akman1955
Reged: 09/07/09
Loc: Alaska, USA
More pictures brian as you help us all with information and we are inquiring minds..john
mustgobigger
Reged: 06/12/07
very nice john, you have 2 of those....not fair. Brian
-------------------- RV-6
Meade 826
Meade 880 Deluxe
Unitron's 114,128,140,142,150,152,155,160
4" Jaegertron
4.5" A.E f/14 Refractor
4" f/15 Edmund's Refractor
akman1955
Reged: 09/07/09
Loc: Alaska, USA
not fair! You have amassed quite a lot over 2/3 years and i admire that because i probably bid against you on some things over the years...but after knowing you these past few months/ years ...we are all alike...All the best Brian and more power too you. You do have nice collection and you do alot of work too restore them.With that said,keep sharing information. Thanks,john
mustgobigger
Reged: 06/12/07
AHHH! HA! looks like i might finally get to try this unitron out tonight. been rotten all week. ill give first light report if i get to use it tonight. Brian
Meade 826
Meade 880 Deluxe
4" Jaegertron
akman1955
Reged: 09/07/09
Loc: Alaska, USA
yes let us know how it performs...did you get my pm's ..john
mustgobigger
Reged: 06/12/07
no i did not.
if you sent to my email i wont see till later tonight
when i get home.
Brian
Meade 826
Meade 880 Deluxe
4" Jaegertron
Edited by mustgobigger (11/01/09 04:41 PM)
akman1955
Reged: 09/07/09
Loc: Alaska, USA
Okay brian,,, see it later tonight. john
mustgobigger
Reged: 06/12/07
tried this scope out last night and its definitely not up to par in my opinion. looked good on moon. did 7 sisters and looked good also when i did orion it was good up to 200x and when i used a barlow at 400 things kind of washed out. when i did a single star test rings were concentric but outer ring in and out of focus was flared. i think spacing might be off as things were close but not good enough for 75mm unitron. ill have to do a little more experimenting on this one. more to come. Brian
Meade 826
Meade 880 Deluxe
4" Jaegertron
Bonco
Reged: 04/17/06
Loc: Florida
Brian, Good idea to try and tweek it. Let us know your results. However I can attest that all Unitron lenses are NOT created equal. Good luck and keep us posted. Bill
-------------------- RV6
Meade 2045
6 inch f/4 RFT R. Fagin Optics
TV Genesis
2.4 inch Lafayette Equitorial
3 inch Polarex/Unitron Equitorial
10 inch Zhumell
PST 40mm Solar scope
4 inch F/15 Antares
2.4 inch Unitron Equitorial
Tasco 10K 80mm/1200mm
Towa 339 Restored
mustgobigger
Reged: 06/12/07
hi bill, yes i agree about not being equal. when i view a single star i see no coma but view could be just a bit crisper. did flashlight test in dark with bright red light and all looked good.(no spots on lens center) i had one a bit back that should have been .005 gap and views were not good till i hit .008 (my 4" Edmund) maybe i will re space in early morning when i get home from work. (its raining again) it could be a bad lens but i have a feeling it just needs a little tweaking. it was close but not there. Brian
Meade 826
Meade 880 Deluxe
4" Jaegertron
akman1955
Reged: 09/07/09
Loc: Alaska, USA
Brian, any more on tweeking 75mm lense john
mustgobigger
Reged: 06/12/07
hi john, no i have not tried yet. maybe i will today before work. it was cloudy last night so i did not get to try the worm gear 140 out. i would not mind having these 2 side by side for a comparison. i better get on it as the boss asked me how busy i am in my room and i said real busy. they just started working some guys 12 hour shifts last night an i have a feeling i am next. that means eat, sleep and work for next 2 months. Brian
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
ok i measured the spacers and looks to be .0035 - .0037 and i think thats a little to thin.
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
i have some .005 foil tape i will try first.
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
smoothing foil down.
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
realign to orientation marks.
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
reassemble
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
now to do collimation
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
might as well check them both so i can compare them out tonight.
Meade 826
Meade 880 Deluxe
4" Jaegertron
mustgobigger
Reged: 06/12/07
if this is no better than first check i will go to .006 or .007 and see how that works and it might take several tries like my edmunds 4" but it was worth it. Brian
Meade 826
Meade 880 Deluxe
4" Jaegertron
