Pages: 1 | 2 | 3 | (show all)
Strix2
Reged: 06/25/09
Loc: southern Chile (Osorno)
Re: B&L 4000 SCT, help needed... new [Re: stevew]
      #3393913 - 10/16/09 11:57 PM Attachment (18 downloads)
Steve,
you are right... Under down, we have some rural spots with really dark skies. Actually, you need a telescope only forr details. Most the time, I use only my eyes (ample FOV) and a Zeiss bino. Just to illustrate my skies quality, attached is a shot got with a little Canon digital camera from the porch of my seashore shack. Using some imagination and kin eyes you'll be able to identify Scorpius. The star pattern looks as an mirrored question mark... Right now I've stopped to check the B&L mount drive, which works as new and is tracking like a pro. Because that I'm sure that I'll be able to get better pictures.
Best regards,
Strix
http://www.cloudynights.com/item.php?item_id=1117
PARAPHERNALIA:
a) Homemade stuff: 3" f/12 reflector; 4.5" f/12 reflector; 80mm f/11 refractor; 80mm f/5 refractor; 83mm f/12 refractor Astrix-Jaegers; 8" f/4 astrograph (on work).
b) Factory-made: Unitron 102mm f/15 refractor; Zeiss Jenoptem 10x50 binos; Jenoptik 10x30 binos; B&L Criterion 4000 SCT (on repair).
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: B&L 4000 SCT, help needed... new [Re: Strix2]
      #3416958 - 10/28/09 09:11 PM
Strix,
Back in '85 I owned one of these B&L 4000's. It was optically better than a Meade 4" SCT I also had at the same time. As for using the mount for imaging, I suspect that you might be limited to normal or perhaps telehhoto lens focal lengths. If I recall rightly, the drive was crude by today's standards, in that it used an AC synchronous 'timing' motor and spur gears. Lots of backlash, and I suspect bad periodic error.
Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
Strix2
Reged: 06/25/09
Re: B&L 4000 SCT, help needed... new [Re: GlennLeDrew]
      #3417898 - 10/29/09 10:21 AM
Glenn,
thanks for your comments. I've been playing with the OTA somewhat and, as I've not found a suitable corrector plate yet, I'm thinking to "design" a sub-aperture corrector. I have some spare lenses in my AAA (Atelier Astronomique Australe, the pig's den in wifey's concept) thus, by trial-and-error, something suitable could arise... Currently, the views aren't entirely horrible, bright objects such as Luna and Jupiter are surrounded by a not subtle halo, seeming that the object's "energy" is spreading, but I'm able to see some details such as moon craters and Jupiter's banding. Do you have some ideas regarding a sort of sub-aperture corrector for this critter?? (I've read your personal info ). On regards to imaging I'm only trying to get some normal or afocal shots with my humble Canon a570is, conveniently tweaked with CHDK software. The mount is in pretty good condition. Indeed, when first connected to energy, it didn't work at all. I disassembled the base only to find that motor's wiring were not connected to the power supply. Wiring, electrical parts, gears and so on looked brand new, as if never were used. Fortunately, the mount works smoothly and there's no backlash at all, thus short exposures will be fine, I hope...
Thanks again for your opinions,
Clear skies,
Strix
PARAPHERNALIA:
memento
Reged: 08/19/08
Loc: 51N 7E
      #3418193 - 10/29/09 12:49 PM
Hello there,
probably these guys also make new corrector plates for small scopes?
http://shop.ebay.de/diy_dkd/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Of course they are not specifically matched to this particular B&L Criterion but probably it's part of the fun to see if one can match something working together?
Or just look at ebay for a somewhat broken other 4" SCT or something similar...
kind regards,
Thomas
Celestron C90 Astro
Meade 2080 LX3
Strix2
Reged: 06/25/09
Re: B&L 4000 SCT, help needed... new [Re: memento]
      #3419751 - 10/30/09 08:32 AM
Hello Thomas,
Thanks for the thread. Mmmh... some refractor objectives look really appetizing (aperture fever...) but the EUR price is rather discouraging... I prefer to save some coins to get a classic Zeiss scope that I'm looking for... I have an eye on evil-bay for a B&L 4000 sct, but also I'm trying some sort of sub-aperture corrector... Some promising progress swaping lenses... Seems that a combination of a negative meniscus plus a PCX works fairly well, but also I'm thinking about a positive meniscus lens that I've "stored" somewhere (where's the (#!!&%·$?*!!!!% lens????). Also, I'm building a spider with four very thin vanes to install the secondary... Well, I will do my best to redeem this little scope!!!
