jusher02
Reged: 02/05/07
The spring winds in Wellington have prevented any imaging for more than 4 weeks, but I managed to get about 15 minutes of clear/calm weather yesterday evening and brought out the 12" dob w/alt-az tracking to catch Jupiter while it was still high in the sky. Although seeing wasn't the best, there's still some reasonable detail to be seen, and Callisto's transit was nice to catch.
500 frames per channel at f/25, 100% size, captured with DMK21 USB camera with Orion RGB filters. Comments and suggestions are most welcome!
Jonathan
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Nice Jonathan! Did you use resample ?
-------------------- Freddy
Meade 14" LX200 GPS UHTC GPS on permanent pier
Celestron C 14" Peltier cooled for planetary imaging.
Meade 10" LX200 & TITAN 50:1 mount Gemini 'go to'
Meade 127 mm f/9 APO & TITAN 50:1 mount Gemini 'go to'
W/O 102 mm f/7 APO doublet
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
Canon 10D Unmoddified
Canon 40D Hutech moddified
jusher02
Reged: 02/05/07
Hi Freddy. No resampling used. This is a quick process I managed to do (we've just had our second child so I don't have much time to play around with settings right now ). I realize the image is a bit noisy and I hope that when I get a bit more time I can coax some more detail from the source AVIs.
Jonathan
Freddy WILLEMS
Reged: 11/13/05
Congrats Jonathan with the baby..... Thanks for taking the time to post this great Jupiter image in between diper changes.
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
whduke
Reged: 04/22/08
Loc: Clayton NC
You have taken some great images. By the way what brand and type of DOB do you have?Did you by the tracking with the Dob or is it aftermarket?
-------------------- CELESTRON 9.25
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
WayneJ
Reged: 08/20/09
Loc: West Chester, PA
Excellent image and processing! Well done.
Imaging Gear:
Meade 10" LX50 EMC
Celestron Neximage
Starlight Instruments Feathertouch Focuser
Orion_PKFD
Reged: 01/22/08
Loc: Vieira do Minho, Portugal
Very well done. Cngrats
-------------------- André Gonçalves
http://astro-andregoncalves.blogspot.com/
SkyView Pro 8" EQ
Dob 4,5" (ATM)
60mm achromatic refractor
10x50 WA
10x25
SPC900NC
DSI
Canon 1000D
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
That's a very good image jonathan, keep them coming
Mert
42º49"N 1º38"W
3" Polarex refractor
6" F12 SW Maksutov,CS2-S
EQ6 + EQMOD
SPC900NC/DFK21AU04.AS
My web-page don't laugh, I should make it better!
jusher02
Reged: 02/05/07
Thanks for the kind words - it's been frustrating with the weather here, so it was nice to finally catch a break with reasonable seeing.
To answer the question about the type of Dob I have, it's a Skywatcher 12" auto-tracking Flextube Dob. It came with an alt-az tracking mount, with a tracking hand controller (level the tube North, turn on power, and the scope tracks from there). I also have a GoTo hand controller for the scope.
While it tracks pretty well, there is quite a lot of free play in the axes, which means that the target can move off frame in the slightest gust of wind. I've toyed with mounting the tube on my EQ6 Pro mount but I think it would stress the mount a bit much.
I'd appreciate some advice about that - if the tube of the 12" is too much for an EQ6 Pro mount, do you think I'd get better solar system imaging on that mount from a C11 or from a 10" Newtonian tube mounted on the EQ6 Pro? I already have a Televue NP127is so I'm not worried about long exposure imaging with the Dob or C11; I just want to get the setup that has the most potential for solar system imaging on the EQ6 Pro mount.
Thanks for any advice!
Jonathan
kevin M13
Reged: 03/07/09
Sweet image! Congrats.
Kevin
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
Great work! Looks fantastic.
-------------------- Gallery/Blog/RSS/Tutorials
Mike's Lesson on Seeing, Collimation and Focusing
**NEW** VIDEO HowTo: Planetary Processing Routine v8 **NEW**
