Privacy Policy |
Please read our Terms
of Service | Signup and
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
if the Lumicon UHC only lets through the OIII & H-beta lines, then is there any gain in owning an OIII, which cuts out the H-beta?
i am thinking if the object being viewed is say a planetary, and only emmiting OIII and no H-beta, would there be anything to gain with the OIII over the UHC?
thanks, david
MitchAlsup
Reged: 08/31/09
Stars emit broad band light.
The OIII filter, all by itself, will dim the stars more than a UHC, so it might be easier to see the nebulae. The brightness of the nebulae, itself, will not be changed, just its contrast relative to the rest of the illumination in the FoV.
helpwanted
Reged: 07/04/07
Loc: Phoenix, AZ
but even with the stars in the fov of the nebula, the differance is only one line of spectral light.
Tiny
Reged: 05/02/08
OIII = darker background, higher contrast and more detail [provided the proper target]. Because it blocks out pretty much everything else [its not just the difference of 1nm in the light spectrum its 13nm] it also makes finding targets easier. This is what you're paying the money for.
tatarjj
Reged: 04/20/04
Loc: Austin, TX
Well, planetary nebulae emit both H-beta and OIII, but so much more OIII than H-beta that you want to use an OIII on them in most cases. Sure it lets through less of the nebula's light, but the important part is that it vastly improves contrast.
Same with the H-beta. Some nebulae emit so much H-beta that you'll see them easier when you cut out their OIII light and vastly increase the contrast by only looking in H-beta.
-------------------- John T.
Austin, TX
25" f/4.2 Dob
18" Obsession #701
4" Stellar Vue Achromat
8X56 Binos
srwolf
Reged: 12/22/04
Loc: Edmonton, Alberta
I like having both available. Viewing a nebula with first one then the other reveals different details. It's interesting to notice the differences.
-------------------- 12.5" f/5 Portaball
8" f/6 Skywatcher Dob
Feathertouch Focuser
Telrad x 2
Crappy Binoculars
3-6 zoom,5,9,16 naglers
24,35 panoptics
13mm Ethos
Rob S
Reged: 03/16/07
Loc: NZ
Yeah, I have both too (Astronomic brand).
Frequently use the darker OIII on the 24Pan and swap that EP out for my 20XW with the UHC fitted (as the exit pupil is smaller in that EP).
Eta Carinae looks amazing in both in the 13E of course. Well, it looks good anytime.
Rob.
-------------------- 8" f5 Dob with Feathertouch
Brandon: 16
Pentax: 7, 10 & 20XW
TMB: 30 Paragon
TV: 8 & 13 Ethos;
5 & 13 NaglerT6;
24 Panoptic
Leica Trinovid 8x50 BN
Edited by Rob S (11/05/09 12:18 AM)
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Loc: Sonoma, Northern California
I have both although my OIII filters are cheaper Celestron models but they perform admirably. My Lumicon UHC is a beast on Nebula and I love it.
-------------------- Dan
20" f/5 Obsession
Antares 1529
TV102
Various Naglers, Ethos, UO Orthos and TV Plossls
The Off Fisher Lane Irregulars
Shawn H
Reged: 05/16/07
Loc: Southern France 43°56'N-4°50'E
David IMHO these are THEE 2 filters worth having, though the UHC is the all nebulae specialist & the OIII the planetary nebulae specialist! I found that each works better on different objects! And only after trying the 2 on each object can you decide!
-------------------- 18" David Lukehurst truss Dobson with Sky Commander flash 4 DSC's & Moonlite CR2 focuser & Astrocrumb filter slide
Orion xt10i fully flocked with Telrad on 4" risers & Feather Touch focuser & huge Boston Red Sox decal
The original Orion StarBlast & 15x70 Celestron Skymaster binos & Ethos & Naglers & Dobs oh my!
Orion Ultrablock narrowband filter & Astronomik OIII line filter
Tele Vue 2x Barlow & Antares 1.6x (2") Barlow
CATSEYE collimation tools, TeleGizmos Dob covers
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
If you want a rough idea of what filter to use on which object, you might want to look at the following article:
FILTER PERFORMANCE COMPARISONS FOR SOME COMMON NEBULAE
Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
Prairie Astronomy Club
http://www.prairieastronomyclub.org
7 registered and 6 anonymous users are browsing this forum.
Moderator: spaceydee, csa/montana
