Privacy Policy |
Please read our Terms
of Service | Signup and
skysurfer
Reged: 10/05/09
Most binos are not equipped with eyecups the rubber shells on the eyepieces preventing glare coming between your eyes and the eyepieces which are detrimental for the vision of faint objects. I used an old inner rubber tube for bike tyres and cut it into pieces and glued it together with so-called 'contact-glue' and wrapped them over the eyepieces. The pieces should have a length of pi * the outer diameter of the EP + 2cm overlap. The width can be 1-1.5 cm with a bulge of 3 cm wide and ca 5cm long. When wrapped over the EPs the bulges should be on the outer ends of the EPs as there normally the glare comes in. It works great ! Even in more lighted environments you can observe the stars without glare. The only thing is when you focus-adjust the right EP individually, re-rotate the eyecup so that the bulge is on the right.
-------------------- Two eyes (5-7mm in full darkness)
TS 15x70mm binos
TeleVue Genesis 100mm f=500mm
Orion XT-10i 250mm f=1200mm
Canon EOS 40 w/85mm f/1.8, 50mm macro f/2,5
eklf
Reged: 05/12/07
Loc: Carrboro, NC
Similar items are commercially available - called winged eyeguards. Scopestuff sells for $3.50 a piece. They can be a tight fit on some oculars but they work.
-------------------- Clear Skies/Kumar
Mike Lynch
Reged: 04/07/06
Good idea! While I've not resorted to this creative DIY approach, I HAVE added a pair of the "winged" eyecups to my 20 x 80's. As you indicated, these glare shields can make a big difference if there is ground-level lighting in your observing area.
Mike Lynch Frankfort KY USA
pcad
Reged: 01/17/05
Loc: Connecticut
Old bicycle tubes! I love it, thanks!
-------------------- Peter
Telescopes 25 - 318 mm
Binoculars 15 - 88 mm
Microscope 50x - 1000x
Joe Lalumia
Reged: 01/24/07
Loc: Rockwall, Texas, USA
Are those RECYCLED tubes?
-------------------- LX90 8" LNT, SV Nighthawk & TelePOD, SV 80/9D & M4 mount, ETX 90, Orion XT10i, 20x80 binoculars, SV-BV3s-- www.texasastro.org
"Great minds discuss ideas;Average minds discuss events;Small minds discuss people." Unknown
Gordon Rayner
Reged: 03/24/07
I have made winged cups (shown in a previous post) from the foamed polyethylene pipe insulation sold at home repair warehouse stores. A sharp knife and/or scissors and a few minutes of experimentation should achieve a correct wing angle and front to back thickness.
The insulation comes with an axial split line. The pipe can expand ( or contract, if you widen the width of the split) to fit a range of eyepiece diameters.
9 registered and 6 anonymous users are browsing this forum.
Moderator: EdZ
