ccs_hello
Reged: 07/03/04
ATI TV Wonder USB2 HDTV (TVW600USB) in Woot new
      #3428727 - 11/04/09 06:51 AM
(Use it in analog video capture)
Today (Wednesday) Woot is selling Diamond Multimedia/ATI
TV Wonder USB2 HDTV Stick (TVW600USB) spec here for $25 shipped.
It has Digital DTV tuner, analog tuner, S-video, and composite video input. No ClearQAM tuner though. Per spec sheet 32bit (and 64bit driver) Vista is also supported.
These usually require fairly fast machines. Additional info :
- analog video is software compressed by PC (DTV is MPEG2 already)
- Some tried on 32bit Win7 and it works.
Clear Skies!
ccs_hello
greg
Reged: 01/25/05
Loc: Central Ca.
Re: ATI TV Wonder USB2 HDTV (TVW600USB) in Woot new [Re: ccs_hello]
      #3430192 - 11/04/09 11:33 PM
It says it has...S-video input with adapter... Does that mean that it's not a true S-Video input?
Greg
Gravity is like a magnet to Humans...4 yr Old Marcus Gregory Allen Wilhite
Not tonight honey I have a Telescope... Greg Wilhite
16" F/3 Reflector GEM SiTech Servo Goto
4.5" F/4 Reflector Piggy Backed on The 16"
Meade 10" F/4 on CGE
6" F/5 Refractor
Celestron 102mm F/5
26mm T5 Nagler
13mm ETHOS
MallinCam Color Hyper Plus
9" Speco High Res. Color CRT Monitor
10' Home Dome
MallinCam Deep Space Observatory
Light polluted Backyard
Great Darksite 1.5 Hrs. Away
johnnyha
Reged: 11/12/06
Re: ATI TV Wonder USB2 HDTV (TVW600USB) in Woot new [Re: greg]
      #3430230 - 11/04/09 11:50 PM
"Capture from VCRs, camcorders with the included audio/video input cable"... Looks like a TV tuner, with other interesting possibilities...
Johnny
Spicewood, TX
Sherman Oaks, CA
ccs_hello
Reged: 07/03/04
      #3430325 - 11/05/09 01:15 AM
Greg,
Click he product picture to see the zoomed picture.
"S-video and composite video" adapter is a cable which plugs into the dongle. S-video signal is then fed into the USB stick's video AFE/digitizer IC.
Clear Skies!
ccs_hello
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: ATI TV Wonder USB2 HDTV (TVW600USB) in Woot [Re: ccs_hello]
      #3430817 - 11/05/09 11:01 AM
A year ago I purchased a very similar product from Pinnacle. I've used mine to successfully capture S-Video from my Mallincam. Fun little unit but the Pinnacle HDTV s/w isn't always the most stable. It does work better with some extra cpu and ram although my laptop with a 1.6Ghz Core2 Duo cpu does handle it just fine. If I'm manipulating the S-Video streams from the Mallincam I prefer to use my desktop (more/faster cpu, ram and video processing).
Mark
C11, C6, APM/TMB115, and AT80ED - Tandem mount CGE and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - Modded 350D, DSI-P, SPC900, Mallincam
Just because you can doesn't necessarily mean that you should
ccs_hello
Reged: 07/03/04
      #3452084 - 11/16/09 08:14 PM
Just wish to add that today I received the device. I found out that for ATSC TV viewing, the "Catalyst Media Center" (software MPEG decoder and the video driver) is not optimized for my PC (a Merom-2M Pentium Dual-Core T2370 laptop) thus display is jittery. However, when I used Microsoft's "Windows Media Center" (I have Vista Home Premium 32bit) to display DTV, even in time-delayed playback mode, it worked perfectly fine.
I'll try analog NTSC baseband video in very soon and report back.
Clear Skies!
ccs_hello
ccs_hello
Reged: 07/03/04
      #3452169 - 11/16/09 09:17 PM
Now tried baseband composite video. Now "Catalyst Media Center" worked fine and looking good/no jitter/stutter.
Also tried AMCAP which is 720*480 YUY2 (this is a form of 4:2:2 YUV, 16 bits/pixel) video display and still capture.
Clear Skies!
ccs_hello
ccs_hello
Reged: 07/03/04
      #3461523 - 11/21/09 11:25 PM
Just few updates:
1. Faster laptop with a graphics accelerator chip works better if using "Catalyst Media Center". This test machine is using WinXP.
2. The actual chipset in use is
Xceive Silicon tuner/demodulator and
video/audio decoder + ATSC media stream transport over USB2.0 (eMPIA 287x or 288x IC).
Clear Skies!
ccs_hello
1 registered and 2 anonymous users are browsing this forum.
Moderator:  Chris Schroeder
