deSitter
Reged: 12/09/04
The latest version of CdC allows the installation of an enormous catalog, the United States Naval Observatory Charge Coupled Device Astrograph Catalog - and contains almost as many stars as words in this title!
This is Omega Centauri with the default catalogs (hybrid of Tycho2 and Hipparcos):
deSitter
Reged: 12/09/04
..and now with UCAC3 turned on - this is not a photograph, but a database dump!
deSitter
Reged: 12/09/04
The default settings are very poor - after hours of tweaking the star density, field of view, colors, and star contrast settings I succeeded in making it look like a respectable atlas - once set it becomes a magnificent tool and extremely useful at the telescope, much more so than the typical planetarium program because it is restricted to making charts for the most part. Configuration is easy to share, and I'd be happy to share mine.
-drl
deSitter
Reged: 12/09/04
For comparison, here's how SNP 6 handles this area (same scale more or less)
bharris22
Reged: 12/12/07
That looks great! Please do share your settings and instructions how to install that catalog!
desertstars
Please stand by...
Reged: 11/05/03
Loc: Tucson, AZ
Looks like it's time for me to upgrade my version of CdC.
-------------------- Tom W.
Collinder's Catalog
Jewels in Dark Settings
okiestarman56
Reged: 04/10/08
Loc: 36.9'33" N 95.23'29" W
Yes please please share!
-------------------- 305mm f/5 GSO 12" DSO
114mm f/7.8 Tasco 4.5" Red Tube
76.2mm f/15.7 Tasco 10te #771027
80mm f/15 Sears 3.1" Refracor #412.4454
60mm f/15 Sears 2.3" Refractor #4 6305-A
60mm f/15 Sears 2.3" Refractor #4451
Plenty of EPs? .965 to 2"
2 LPI's
Home made Denver chair
3-7'x10' light panels
yada yada yada
StarmanDan
Reged: 08/27/07
Loc: China Spring, Texas
Awsome! Can't wait to upgrade my catalogs.
-------------------- "Starman" Dan Doyle
Texas Astronomical Society of Dallas
Central Texas Astronomical Society
8" LX200GPS w/ST80 guidescope, Canon 350D+DSI Pro
150mm f/8 Sky Watcher Refractor
10" f/4.5 Homemade Dob
RV-6 Criterion Dynascope
http://darcstar.wordpress.com
klassikmann
Reged: 02/07/05
Loc: south of Frankfurt/Germany
To install UCAC3 with CdC (skychart 3.0.1.6) you have to download the zip-files from Sourceforge(2.2 GB!) plus the readme.txt (2-catalogs -> Stars -> UCAC3). Than expand the archives to the "cat" directory of your skychart installation (for *NIX e.g. /usr/share/skychart/cat).
The last step you find in the documentation (first paragraph). Leave the defaults for min (0) and max (3). This works fine for me.
-------------------- Herbert Eisenbeis
Celestron CGE1100
Takahashi FSQ-106ED
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
How deep is the dimmest mag in the catalog? Will it work with other apps like Kstars or stellarium? Did you get it setup on win? Linux?
PS I really need to hang out here more!
-------------------- Gallery/Blog/RSS/Tutorials
Mike's Lesson on Seeing, Collimation and Focusing
**NEW** VIDEO HowTo: Planetary Processing Routine v8 **NEW**
bharris22
Reged: 12/12/07
-drl
Please do share your configuration settings - your screenshot looks a heck of a lot better than my CdC!
deSitter
Reged: 12/09/04
Here's my skychart.ini - put in your own location data afterward (random place inserted here) under the [observatory] section and check the path to your local settings - based on your XP install and user name - mine is C:\Documents and Settings\Administrator\Local Settings\Application Data\Skychart - note that "Local Settings" is a hidden directory and you must change the folder settings to display hidden items to access it via Explorer. Also clear out the [dss] section - this one has the footprint of some images I downloaded. You'll need the Gill Sans TrueType font with ClearType anti-aliasing turned on for the best label appearance.
