dymy24
Reged: 07/28/08
Loc: Fayetteville, NC
Tired of lugging equipment in and out of the garage. Also tired of using that as an excuse not to observe. Seems a BYO is the answer, so I got started this weekend.
It'll be a Roll Off Roof. My location isn't ideal, but it is close and I'll use it often. I live in a neighborhood with streetlights, but my hous actually shields the backyard reasonably well. I have an existing 12x16 storage shed, but I don't want to tackle making the roof movable, so I'll build an 8x12 dedicated shed. I've drawn dozens of rough sketches. My current plan is 8x8 for the scope, 4x8 for a warm room of sorts. Really just a place for a table, chair, computer, etc.
Hole's dug, base is poured, pier is pretty much done. I'll start on the building on Friday.
-------------------- Astrophotograhphy novice
dymy24
Reged: 07/28/08
The light pole was free - a golf buddy had six or seven of them laying around his family's farm
Edited by dymy24 (11/03/09 09:39 PM)
dymy24
Reged: 07/28/08
Cutting it to length was a job.
dymy24
Reged: 07/28/08
Adding a top plate was easy. Carried everything to my pops house, threatened to weld it myself, sttod back and watched as he did the work.
dymy24
Reged: 07/28/08
The plate isn't as bad as the photo makes it look.
dymy24
Reged: 07/28/08
Finished the pier by 7:30 PM, couldn't not test fit it all on the base. Hate the time change - dark so early.
dymy24
Reged: 07/28/08
And as long as we're test fitting, might as well try the mount.
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Congratulations! You have made the plunge We'll be looking forward to your observatory starting to take shape!
-------------------- Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory, #2
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Well done!
-------------------- Chris
Mallincam Color Hyper Plus
10" DSH with SC DSC, CPC 800 XLT
M110 Doublet ED, AT 102Achro, ZS80FD 10th Anniv, ZS66SD, PST
CG5-AGT, EZ-Touch, Voyager
POD XL3 http://POD.SchroederCity.com
dymy24
Reged: 07/28/08
Thank you. Of course, nothing I do will be an inovation. Every feature will come from something I've learned on CloudyNights. Still, I'll post pictures and keep a log of the build - that way others can avoid my mistakes.
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
That's what this forum is all about; sharing ideas & encouraging others to keep on building! Each observatory build brings back memories of when ours was being built.
14mm Meade 4000 UWA
Digital Don
Reged: 01/20/04
Loc: Manteno
Keep up the good work!
Don
LateViewer
Reged: 11/17/05
Loc: Westchester NY
Just curious, how deep is the hole and what is that dirt? A gray clay?
-------------------- 12.5" Discovery Mirror String Truss Dob
DSV-1 Alt-Az Mount
WO 66mm Petzval
Orion 127mm Mak with WO 2" Dielectric Diagonal
C9.25"
Celestron CG-5 GoTo
8.8, 14, 18, and 24mm Meade UWA Series 5000 EP
32, 40mm Orion Optiluxe EP
Doug76
Reged: 12/05/07
Loc: SE Louisiana, future Texan
So first you dig a hole, right? -------------------------------
Yep, that's how it starts.  Then the fun really begins. I too found help here looking over others' efforts here, so mine, while not quite done, is now usable. It makes for a much more satisfying, and relaxed viewing session. You'll be glad you did it. I made mine 10x10, and will be adding a 8x8 combined warm (cool?) room/equipment storage room under the roll off rail structure.
-------------------- Doug
Truckstop Astronomer
The Universe, the light of God, in all it's majesty
6 achro refractors, 50mm-150mm
1 apo refractor, 90mm
1 SCT, 8 inch
UO Abbe Volcano Tops
Faworski Ortho's
Panoptic 24mm
Carton 100mm f/13 under construction
f29pc
Reged: 05/23/05
Loc: Maine
Yep, but you have to dig a BIG hole!!!
Good luck, your going to love it.
Paul
-------------------- 12" LX200 UHTC OTA
10" LX200 EMC
WO 105mm APO, 80mm APO, 66mm APO
MI250
Next day air makes every night X-mas eve!
www.burkesobservatory.com
Edited by f29pc (11/05/09 09:26 PM)
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Now, that's gonna be a big pier!
14mm Meade 4000 UWA
dymy24
Reged: 07/28/08
Good luck, your going to love it. Paul
In that photo, the hole is about 2 feet deep and round. The final hole, ready for the pour, was 3.5 feet square along the base, tapered to two feet square at the top. The soil is fairly loose black earth. We have no frost line here.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
I don't know there. You factor in wall thicknesses and 8x8 is going to be too small. You'll learn the hard way like many others. Doen't cost much more to go with an absolute 10x10 minimum. Rethink it I think you might reconsider. Mike
-------------------- 7x35 and 10x50 sears tower binocs, 3" f/10 edmunds reflector, 2.4" f/11.7 manon refractor, 6" f/8 jaegers refractor, "The 8 Ball" 8" f/13.3 brandt refractor, 3" f/15.8 sans&streiffe refractor, 3.1" f/15 selsi refractor(towa 339), 2.4" f/15 sears refractor, selsi 30x30mm spyglass, criterion 5-draw 25x45x75x spyglass(1957), 4.25" f/14.8 tasco 20te.
dymy24
Reged: 07/28/08
You might be right. I know it'll be close. Unfortunately, I have space and size constraints. In any event, I framed the floor today, so it would involve some work and additional expense to start over.
LateViewer
Reged: 11/17/05
Loc: Westchester NY
8*8,is what I have and I wish I could have built larger but 8*8 was the max I could build without a building permit.
I think you find after the basic construction that you start to "fit" the observatory to you personally with shelves etc.
DSV-1 Alt-Az Mount
WO 66mm Petzval
C9.25"
Celestron CG-5 GoTo