Strix
PARAPHERNALIA:
GlennLeDrew
Reged: 06/18/08
      #3426527 - 11/02/09 11:33 PM
Strix,
Because the primary is such a short focal length sphere, it generates horrible amounts of spherical aberration, as you've seen. Any corrector will have to compensate by introducing the opposite form of spherical aberration. This is what the full-aperture corrector plate did. Even though it was but a single element, its location *before* the primary results in a net zero power. This keeps chromatic aberration to a minimum.
Obtaining this to a good enough degree with even a large sample of sub-aperture lenses to choose from will most probably not work. A small corrector made from spherical lenses will have to have significant optical power, and so chromatic aberrations will rear their ugly heads and must in their turn be dealt with. So even if by accident the spherical aberration was reasonably well negated by a cobbled-up sub-aperture corrector, one or more aberrations will be prominent, such as longitudinal chromatic aberration, astigmatism and lateral color, to name a few.
If nothing else, you'll begin to obtain some understanding of optics as you experiment! And there's nothing like going hands-on to accelerate the learning process.
My Gallery
deSitter
Reged: 12/09/04
      #3426669 - 11/03/09 12:34 AM
Strix,
Without the corrector an SCT is equivalent to a sphere of comparable focal length. Since this is 4" f/12 it should be OK. I'm repairing one of these and I can't determine any curve to the corrector after careful inspection. It's not even coated. I think it's just an off-the-shelf plate glass optical window (at least in the spotting scope edition).
-drl
memento
Reged: 08/19/08
Loc: 51N 7E
Re: B&L 4000 SCT, help needed... new [Re: deSitter]
      #3427079 - 11/03/09 09:50 AM
As far as I understand SCT optics, the primary mirror is a 4" f/2 or f/2.5 or something like this. (The focal length of primary mirror is roughly equal to the length of the tube !!)
.... so the optical problems are comparable to a 4" f/2 or f/2.5 spherical mirror and NOT to a 4" f/12.
f/12 is only achieved through the secondary mirror but this does not help at all to avoid the problems of the ultra-fast primary. These problems are addressed solely by the Schmidt corrector at the front.
I remember somewhere having seen a thread where a guy did make a Schmidt corrector plate on his own, like when making your own mirrors. But I can imagine it's an awfully complicated job to get it right?
I don't know how modern lens correctors work. There are all these fancy new things like e.g. ccd cameras that can be attached in place of the secondary mirror of e.g. C8 and the like, these attachments also have some kind of glass correctors and work very well.
Probably the easiest / cheapest way of them all would be to source a Schmidt or Maksutov front glass of a broken little other telescope and just experiment with the results?
regards
Thomas
Celestron C90 Astro
Meade 2080 LX3
tim53
Reged: 12/17/04
Loc: Highland Park, CA
      #3427150 - 11/03/09 10:43 AM
Without the corrector, this OTA is only suitable for parts.
If you can't find another Criterion OTA, How about adapting a Meade 2045 OTA or an ETX OTA to fit the fork mount you have?
-Tim.
"We`re just waiting looking skyward as the days come down.
Someone promised there`d be answers, if we stayed around."