[main] version=3.0.1.6 AppDir=C:\Program Files\Ciel PrivateDir=C:\Documents and Settings\Administrator\Local Settings\Application Data\Skychart use_xplanet=0 xplanet_dir=C:\Program Files\xplanet SaveConfigOnExit=0 NightVision=0 Paper=2 PrinterResolution=72 PrintColor=0 PrintLandscape=1 PrintMethod=0 PrintCmd1=gsview32.exe PrintCmd2=mspaint.exe PrtLeftMargin=15 PrtRightMargin=15 PrtTopMargin=10 PrtBottomMargin=5 Theme=default WinMaximize=1 AzNorth=1 ListStar=1 ListNeb=1 ListVar=1 ListDbl=1 ListPla=1 autorefreshdelay=30 ConstLfile=C:\Program Files\Ciel\data\constellation\DefaultConstL.cln ConstBfile=C:\Program Files\Ciel\data\constellation\constb.cby EarthMapFile=C:\Program Files\Ciel\data\earthmap\earthmap1k.jpg PlanetDir=C:\Program Files\Ciel\data\planet ServerIPaddr=127.0.0.1 ServerIPport=3292 IndiPanelCmd=cmd /c "C: && cd C:\Program Files\dcd && dcd.py" keepalive=1 AutostartServer=1 dbtype=1 dbhost=localhost dbport=3306 db=C:\Documents and Settings\Administrator\Local Settings\Application Data\Skychart\database\cdc.db dbuser=root dbpass=082080021040022004402004100180 ImagePath=C:\Program Files\Ciel\data\pictures\ ImageLuminosity=0 ImageContrast=0 ShowChartInfo=0 SyncChart=0 ButtonStandard=1 ButtonNight=2 HttpProxy=0 FtpPassive=1 ConfirmDownload=0 AnonPass=skychart@ CometUrlCount=1 CometUrl1=http://cfa-www.harvard.edu/iau/Ephemerides/Comets/Soft00Cmt.txt AsteroidUrlCount=3 AsteroidUrl1=http://www.ap-i.net/skychart/data/mpc5000.dat AsteroidUrl2=http://cfa-www.harvard.edu/iau/Ephemerides/Unusual/Soft00Unusual.txt AsteroidUrl3=http://cfa-www.harvard.edu/iau/Ephemerides/Distant/Soft00Distant.txt IndiAutostart=1 IndiServerHost=localhost IndiServerPort=7624 IndiServerCmd=indiserver IndiDriver=lx200basic IndiPort=/dev/ttyS0 IndiDevice=LX200 Basic IndiTelescope=0 PluginTelescope=1 ManualTelescope=0 ManualTelescopeType=0 TelescopeTurnsX=6 TelescopeTurnsY=0.4 ScopePlugin=Ascom.tid ViewMainBar=1 ViewLeftBar=0 ViewRightBar=1 ViewObjectBar=0 ViewScrollBar=0 ViewStatusBar=1 NumChart=1 WinTop=-4 WinLeft=-4 WinWidth=1680 WinHeight=1029 FieldNum0=1 FieldNum1=2 FieldNum2=5 FieldNum3=10 FieldNum4=20 FieldNum5=45 FieldNum6=60 FieldNum7=90 FieldNum8=120 FieldNum9=180 FieldNum10=360
[catalog] starcatpath1=C:\Program Files\Ciel\cat\bsc5 starcatpath2=C:\Program Files\Ciel\cat\sky2000 starcatpath3=C:\Program Files\Ciel\cat starcatpath4=C:\Program Files\Ciel\cat\tycho2 starcatpath5=C:\Program Files\Ciel\cat starcatpath6=C:\Program Files\Ciel\cat\gsc starcatpath7=C:\Program Files\Ciel\cat\gsc starcatpath8=C:\Program Files\Ciel\cat starcatpath9=C:\Program Files\Ciel\cat\usnoa starcatpath10=C:\Program Files\Ciel\cat starcatpath11=\Deepsky2000 starcatpath12=\Deepsky2000 starcatpath13=\Deepsky2000 starcatpath14=C:\Program Files\Ciel\cat varstarcatpath1=C:\Program Files\Ciel\cat\gcvs varstarcatpath2=C:\Program Files\Ciel\cat dblstarcatpath1=C:\Program Files\Ciel\cat\wds dblstarcatpath2=C:\Program