Privacy Policy |
Please read our Terms
of Service | Signup and
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
when you guys talking about the payload, is it include everything on top of the mount (OTA, diagonals, eyepieces, focusers, finder/guide scope).
Yes, the 'weight' will be everything on top of the mount.
Regarding the C8 weight, Astronomics lists the weight at 13 lbs also.
I was planning to do some short exposure APs with my DSLR for fun, but I'm just a little bit worried after reading comments about CG-5 payload. I don't know what should I do right now, am I going to be ok? any advice would be helpful.
Try it and see how things work out for you. The WO72ED should be a fine scope for that mount for AP. You can always get a lighter weight guide scope or try imaging with just the smaller refractor. You can use the C8 for visual work or as the guide scope.
Patrick
10" f/6 Truss Tube Newtonian
Celestron C6S-GT SCT
AT66ED Refractor
Oberwerk Ultra 15x70 Binocular
475B Geared Tripod & 501HDV Head
Celestron Regal 8x42 Binocular
Canon XSi; Meade DSI;SPC900-NC
Vixen GP2 Photo Guider Mount
My Astronomy Pages
Leo.S
Reged: 09/21/09
Loc: Toronto, Ontario
Thanks Mark and Patrick! The mount is on its way to my front door now, just can't wait to try it
-------------------- Telescopes: Celestron Nexstar 8SE, WO Megrez 72ED APO, Orion 9x50 RACI Finder
Eyepieces: 8mm 13mm TV Ethos, 26mm 31mm TV Naglar
Filters: Lumicon 2" Variable Polarizer/2" UHC
Mount: Celestron Nexstar GoTo, CG-5 ASGT
Accessories: Moolite Focuser,2"Dura Bright/2"Quartz WO Diagonals,WO P-Flattner 3,CN16 GPS,NexImage,Starry Night Pro Plus 6.3
AlienFirstClass
Reged: 02/13/09
A quick qestion...what is the diameter of the hole in the counterweight for the CG5-GT?
johnpd
Reged: 04/13/08
Approx 21mm.
ned_l
Reged: 03/12/07
Loc: north carolina
Does the CG5-GT also have the Allstar polar alignment routine the CGEM has? I am debating between the 2, and would be really happy to a) save the money over the CGEM and b) save the weight of carrying the CGEM around.
Ned
-------------------- 8" Orion Newtonian w/ Sky View Pro mount
Feather Touch focuser
Stellarvue 102 ED
Chris Rowland
Reged: 02/28/05
Yes it does have Allstar.
Chris
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
If you have an upgradable hand controller (running any firmware at 4.x) the CG5 can use exactly the same firmware as the CGEM/CGE/CGEpro. So any of the discussions about All Star Polar Alignment or any of the other features mentioned in the threads here apply to the CG-5.
-------------------- Mark
C11, C6, APM/TMB115, and AT80ED - Tandem mount CGE and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - Modded 350D, DSI-P, SPC900, Mallincam
Just because you can doesn't necessarily mean that you should
BlueGrass
Reged: 07/25/09
Loc: Wasatch Front, UT
Except the HC firmware knows that you're using a CGEM / CGE and gives you PEC capability. That option is not available with the CG5. There may be other options but for the most part the AllStar alignment routine is the same....
-------------------- C8 / EON 80 APO
CGEM / CG5
ST80 with SS AG setup
Canon 1000d
mclewis1
Thread Killer
Reged: 02/25/06
Yeah, that's a good point. I should have added something like that you get the same s/w functions within the capabilities of the hardware. For example on the CG-5 with no fixed index point on the RA axis means that the PEC routine has no reference point to start and synchronize from.
There are a few other hardware specific characteristics of the other mounts (like the limit switches on the CGE) so while the HC firmware is indeed exactly the same there are physical characteristics that effect the overall function of each type of mount.
5 registered and 5 anonymous users are browsing this forum.
Moderator: Charlie Hein, lineman_16735
