Privacy Policy |
Please read our Terms
of Service | Signup and
Jarad
Reged: 04/28/03
Loc: Atlanta, GA
Still, an object in earth orbit is a rotating frame. That it is rotating can be discerned by experiment within the frame. Can a rotating frame truly be a 'rest frame'?
Not necessarily. If the spacecraft is rotating to keep the same side facing the earth as it orbits, then it is a rotating frame. But if it does not rotate as it orbits, it is not a rotating frame. For example, the Hubble Space Telescope does not rotate - if it did, the "frame" of the CCD camera would have star trails like a shot of the sky from a fixed tripod on earth. It keeps it orientation relative to the stars, and is a non-rotating rest frame.
An orbiting object is not an inertial frame of reference relative to the planet itself.
There is a difference between inertial frames and rest frames. Two frames can both be rest frames, but not at rest relative to each other. You could also have non-rest frames that are at rest relative to each other (for example, a car on the highway going parallel to a train on a track at the same speed).
Jarad
Edited by Jarad (11/03/09 03:23 PM)
hwhall
Reged: 09/22/08
Doh! I should have remembered that.
0 registered and 2 anonymous users are browsing this forum.
Moderator: LivingNDixie, Shadowalker, llanitedave