Files\Ciel\cat nebcatpath1=C:\Program Files\Ciel\cat\sac nebcatpath2=C:\Program Files\Ciel\cat\ngc2000 nebcatpath3=C:\Program Files\Ciel\cat\lbn nebcatpath4=C:\Program Files\Ciel\cat\rc3 nebcatpath5=C:\Program Files\Ciel\cat\pgc nebcatpath6=C:\Program Files\Ciel\cat\ocl nebcatpath7=C:\Program Files\Ciel\cat\gcm nebcatpath8=C:\Program Files\Ciel\cat\gpn nebcatpath9=C:\Program Files\Ciel\cat GCatNum=1 CatName0=3uc CatPath0=C:\Program Files\Ciel\cat\ucac3\ CatMin0=0 CatMax0=3 CatActif0=1 StarmagMax=19.1 NebmagMax=99 NebSizeMin=0 UseUSNOBrightStars=0 UseGSVSIr=0 starcatdef1=1 starcaton1=1 starcatfield11=0 starcatfield21=10 starcatdef2=0 starcaton2=0 starcatfield12=6 starcatfield22=7 starcatdef3=0 starcaton3=0 starcatfield13=0 starcatfield23=0 starcatdef4=1 starcaton4=1 starcatfield14=0 starcatfield24=5 starcatdef5=0 starcaton5=0 starcatfield15=0 starcatfield25=0 starcatdef6=0 starcaton6=0 starcatfield16=0 starcatfield26=3 starcatdef7=0 starcaton7=0 starcatfield17=0 starcatfield27=3 starcatdef8=0 starcaton8=0 starcatfield18=0 starcatfield28=0 starcatdef9=0 starcaton9=0 starcatfield19=0 starcatfield29=1 starcatdef10=0 starcaton10=0 starcatfield110=0 starcatfield210=0 starcatdef11=0 starcaton11=0 starcatfield111=0 starcatfield211=10 starcatdef12=0 starcaton12=0 starcatfield112=0 starcatfield212=5 starcatdef13=0 starcaton13=0 starcatfield113=0 starcatfield213=3 starcatdef14=0 starcaton14=1 starcatfield114=0 starcatfield214=0 varstarcatdef1=0 varstarcaton1=0 varstarcatfield11=0 varstarcatfield21=10 varstarcatdef2=0 varstarcaton2=0 varstarcatfield12=0 varstarcatfield22=0 dblstarcatdef1=0 dblstarcaton1=0 dblstarcatfield11=0 dblstarcatfield21=10 dblstarcatdef2=0 dblstarcaton2=0 dblstarcatfield12=0 dblstarcatfield22=0 nebcatdef1=1 nebcaton1=1 nebcatfield11=0 nebcatfield21=10 nebcatdef2=1 nebcaton2=1 nebcatfield12=0 nebcatfield22=10 nebcatdef3=0 nebcaton3=0 nebcatfield13=0 nebcatfield23=5 nebcatdef4=1 nebcaton4=1 nebcatfield14=0 nebcatfield24=5 nebcatdef5=0 nebcaton5=0 nebcatfield15=0 nebcatfield25=5 nebcatdef6=0 nebcaton6=0 nebcatfield16=0 nebcatfield26=5 nebcatdef7=1 nebcaton7=1 nebcatfield17=0 nebcatfield27=5 nebcatdef8=1 nebcaton8=1 nebcatfield18=0 nebcatfield28=5 nebcatdef9=0 nebcaton9=0 nebcatfield19=0 nebcatfield29=0 CatMin1=0 CatMax1=10 CatActif1=0 CatLongName0=UCAC3
[dss] dssnorth=0 dsssouth=0 dss102=0 dsssampling=1 dssplateprompt=1 dssmaxsize=2048 dssdir=cat\RealSky dssdrive=D:\ DSSurlName1=DSS 1 DSSurl1=http://archive.eso.org/dss/dss/image?ra=$RAH+$RAM+$RAS&dec=+$DED+$DEM+$DES&equinox=J2000&x=$XSZ&y=$YSZ&Sky-Survey=DSS1&mime-type=display/gz-fits DSSurlName2=DSS 2 Red DSSurl2=http://archive.eso.org/dss/dss/image?ra=$RAH+$RAM+$RAS&dec=+$DED+$DEM+$DES&equinox=J2000&x=$XSZ&y=$YSZ&Sky-Survey=DSS2-red&mime-type=display/gz-fits DSSurlName3=DSS 2 Blue DSSurl3=http://archive.eso.org/dss/dss/image?ra=$RAH+$RAM+$RAS&dec=+$DED+$DEM+$DES&equinox=J2000&x=$XSZ&y=$YSZ&Sky-Survey=DSS2-blue&mime-type=display/gz-fits