-Orchestral Maneuvers in the Dark, "The Romance of the Telescope"
Strix2
Reged: 06/25/09
      #3427935 - 11/03/09 05:48 PM Attachment (3 downloads)
Glenn, thanks for your comments. You’re right, experimenting is crucial for a sound learning process. But as I’ve posted before, the views aren’t so terrible. The views of planets (Jupiter) and moon, and to a less degree stars, aren’t really bad. Some banding and craters can be seen. The problem is a fuzzy whitish halo around objects, no deformations at all. For short tubes SCT’s as the B&L, if I’m right a f/2 primary and a secondary with a negative focal ratio of f/6 yields a system focal ratio of f/12.0. Actually, if the system is f/12, and as Danny pointed out it should be OK (I’ve builted a f/8 newtonian using a spherical primary and views are OK), but looking at some ray tracing on a fast mirror it’s clear enough that peripheral rays never get into focus thus spherical aberration arises. But, if the system is f/12 means that the secondary mirror does its work. BTW, I’ve never seen a B&L corrector plate but I’ve seen some shots of the corrector plates of this same telescope and it look really flat (search for Bausch on CN classifieds and you can see one or two examples showing that the front of the corrector plate is straight flat, judging for the reflection). Being a really fast primary mirror, Danny’s observation about the lack of a noticeable curve of the corrector confuses me, because I’m expecting (fruits of my experiments) that the corrector’s figure must be, if not strong, noticeable negative. Worst, I’ve read that a Schmidt corrector is mounted with the flat side toward the mirror!!! So, does B&L 4000 criterion have, at all, a real Schmidt corrector plate or “it’s just an off-the-shelf plate glass optical window” as Danny pointed out? This could explain the “raving” comments of Uncle Rod about this little scope…
Perhaps Thomas is right, getting the corrector plate from other small telescope and perform some experiments could be nice… Also, Tim’s suggestion about the “adoption” of other small SCT to use the mount is feasible, but being at the end of the world I fear that both options are not practicable… Although our custom officers are really honest (nothing is lost) they ask for their share and don’t show any mercy. Only gifts escape (sometimes) of being burdened with taxes. Anyway, I’ve have another question to you all, dear “Cat” lovers… As I’m thinking to build a thin four vane spider to continue my experiments, it is really critical to set the secondary mirror mount in the same original place were the corrector is supposed to be??? Currently, as you can observe in the attached image, the secondary mirror is well buried into the tube, near the primary baffle. I’m suspecting there’s some vignetting or it dissapear while focusing?
Thanks in advance. A really disconcerted SCT Optics 101 student gives you all his best regards….
Strix
PARAPHERNALIA:
deSitter
Reged: 12/09/04
      #3428513 - 11/04/09 12:20 AM
The scope I am repairing definitely had an optical window and not a corrector. I confirmed this by interposing some of the broken pieces between my eye and an out of focus star in another scope. No change and the glass was moved to and fro.
Without any Schmidt correction, this scope is basically a Mak without any SA or coma correction.
I'm still doing the repair so when I'm done (gotta get to a drill press!) I'll do some detailed analysis of what I see. It's funny to see this weird scope that was so unloved get so much attention. Actually the one I'm fixing is very well made mechanically at least. If the optics were good it would make a great camping scope.
-drl
Strix
tim53
Reged: 12/17/04
      #3428521 - 11/04/09 12:27 AM
No way the correctors are simple windows.
The "system" without the corrector may be f/12, but lacking the corrector makes it no different from a f/2 Newt with a spherical mirror and a barlow lens for magnification.
SCT correctors aren't strongly curved on either side, so they can look as though they're simple windows.
If it were me, I'd buy one of the scopes that crops up on ebay, astromart, or CN's classifieds semi-regularly and use the best parts from it and the one you have.
In my opinion, you're wasting your time "experimenting" with secondary supports without a corrector.
best,
-Tim.
deSitter
Reged: 12/09/04
Re: B&L 4000 SCT, help needed... new [Re: tim53]
      #3428561 - 11/04/09 01:08 AM
Not my scope, so I'm just finishing the job.. but you make a good point, the resulting system will be like one of those shorty Newts - which aren't that bad really if the primary is good. The mirror on this scope is more like f/3.
-drl
tim53
Reged: 12/17/04
      #3428601 - 11/04/09 02:28 AM
Still, the SCT has a sphere, whereas a shorty Newt will have a parabola.
deSitter
Reged: 12/09/04
      #3428755 - 11/04/09 07:41 AM
Negative, those short Newtonians (but not the Orion Starblast) are usually f/4 spheres + achromat in the focuser for f/8 equivalent system, and it performs like an f/8 sphere in terms of SA but not in terms of edge astigmatism. So the spherical correction is the same, which is what I expect here (fuzzy outfield at low power). The true Jones-Bird scope adds sub-aperture elements to correct the edge and remove the remaining SA.
