lionel
Reged: 08/12/07
Loc: Delaware
Re: CGEM vs Vixen Sphinx SXD new [Re: Texas]
      #3426346 - 11/02/09 10:04 PM
Actually I was only looking for capabilities that seem pretty basic in a goto mount these days. Two that would be very helpful are a way to correct or remove a bad alignment point from the goto algorithm, and a data entry field for inputting RA and DEC coordinates.
Like you I "make do" with the Starbook.
Lionel
Tak Mewlon 250
Powerstar C8
1960s Bushnell 60mm f12 refractor
Sphinx SXD
CG5-ASGT
FoxTrot
Reged: 06/01/06
Loc: Melbourne, Australia
      #3426633 - 11/03/09 12:16 AM
Lionel, Texas, thanks for the insightful comments. Mechanically, the SXW looks and sounds beautiful, but its the software that needs work. I thought StarBook looked nice a few years ago when it came out, but I agree with a previous comment that (IMHO) it seems to have dated rather quickly. Vixen just don't seem that interested in pushing its boundaries, which is really disappointing. I'll say it again my perfect mount, in this level/price bracket, would be the SXD coupled with the Nextstar or Autostar II controllers.
PS: BobH, please tell us which way you decide! Fox
GaryML
Reged: 02/16/09
Loc: San Diego, California
Re: CGEM vs Vixen Sphinx SXD [Re: Siguy]
      #3427873 - 11/03/09 05:05 PM
The CGE holds 65 pounds and is made in the USA. The Sphinx holds 33 pounds and while I'm not positive, I'm pretty sure it's made in China. So it's roughly equivalent to the $1500 HEQ6/Atlas EQ-G mount.
Just to set the record straight, the Vixen Sphinx mounts (SXW & SXD) are made in Japan. I recently saw a new Vixen HAL-130 tripod that was marked made in China, but the mount itself is Japanese.
The O.P. was considering a CGEM mount which is made in China by Synta and is mechanically similar to the HEQ6/Atlas EQ-G mounts. The CGE and CGE Pro mounts are made in the U.S., but are much heavier and more expensive than the mounts being considered by the O.P.
I used a Vixen Sphinx mount for a short while while waiting for my CG-5 ASGT to be repaired. The Starbook is certainly more advanced in design than the Celestron hand controller: e.g., it uses an Ethernet network port for updates rather than the slow and outdated RS-232 serial port used by the Celestron. Installing the newest firmware allows the LCD screen to be set dimmer as compared to the original firmware, but a color LCD screen can be a problem in terms of night vision in very dark locations. I found the gotos somewhat more accurate with my CG-5 (when it worked) as compared to the Vixen, but the difference was not dramatic. Certainly the mechanical build quality of the Vixen was superior to the Chinese-made mounts.
Sky conditions in San Diego, California:
Vixen VMC200L 8" corrected Cassegrain telescope on a Celestron CG-5 Advanced Series GT mount
Pentax eyepieces and Televue eyepieces & diagonal
Fujinon 16x70 Binoculars on a Manfrotto 028B/501HDV tripod
Celestron SkyScout
______________________________________________________
Avatar: Gemini North on Mauna Kea, November, 2008.
BobH
Reged: 01/03/08
Loc: PA
      #3429916 - 11/04/09 09:05 PM
As for as the folks who really have a hunger to view all 64k objects in the Meade db, or want/need certain features, or have an interest in AP, then yeah, the Starbook is gonna disappoint...
Thanks, Tex, I heard enough. Vixen is out. Too bad someone can't combine Meade-equivlent database with a quality mount.
Bob
"Wise men learn more from fools than fools from the wise." - Cato the Elder
Meade 8" LX200 GPS
ETX 125 PE
Tasco 50mm x 600mm
StellarVue 115ST on MiniTower
Orion Astroview 100
Celestron 8x42 Outland LX
'03 Harley FXDL (oops, wrong forum)
5 registered and 6 anonymous users are browsing this forum.