DSSurlName4=DSS 2 Infrared DSSurl4=http://archive.eso.org/dss/dss/image?ra=$RAH+$RAM+$RAS&dec=+$DED+$DEM+$DES&equinox=J2000&x=$XSZ&y=$YSZ&Sky-Survey=DSS2-infrared&mime-type=display/gz-fits DSSurlName5=SkyView DSS DSSurl5=http://skyview.gsfc.nasa.gov/cgi-bin/images?Survey=DSS&position=$RAF,$DEF&Size=$FOVX,$FOVY&Pixels=$PIXX,$PIXY&Projection=Tan&Equinox=2000&Return=FITS DSSurlName6=H-alpha Full Sky Map DSSurl6=http://skyview.gsfc.nasa.gov/cgi-bin/images?Survey=H-alpha&position=$RAF,$DEF&Size=$FOVX,$FOVY&Pixels=$PIXX,$PIXY&Projection=Tan&Equinox=2000&Return=FITS DSSurlName7=2MASS J DSSurl7=http://skyview.gsfc.nasa.gov/cgi-bin/images?Survey=2MASS-J&position=$RAF,$DEF&Size=$FOVX,$FOVY&Pixels=$PIXX,$PIXY&Projection=Tan&Equinox=2000&Return=FITS DSSurlName8=2MASS H DSSurl8=http://skyview.gsfc.nasa.gov/cgi-bin/images?Survey=2MASS-H&position=$RAF,$DEF&Size=$FOVX,$FOVY&Pixels=$PIXX,$PIXY&Projection=Tan&Equinox=2000&Return=FITS DSSurlName9=IRAS 12 micron DSSurl9=http://skyview.gsfc.nasa.gov/cgi-bin/images?Survey=IRAS12&position=$RAF,$DEF&Size=$FOVX,$FOVY&Pixels=$PIXX,$PIXY&Projection=Tan&Equinox=2000&Return=FITS OnlineDSS=1 OnlineDSSid=1
[quicksearch] count=9 item1=eta cas item2=m13 item3=omega cen item4=m11 item5=moon item6=v crb item7=ngc 7603 item8=rachele item9=HR897
[filter] StarFilter=1 AutoStarFilter=1 AutoStarFilterMag=6.2 NebFilter=1 BigNebFilter=1 BigNebLimit=60 StarMagFilter1=99 NebMagFilter1=99 NebSizeFilter1=0 StarMagFilter2=15 NebMagFilter2=99 NebSizeFilter2=0 StarMagFilter3=14 NebMagFilter3=99 NebSizeFilter3=1 StarMagFilter4=13 NebMagFilter4=99 NebSizeFilter4=2 StarMagFilter5=12 NebMagFilter5=13 NebSizeFilter5=4 StarMagFilter6=11 NebMagFilter6=12.5 NebSizeFilter6=6 StarMagFilter7=10 NebMagFilter7=12 NebSizeFilter7=6.66666666666667 StarMagFilter8=9 NebMagFilter8=11.5 NebSizeFilter8=20 StarMagFilter9=8 NebMagFilter9=10 NebSizeFilter9=30 StarMagFilter10=7 NebMagFilter10=8 NebSizeFilter10=60
[display] starplot=2 nebplot=1 plaplot=2 TransparentPlanet=0 Nebgray=36 NebBright=126 StarDyn=68 StarSize=17 contrast=359 saturation=255 redmove=1 partsize=0.80000001192092 magsize=8.30000019073486 AutoSkycolor=0 color0=0 color1=15702147 color2=15458164 color3=16777215 color4=13302265 color5=9106155 color6=9354226 color7=6451707 color8=255 color9=16776960 color10=65280 color11=16777215 color12=2302755 color13=2039583 color14=32896 color15=12632256 color16=8388608 color17=2034207 color18=155 color19=2105392 color20=65535 color21=16760832 color22=328707 color23=8421440 color24=8421504 color25=2741961 color26=803614 color27=0 color28=5384551 color29=6633757 color30=0 color31=255 color32=255 color33=8421631 color34=16711808 color35=0 skycolor0=2097152 skycolor1=15744060 skycolor2=13120050 skycolor3=10496040 skycolor4=7864320 skycolor5=6553616 skycolor6=3932176 skycolor7=0 bgColor=2097152