-drl
Strix2
Reged: 06/25/09
      #3428762 - 11/04/09 07:47 AM
Danny,
you have the same perception: this little scope is very well made and it's a shame not doing some efforts to get it fixed (the best we can...).
Tim,
being a self-proclaimed ATM genius (don't expect the endowment of such an illustrious title from others ) while "experimenting" I'm not wasting my time. On the contrary, I'm enjoying the hobby at its best. As somebody pointed out: building a scope is the best of two worlds: you have a tool to enjoy the wonders of the sky and you always can tweak it to improve its performance .
Best regards,
Strix
PARAPHERNALIA:
memento
Reged: 08/19/08
Loc: 51N 7E
Re: B&L 4000 SCT, help needed... [Re: Strix2]
      #3429126 - 11/04/09 12:21 PM
Hi folks,
I know there have been telescopes that REALLY have just a window in front of the tube and NO schmidt plate. Here is one of those:
http://www.vega-sky-center.com/pages/VAO_Jason_Comet-Chaser_114mm_Catadioptric.html
but that has nothing to do with the B&L 4000 which really should be a Schmidt cassegrain design.
Of course it's possible to do away with the Schmidt corrector plate by making the two mirrors hyperbolic instead of spheric. Then the scope would become a Ritchey Chretien design and not need any corrector any more. But I guess that it is far away from trivial to make such a kind of mirror.
It is then much easier to make your own Schmidt corrector plate.
There is a German forum entry where a guy discusses that he has made a Schmidt plate on his own. The discussion does not go that much into details, but basically he states that it is not more complicated than making a standard telescope mirror (what many amateurs already have done):
http://www.astro-foren.de/showthread.php?t=9519
BTW I find it interesting that the secondary mirror is not only attached via the Schmidt plate. With all SCTs that I know, the secondary is just mounted in the midst of the Schmidt plate, with no additonal spider or the like.
kind regards,
Thomas
Celestron C90 Astro
Meade 2080 LX3
deSitter
Reged: 12/09/04
      #3429434 - 11/04/09 03:39 PM
You could refigure the fast primary to an ellipsoid and end up with a small Dall-Kirkham system as well.
-drl
Hi folks,
kind regards,
Thomas
deSitter
Reged: 12/09/04
      #3429443 - 11/04/09 03:41 PM
The best SCT would be one with the corrector at the radius of curvature of the primary, with zero coma, an aplanatic system like a refractor - mounting the secondary in the corrector is a compromise made for compactness.
-drl
Hi folks,
kind regards,
Thomas
GlennLeDrew
Reged: 06/18/08
      #3429896 - 11/04/09 08:52 PM
Strix,
I note that you accept the spherical aberration as being not all that bad. (And note that the fuzzy blur surrounding objects is the spherical aberration.) If you could have the aberration switched on and off instantaneously, you would really appreciate just how bad it is.
I owned both a B&L 4000 (like this one) and a Meade 4" Cass. The B&L did indeed have a Schmidt corrector, whereas I *suspect* the Meade used a simple plane parallel window, as it employed a corrector lens very close to the secondary mirror. Note that light would pass through this lens twice. I didn't like it in use, as the B&L delivered a *much* sharper image.
Interposing a Schmidt plate between eye and eyepiece will do nothing to reveal the subtle curvature, mainly because you're looking through a very small portion of it at any one time. Now, if one placed the corrector in *front of the scope*, the nasty, wicked aberration would be hard to miss!.
And I'll stress that the secondary does NOT magically fix the huge spherical aberration introduced by the primary. So the corrector-less 4000 will not work like an f/12 sphere.
The position of the secondary on that stalk-like support *may* result in it being a little too far inside the tube. If it was significantly mis-placed rearward, the position of best focus would be moved rather far from the back of the 'scope. But even if this were to be the case, it can be difficult to ascertain because the focusing mechanism moves the primary and results in an already large range of focus psition. Perhaps the actual distance range of the focal position could provide a clue....
My Gallery
3 registered and 5 anonymous users are browsing this forum.
Moderator:  Jason B, rick rian, LLEEGE
