Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Eq Platform for $29.5 new [Re: arpruss]
      #3419771 - 10/30/09 08:53 AM
Arpruss,
Synchronous motor speed is determined by the line frequency. I don't need variable speed because the tracking speed is correct. If I were doing photography then I would use the variable frequency inverter mentioned above but then you would need a second axis motor too.
Ed Jones
salies
Reged: 08/10/09
Loc: catalogne france
Re: Eq Platform for $29.5 new [Re: Ed Jones]
      #3419814 - 10/30/09 09:38 AM
hola ed! you work is very good for me!
j am envoy see your build
congratulations!!!!
sempre andavant ,mai morirem !
arpruss
Reged: 05/23/08
Loc: Waco, TX
Re: Eq Platform for $29.5 new [Re: salies]
      #3425266 - 11/02/09 10:37 AM
Ed:
How thick is the maple ply that you used?
I am still in the planning stages. What I really like about this design is that it doesn't use a single-point south bearing like most of the other designs on the net. For my scope with a 25.5" high COG and about latitude 30, a single-point south bearing would require a ridiculously long platform--about 58" long.
Coulter Odyssey 13.1" split-tube
Coulter Odyssey 8"
Home-made 7.8" F/4 dobsonian travel scope
Home-made 68mm F/5.3 achro (typically used as finder on 13.1")
Skymaster 15x70
BPTs4 8x30
32mm Plossl, 30mm Rini, 27mm Kellner, 13mm Hyperion, 6mm TMB/BO Planetary, Owl 2X Barlow
Palm TX with AstroInfo and RescoViewer
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: Eq Platform for $29.5 [Re: arpruss]
      #3426279 - 11/02/09 09:23 PM
I use some old maple wooden flooring 3/8 thick and doubled it to 3/4.
Ed Jones
arpruss
Reged: 05/23/08
Loc: Waco, TX
      #3446945 - 11/13/09 10:18 PM
Does anyone have any spreadsheet for the measurements? I made one (I'll post a link once I know it works) but I'd like to double check its calculations against someone else's before I start to cut.
Coulter Odyssey 8"
Skymaster 15x70
BPTs4 8x30
10 registered and 7 anonymous users are browsing this forum.