[font] FontName1=Gill Sans FontSize1=8 FontBold1=0 FontItalic1=0 FontName2=Gill Sans FontSize2=8 FontBold2=0 FontItalic2=0 FontName3=Arial FontSize3=8 FontBold3=0 FontItalic3=0 FontName4=Gill Sans FontSize4=8 FontBold4=0 FontItalic4=0 FontName5=APL2 FontSize5=8 FontBold5=0 FontItalic5=1 FontName6=Gill Sans FontSize6=8 FontBold6=0 FontItalic6=0 FontName7=Symbol FontSize7=8 FontBold7=0 FontItalic7=0 LabelColor1=45913 LabelSize1=8 LabelColor2=6291647 LabelSize2=8 LabelColor3=8388736 LabelSize3=8 LabelColor4=8421440 LabelSize4=6 LabelColor5=33023 LabelSize5=8 LabelColor6=8929847 LabelSize6=8 LabelColor7=8421504 LabelSize7=8 LabelColor8=8454143 LabelSize8=9
[grid] ShowCRose=0 CRoseSz=80 HourGridSpacing0=0.00555555555555 HourGridSpacing1=0.00833333333333 HourGridSpacing2=0.01666666666666 HourGridSpacing3=0.03333333333333 HourGridSpacing4=0.08333333333333 HourGridSpacing5=0.25 HourGridSpacing6=0.5 HourGridSpacing7=1 HourGridSpacing8=1 HourGridSpacing9=2 HourGridSpacing10=2 DegreeGridSpacing0=0.08333333332996 DegreeGridSpacing1=0.16666666667004 DegreeGridSpacing2=0.33333333332996 DegreeGridSpacing3=0.5 DegreeGridSpacing4=1 DegreeGridSpacing5=2 DegreeGridSpacing6=5 DegreeGridSpacing7=10 DegreeGridSpacing8=15 DegreeGridSpacing9=20 DegreeGridSpacing10=20
[Finder] ShowCircle=0 Circle1=360 Circle2=120 Circle3=30 Circle4=18 Circle5=26.5 Circle6=17.5 Circle7=0 Circle8=0 Circle9=0 Circle10=0 CircleR1=0 CircleR2=0 CircleR3=0 CircleR4=45 CircleR5=0 CircleR6=0 CircleR7=0 CircleR8=0 CircleR9=0 CircleR10=0 CircleOffset1=0 CircleOffset2=0 CircleOffset3=0 CircleOffset4=30 CircleOffset5=0 CircleOffset6=0 CircleOffset7=0 CircleOffset8=0 CircleOffset9=0 CircleOffset10=0 ShowCircle1=1 ShowCircle2=0 ShowCircle3=0 ShowCircle4=0 ShowCircle5=0 ShowCircle6=0 ShowCircle7=0 ShowCircle8=0 ShowCircle9=0 ShowCircle10=0 CircleLbl1=Telrad CircleLbl2= CircleLbl3= CircleLbl4=Off-Axis guider CircleLbl5=ST7 autoguider area CircleLbl6=ST7 autoguider area CircleLbl7= CircleLbl8= CircleLbl9= CircleLbl10= RectangleW1=11.8000001907349 RectangleW2=4.5 RectangleW3=0 RectangleW4=0 RectangleW5=0 RectangleW6=0 RectangleW7=0 RectangleW8=0 RectangleW9=0 RectangleW10=0 RectangleH1=7.90000009536743 RectangleH2=4.5 RectangleH3=0 RectangleH4=0 RectangleH5=0 RectangleH6=0 RectangleH7=0 RectangleH8=0 RectangleH9=0 RectangleH10=0 RectangleR1=0 RectangleR2=0 RectangleR3=0 RectangleR4=0 RectangleR5=0 RectangleR6=0 RectangleR7=0 RectangleR8=0 RectangleR9=0 RectangleR10=0 RectangleOffset1=0 RectangleOffset2=11 RectangleOffset3=0 RectangleOffset4=0 RectangleOffset5=0 RectangleOffset6=0 RectangleOffset7=0 RectangleOffset8=0 RectangleOffset9=0 RectangleOffset10=0 ShowRectangle1=0 ShowRectangle2=0 ShowRectangle3=0 ShowRectangle4=0 ShowRectangle5=0 ShowRectangle6=0 ShowRectangle7=0 ShowRectangle8=0 ShowRectangle9=0 ShowRectangle10=0 RectangleLbl1=KAF400 prime focus RectangleLbl2=ST7 autoguider RectangleLbl3= RectangleLbl4= RectangleLbl5= RectangleLbl6= RectangleLbl7= RectangleLbl8= RectangleLbl9= RectangleLbl10=
