Sunspot
Reged: 03/15/05
Hi all,
Wow, two in one day!! Seeing was not good on this morning.
http://www.sunspot51.com/Mars/2009-09-11-PWM.jpg
Paul
-------------------- Paul Maxson
Mewlon 250, Orion EON120, SKYnyx 2-0M, LS100F.
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Great work as always Paul. I've been meaning to ask you. Is there a trick you learned in regards to focus? All of your images, especially of Mars, seem to have the focus dead on. And its such a small target. Did you come up with a technique or something that helps?
-------------------- Mars Watch
All images taken with:
Celestron CPC 1100
DBK 21AF04.AS
K3ccd/Registax4/PSP8/Maxim DL IP
ALPO Member #4287
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Well done Paul.
-------------------- Freddy
Meade 14" LX200 GPS UHTC GPS on permanent pier
Celestron C 14" Peltier cooled for planetary imaging.
Meade 10" LX200 & TITAN 50:1 mount Gemini 'go to'
Meade 127 mm f/9 APO & TITAN 50:1 mount Gemini 'go to'
W/O 102 mm f/7 APO doublet
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
Canon 10D Unmoddified
Canon 40D Hutech moddified
Sunspot
Reged: 03/15/05
Joel,
Thanks! I learned a trick not too long ago from someone here. I lower the gamma from 1.0 (on my software) to about .7 or so, then focus. That has helped. The other trick on Mars is to have the blue filter online and have the settings on the computer for the green filter. Right now the NPH stands out and I try to focus on the rim of it. Mostly I just keep going in and out of focus until it "looks right". It sometimes takes me 10-15 minutes to get focus. Having an electric focus sure helps too.
Paul
5 registered and 4 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
