whduke
Reged: 04/22/08
Loc: Clayton NC
I tried the ninox Resample 3/1, but when each channel is done the image develops lines through out the image. After ninox, I only stack the images with Registax. I use IRIS to process, and with just only a little bit of wavelettes is when the lines develope. Any help would be much appreciated, or the proper way to do this. Thanks!!
-------------------- CELESTRON 9.25
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Edited by whduke (10/27/09 11:13 PM)
Sunspot
Reged: 03/15/05
I don't have an answer. The same thing happens for me when I resample above 3/2. I know Bird goes 3x with great success.
Paul
-------------------- Paul Maxson
Mewlon 250, Orion EON120, SKYnyx 2-0M, LS100F.
http://www.sunspot51.com
whduke
Reged: 04/22/08
Loc: Clayton NC
I will try resampling to 2x this time. Maybe that will help?
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Chris_H
Reged: 11/24/03
Loc: Norway
Yeah I had the same problem as well
-------------------- Chris
Orion Optics 200mm F4.5
DMK 21AU04.AS
Astrodon LRGB
SPC900NC
Canon Powershot A610 (CHDK modded)
My Website
Bird
Reged: 08/07/03
Loc: Canberra, Australia
Do you guys have the latest version? Try grabbing that from the website and check if it fixes the problem.
cheers, Bird
-------------------- Deep Sky Optics 13.1" f/5.5 newtonian,
PGR Dragonfly Express, PGR Dragonfly 2
RedHat Linux + Coriander
http://www.acquerra.com.au/astro/
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
What do the lines look like?
-------------------- Gallery/Blog/RSS/Tutorials
Mike's Lesson on Seeing, Collimation and Focusing
**NEW** VIDEO HowTo: Planetary Processing Routine v8 **NEW**
Sunspot
Reged: 03/15/05
Bird,
With the newest (2.71) I don't see the lines when I resample at 3x. I do see a halo around very dark dots (like satellite shadows). The attached image was resized 3x, then reduced 50% and saved out as a jpg. You can see a "halo" around the moon's shadow. I don't know if that is from Ninox or Registax.
Paul
Mike Phillips
Reged: 02/21/06
I get a ringing effect too, I just assumed it was the sharpening effect. I'm sure it's more complicated than that!
whduke
Reged: 04/22/08
Loc: Clayton NC
I haven't tried the new version yet. I gues I have to change from Win Ninox to the command line version correct? The lines in the old version show up with just the slightest wavlettes. They are horizontal lines all over the image about one pixel apart.
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Don C
Reged: 08/26/07
Loc: McCain, North Carolina
I'm having issues there too, but I built the INI file (command line version) and it seems to work. I then register and stack in Registax 5. These are .bmp files not .fit, and then I'm still looking for a good deconvolution sw that doesn't trash the images after 2 iterations... I use Registax for the wavelets and Photoshop CS4 for tweaks and resampling to 50%. Don
-------------------- CPC 800 XLT OTA
Orion Atlas EQ
Orion 3-element 2x Barlow w/extension tube
Philips SPC900NC with Color RAW mod
Dell Studio XPS 1640 running Win7 Home Premium
Mike Phillips
Reged: 02/21/06
Don't make me whip this one out again:
http://www.youtube.com/watch?v=FpOJQxzyTnw
PS the rest of the tutorial below shows the options more
whduke
Reged: 04/22/08
Loc: Clayton NC
Mike thanks for the link!! How do you setup the directories for the command line ninox. With winNinox I set it up as : C\Ninoxed\Jupiter1bmp\RGB <in individual folders. When I try this for the command line version it can't find the folders. So my question is how do I process all of the RGB's in seperate folders marked RGB?
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Mike Phillips
Reged: 02/21/06
Humm... that'll be in the advanced version!
I'd probably setup a windows batch file that just runs the same ninox command three times with the subfolders R, G and B.
whduke
Reged: 04/22/08
Loc: Clayton NC
That sucks, I believe im going to stick with Win Ninox again. It processes everything, if someone would just update the program please!!
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Sunspot
Reged: 03/15/05
whduke,
Which version of Winninox are you using? I have 1.2 and for me it works fine (under Win XP Pro).
Paul
whduke
Reged: 04/22/08
Loc: Clayton NC
I have 1.2 also, but im trying to resize like Bird. Bird said the artifacts / numerous lines in the image might be due to the older version of ninox. Im going to stick with Ninox and just buy a 3x barlow. I will use the 2.5 on average seeing, and the 3x on good seeing. Thanks for the help everyone!!
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Don C
Reged: 08/26/07
Where can I download winninox? I tried Dave's site but get 403 and 404 errors. Thanks, Don
Orion Atlas EQ
RedIrocZ-28
Reged: 09/18/05
Loc: Grand Rapids, Michigan
I can't even get ninox to run with Mike's tutorial.... I already give up..
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Yep had some problems with Ninox to, but somebody helped me out with some basics. Somebody should put all these 'softwares' together like virtul dub, Ninox, Registax, Astra Image and PS so it's one package for you to choose the processing you like. The most important is to select the best frame (=quality) and start from there so you can decide how many frames to stack for furture processing.
-------------------- Freddy
Meade 14" LX200 GPS UHTC GPS on permanent pier
Celestron C 14" Peltier cooled for planetary imaging.
Meade 10" LX200 & TITAN 50:1 mount Gemini 'go to'
Meade 127 mm f/9 APO & TITAN 50:1 mount Gemini 'go to'
W/O 102 mm f/7 APO doublet
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
Canon 10D Unmoddified
Canon 40D Hutech moddified
Bird
Reged: 08/07/03
Hi guys, winninox should be compatible with the latest version of ninox, if in doubt give DaveP (the author) a yell and ask him to check it.
The ringing artifacts from the earlier posts will be from registax, ninox doesn't do anything that could cause that.
cheers, Bird
