RobM
Reged: 01/03/07
Removing Dew Shield from Astro Tech AT80LE
      #3426973 - 11/03/09 08:19 AM
Like alot of the Astro Tech 80mm scopes, my AT80LE scope is a little killer, but there's way too much wiggle in the fit of the dew shield. I would like to add some adhesive-backed velvet to the front exterior of the OTS to snug up the dew shield's fit. How do I remove the dew shield's front retaining ring?
Astronomics told me it should just unscrew, but the danged thing won't budge and I don't want to damage the OTA. I love this scope and if I sell it, this would only be to move up to the AT106. Any suggestions would be appreciated.
LLEEGEModerator
Running out of Oxygen
Reged: 03/03/05
Loc: Cloud-chester,NY
Re: Removing Dew Shield from Astro Tech AT80LE new [Re: RobM]
      #3427235 - 11/03/09 11:29 AM
The dew shield should easily unscrew from the slide mechanism. Then, remove the focuser and slide the retainer off, apply some felt and reinstall. If it doesn't unscrew easily, try wearing latex gloves to help get a better grip. If that doesn't work, try a rubber strap wrench.
"Okay! You draw the straws. I'm-a taking the parachute."
RobM
Reged: 01/03/07
Re: Removing Dew Shield from Astro Tech AT80LE new [Re: LLEEGE]
      #3427725 - 11/03/09 03:44 PM
Thanks for the response, but no dice...darned thing just won't budge.
AstronomicsAdministrator
Vendor if you must, AKA The Mighty Kong.
Reged: 06/07/04
Loc: Right Here
      #3427740 - 11/03/09 03:51 PM
The interior of the front trim ring is threaded. Just unthread the interior ring from the entire trim ring assembly and it will allow you to push the dew shield past the lens.
Michael Bieler
Father and Husband
Owner
www.astronomics.com
www.astronomytechnologies.com
www.cloudynights.com
27 registered and 22 anonymous users are browsing this forum.
Moderator:  desertstars, Remy Bosio, Jason B, LLEEGE
