Privacy Policy |
Please read our Terms
of Service | Signup and
Doug Sanqunetti
Reged: 12/19/05
Does anyone know where I can get about 6 feet of Belden 8777 or similar cable? Other similar cables that I know of are:Omni 32203 or Honeywell/Genesis 1266. Here is a description from the data sheet:
22 AWG stranded (7x30) tinned copper conductors, polypropylene insulation, twisted pairs individually Beldfoil® Shielded (100% coverage), 22 AWG stranded tinned copper drain wire, PVC jacket.
I can find it rolls of 100 feet and greater, but I only need about 6 feet. Thanks, Doug
-------------------- http://www.dougsastro.net
Cicero, Indiana
cdndob
Reged: 07/28/06
Loc: The Great White North
Is there a very specific use for this cable that requires it to be close to Belden 8777?
If its just general use you could get away with some Category 5 networking cable which is 24 AWG, twisted pairs.
Steve
Radiostar
Reged: 10/16/08
Loc: Thunder Bay, Ontario
This cable is used for audio and control systems. Try some where that sells and installs commercial radio systems or a radio/tv station. Try and talk to a technician. They are usually more likely to help you out.
scott m
Reged: 12/06/07
Loc: Hatfield Pa
You can try here Cables To Go
-------------------- Orion Astroview 120st EQ w/rigel+2"diag(Cosmo)
Zhumell 10 inch dob w/telrad (Oddball)
Nikon AE 10x50 Binos
Astro-Tech Paradigm 5,8,12,15,18,25mm
GSO SuperView 30mm,20mm,15mm,10mm
Knight Owl EWA 6mm,9mm
Zhumell Plossl EP Kit
Tomvictor
Reged: 08/09/04
Loc: N.59.11.47. Norway
Minimum 1 meter: http://www.newark.com/belden/8777/cable-8777-3pair-per-m/dp/18K8434
-------------------- Tom Victor
http://www.ccd-astrophoto.com/
Takahashi EM-200 - 10" LX200ACF - Artemis 4021M - Mini Borg 60ED - FLI CFW - DSI PRO II. Canon EF200L f/2.8 - 450D - Baader mod. 350D.
Doug Sanqunetti
Reged: 12/19/05
Thanks for the info. This is exactly what I was looking for.
Best Regards, Doug
Cicero, Indiana
7 registered and 5 anonymous users are browsing this forum.
Moderator: spaceydee, csa/montana
