% to 60% of the diameter of the Airy disk, brighter magnitude pairs having a larger central disk.
The maximum separation I could see on a 0.8" even pair, using a 6" refractor, was about 20% overlap. It took over 400x to see it. At 250x I could barely see a dip between the diffraction rings.
SOOOO, this is why I think you are going to need pairs wider than the diffraction limit. You aren't using magnification high enough to support seeing the limit.
edz
I posted this list in the thread in the eyepiece forum,
Doubles for Testing Limits of 80mm to 150mm
Probably some of these need to be checked in the 6th Orbit Catalogue, since they have been changing, but perhaps by only a few hundreths arcsec. For example I have zeta Cnclisted at 0.98", but it is at 1.04" in 2009 and will be at 1.06" in 2010.
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
Re: O.F.L.I. Eyepiece World Cup: Target Selection? [Re: EdZ]
      #3425468 - 11/02/09 01:01 PM
Thanks EdZ. This (insufficient magnification) was one of our concerns as well. Your chart is very useful. I think we'll need to select our 3 stars in order of increased challenge, and likely also need to have perhaps 3 sets of 3, in increasing order of difficulty, so that "night of" we can select the set list that best fits seeing at the time.
- Sir Issac Newton
Edited by jrbarnett (11/02/09 01:03 PM)
Moderator:  EdZ, RLTYS
