DrBuck
Reged: 12/10/08
Loc: Susanville, No. Calif.
CGE POLAR ALIGNMENT new
      #3425323 - 11/02/09 11:23 AM
Ever try to precisely align your CGE with the supplied Allen Wrenches?? Good Luck---I bought an allenwrench socket adapter with 1/4 inch drive and then used an 18 inch piece of 4130 chromolly steel tubing to use as a cheater bar. It gives you precision that you just can't get using the wrenches alone.
DrBuck
Roll off Roof Observatory,
CGE on concrete and steel pier
Takahashi FS 152 Fluorite apo refractor
Televue 85MM Apochromatic refractor
12 inch LX 200 gps smt uhtc
Nikon D-90 with 18-200mm AF VR lens
Canon 15x50 IS Binoculars
http://www.flickr.com/photos/697650grr/?saved=1
lambermo
Reged: 07/16/07
Loc: .nl
Re: CGE POLAR ALIGNMENT new [Re: DrBuck]
      #3427431 - 11/03/09 01:13 PM
...allenwrench socket adapter with 1/4 inch drive and then used an 18 inch piece of 4130 chromolly steel tubing to use as a cheater bar...
Sounds interesting. Can you post a picture of that ?
-- Hans
DrBuck
Reged: 12/10/08
Re: CGE POLAR ALIGNMENT new [Re: lambermo]
      #3427645 - 11/03/09 03:00 PM Attachment (15 downloads)
this is the setup adjusting altitude
DrBuck
DrBuck
Reged: 12/10/08
      #3427651 - 11/03/09 03:02 PM Attachment (13 downloads)
this is the setup adjusting azimuth---------it really makes it much much easier and precise.
DrBuck
Dixie
Reged: 03/30/06
Loc: UK Latitude 53.3 north
      #3427675 - 11/03/09 03:21 PM
How do you cope with the mount slightly moving when you tighten both Az bolts and those on the dec? Lesson in fustration for me.
Cheers
Dix
DrBuck
Reged: 12/10/08
Re: CGE POLAR ALIGNMENT [Re: Dixie]
      #3427966 - 11/03/09 06:04 PM
with this tool, you only have to loosen the ax knobs slightly and then there is no movement when they are tightened up again.
DrBuck
Alph
Reged: 11/23/06
Loc: Melmac
      #3428440 - 11/03/09 11:24 PM
It would help if you provided link(s) to your parts source.
DrBuck
Reged: 12/10/08
Re: CGE POLAR ALIGNMENT new [Re: Alph]
      #3429018 - 11/04/09 11:19 AM
Well, I just got them from my shop. The socket adapter was purchased from Ace hardware. The tubing was purchased from Aircraft spruce in southern california when I was building my biplane. Any steel tubing will work as long as it fits over the handle of the 1/4 inch socket handle. If ace hardware doesn't have the tubing, any welding shop should have it. You could get sophisticated and drill thru the tubing and the handle and use a bolt or pin to hold them together, but I found that it wasn't really necessary.
DrBuck
10 registered and 12 anonymous users are browsing this forum.
