desertrefugee
Reged: 08/06/07
Loc: Arizona
An Old Widefield - 2" 40mm Orion Ultrascan
      #3428415 - 11/03/09 11:11 PM Attachment (15 downloads)
I posted once before on this EP and there wasn't much chatter over it. I'll try again and not bring it up again.
Does anyone have any of these and what is your opinion on them? They were well-regarded when new, but at that time, not too many folks had splurged on TeleVue. That has changed now for sure. I can say that it definitely does not perform well on faster scopes. It is positively rotten on my f4.9 newt, but marginally better on an f5 ST120.
I have not tried it on a slower cat, but suspect that it might be decent in that application.
Can anyone confirm?
"Illimitable ocean, without bound, Without dimension, where length, breadth, and height, And time, and place are lost." - Milton
-Darrell
Reflectors - 76 to 305mm (f4.7 to f9.2)
Refractors - 50 to 120mm (f5 to f16.7)
Binoculars - 6x15 to 22x100
N. Phoenix, AZ
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: An Old Widefield - 2" 40mm Orion Ultrascan new [Re: desertrefugee]
      #3429851 - 11/04/09 08:26 PM
Used to own one back in the early '90s, and employed on an Astrophysics Star 12 (120mm f/8.5). I recall that it worked well, and I liked it primarily for its close-to-maximum field stop diameter for a 2" eyepiece. It delivered nearly the same FOV as a TV 55 Plossl, but the higher magnification and much larger AFoV were more desirable.
I sold it to the same friend for whom I made a 5" f/5 bino. He located another 40mm and just loves the big, bright view.
As for myself, I'd probably donate a lesser-used organ for a pair of the Ultrascan 30mm jobbies!
Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
      #3431050 - 11/05/09 01:03 PM
I has a couple of Ultrascans back in the day. Recently I sold the last remaining example I owned; a 9mm 1.25".
My impression was (a) nice and sharp on-axis, (b) not so nice at the edge of the field in faster scopes, and (c) make-your-eyeball-bleed short eye relief. I would estimate <2mm eye relief on the 9mm.
"I do not know what I may appear to the world; but to myself I seem to have been only like a boy playing on the seashore, and diverting myself in now and then finding a smoother pebble or a prettier shell than ordinary, whilst the great ocean of truth lay all undiscovered before me."
- Sir Issac Newton
desertrefugee
Reged: 08/06/07
Loc: Arizona
Re: An Old Widefield - 2" 40mm Orion Ultrascan new [Re: jrbarnett]
      #3433770 - 11/06/09 09:10 PM
Thanks, guys. I suspect I'll hold onto it. I will say that, even on the faster scopes, it does provide sharp views over ~75% of the field. It's just that outside 25...
Anyway, if nothing else, it makes a great object finder EP. And if I ever get that C14 with 2" Feathertouch . . .
-Darrell
N. Phoenix, AZ
JayKSC
Reged: 01/01/05
Loc: Florida
      #3433894 - 11/06/09 10:38 PM
While I've not seen or used an Ultrascan, I had a somewhat similar Meade 40mm "Extra Wide Field" that dated to the 1980's. I sold it for what probably was a bargain a couple of years ago, though regret it a little. These older widefield oculars are sought-out by some who have a nostalgia. Then, I recall in a long conversation I had with a fellow amateur that (from his opinion) sometimes older (simpler) optical designs can perform surprisingly well against newer designs that use many elements.
- Jay
South Florida
Refractor manic.
My Sketches
21 registered and 12 anonymous users are browsing this forum.
Moderator:  Greg K., Jason B, csa/montana