[chart] EquinoxType=1 EquinoxChart=2000.0 DefaultJDchart=2451543.5
[default_chart] racentre=0.21442993598521 decentre=1.00916595057669 acentre=2.45048098901928 hcentre=0.77591477082203 fov=0.00321956420359 theta=0 projtype=A ProjPole=0 FlipX=1 FlipY=1 CoordExpertMode=1 PMon=1 YPMon=0 DrawPMon=0 ApparentPos=1 CoordType=0 DrawPMyear=5000 horizonopaque=1 ShowHorizon=1 FillHorizon=1 ShowHorizonDepression=0 ShowEqGrid=1 ShowLabelAll=1 EditLabels=0 ShowGrid=0 ShowGridNum=1 ShowConstL=0 ShowConstB=1 ShowEcliptic=0 ShowGalactic=0 ShowMilkyWay=1 FillMilkyWay=1 ShowPluto=1 ShowPlanet=1 ShowAsteroid=0 ShowComet=1 ShowImages=0 ShowStars=1 ShowNebulae=1 ShowLine=1 ShowBackgroundImage=0 BackgroundImage=C:\Documents and Settings\Administrator\Local Settings\Application Data\Skychart\pictures\ AstSymbol=0 AstmagMax=18 AstmagDiff=6 ComSymbol=1 CommagMax=18 CommagDiff=4 MagLabel=0 NameLabel=1 DrawAllStarLabel=0 ConstFullLabel=1 ConstLatinLabel=0 PlanetParalaxe=1 ShowEarthShadow=0 GRSlongitude=92 StyleGrid=0 StyleEqGrid=0 StyleConstL=0 StyleConstB=0 StyleEcliptic=0 StyleGalEq=0 Simnb=1 SimLabel=1 SimNameLabel=1 SimDateLabel=1 SimDateYear=1 SimDateMonth=1 SimDateDay=1 SimDateHour=1 SimDateMinute=1 SimDateSecond=0 SimMagLabel=0 SimD=1 SimH=0 SimM=0 SimS=0 SimLine=1 SimObject1=1 SimObject2=1 SimObject3=1 SimObject4=1 SimObject5=1 SimObject6=1 SimObject7=1 SimObject8=1 SimObject9=1 SimObject10=1 SimObject11=1 SimObject12=1 SimObject13=1 ShowLabel1=1 LabelMag1=4 ShowLabel2=1 LabelMag2=4 ShowLabel3=0 LabelMag3=4 ShowLabel4=1 LabelMag4=4 ShowLabel5=1 LabelMag5=2 ShowLabel6=1 LabelMag6=4 ShowLabel7=1 LabelMag7=4 ShowLabel8=1 LabelMag8=4 ChartWidth=1652 ChartHeight=948 ChartTop=0 Chartleft=0 ChartMaximized=1
[observatory] ObsLatitude=12.3456 ObsLongitude=76.5432 ObsAltitude=345 ObsTemperature=10 ObsPressure=1010 ObsName=Random Place ObsCountry=No Country for Old Men ObsTZ=America/New_York countrytz=1
[date] UseSystemTime=1 CurYear=2009 CurMonth=11 CurDay=4 CurTime=2.44345083326334 autorefresh=1 Force_DT_UT=0 DT_UT_val=0.01833694444444
[projection] ProjName1=ARC ProjName2=ARC ProjName3=ARC ProjName4=ARC ProjName5=ARC ProjName6=ARC ProjName7=ARC ProjName8=ARC ProjName9=ARC ProjName10=ARC
[custom_labels] poslabels=0 numlabels=0
[icon] Icon_action=1 Icon_type=0 Icon_bg=-2147483633 Icon_text=-2147483630 Icon_textsize=7 Icon_info=4 clockposx=1225 clockposy=1002 calposx=-1 calposy=-1
[labels] poslabels=0 numlabels=0
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Now I know why I stick to MegaStar.
This is way beyond my computer skills; Dan, you are a genius on the computer!
-------------------- Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory, #2
deSitter
Reged: 12/09/04
Not really just copy/paste this file into Notepad and save it as skycharts.ini and overwrite your existing one. Ask for help if you need it!
-drl
