DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
Mars 3 Nov 2009 @ 10:58UT new
      #3430125 - 11/04/09 11:02 PM Attachment (39 downloads)
Mars Nov 3 2009 10:58UT CM 282 D=8"
Imaged with C14 at f/25 with DMK21BF04. Resampled 1.6x. Seeing was fair to good but never long enough to get enough frames for a good result. Should have imaged longer as these were only 1minute avi's at 30fps for red & green and 15fps for blue. So I ended up with only 370 frames r&g and 200 for blue. Seeing artifact in the n pole area I guess, as it shows up with minimal processing of the red channel.
Glenn
Brandon 94mm f7, Televue TV102 f8.6; GM8
Baader Wedge & Filters, Coronado SM90/BF30
IM715; C11 & C14; G-11 Gemini
Freddy WILLEMS
Reged: 11/13/05
Loc: Hawaii, Honolulu
Re: Mars 3 Nov 2009 @ 10:58UT new [Re: DesertRat]
      #3430274 - 11/05/09 12:22 AM
Nice Glenn !
Gives me hope for the next imaging project.
You use a 2.5 X barlow ? That resampleing really looks good for that many frames stacked.
Freddy
Meade 14" LX200 GPS UHTC GPS on permanent pier
Celestron C 14" Peltier cooled for planetary imaging.
Meade 10" LX200 & TITAN 50:1 mount Gemini 'go to'
Meade 127 mm f/9 APO & TITAN 50:1 mount Gemini 'go to'
W/O 102 mm f/7 APO doublet
Orion 80 mm f/7 ED
DFK 21AU04.AS
ToUcam 840 II pro
Canon 10D Unmoddified
Canon 40D Hutech moddified
DesertRat
Reged: 06/18/06
Re: Mars 3 Nov 2009 @ 10:58UT new [Re: Freddy WILLEMS]
      #3430328 - 11/05/09 01:19 AM
Thanks Freddy! Yes, I used a TV 2.5x Powermate.
Glenn
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
      #3431065 - 11/05/09 01:07 PM
Very very nice Glenn. Perhaps I should say I can see Huygens and make a lot of people mad. But great detail and colors. Looks like seeing will have me shut down for at least 5 days or a week.
Edited by Lunatiki (11/05/09 01:09 PM)
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: Mars 3 Nov 2009 @ 10:58UT new [Re: Lunatiki]
      #3431120 - 11/05/09 01:30 PM
Huygens is there all right, if you look carefully.
- Rick
14" LX200GPS
Dyslexics Untie!
RedIrocZ-28
Reged: 09/18/05
Loc: Grand Rapids, Michigan
      #3431168 - 11/05/09 01:53 PM
Wow you guys are getting such good images I'm getting jealous!
Am I correct in remembering that Mars will reach 14.1" this January? I can't wait to capture it then, and I can't wait to see your images Glenn!
Maybe I'll setup and turn in early tonight, see if I can get something like what you have captured
sfugardi
Reged: 09/30/06
Loc: CT
Re: Mars 3 Nov 2009 @ 10:58UT new [Re: RedIrocZ-28]
      #3431458 - 11/05/09 04:24 PM
Glenn, awesome image size! I usually go 90sec per channel, but can you go 2min or more and align to the surface features? That would give a ton more frames to work with
Steve
1986 Compustar C11
Toucam, DMK21 + IFW Wheel
ST-4/C90, Nikon D70s
DesertRat
Reged: 06/18/06
Re: Mars 3 Nov 2009 @ 10:58UT new [Re: sfugardi]
      #3431720 - 11/05/09 06:45 PM
Thanks guys!
Steve - with Mars this small maybe 6 minutes total is possible if you align on the CM. I'd have to calculate that. But 1 minute per channel is not enough in less than optimal seeing, I only kept about 20% of the frames, and even in those there were some fuzzed out blobs.
Glenn
astrovienna
Reged: 12/04/06
Loc: Vienna, VA
      #3432050 - 11/05/09 10:19 PM
I think Damian Peach said in this month's S&T that for Mars he shoots 2 mins each R and G and 3 mins B. That surprised me, but if it works for him I'm sure I can live with it!
Kevin
The Hole in the Trees Skybox
CPC1100 on a Milburn wedge
C8 Phoenix (1985 Super C8+ remounted on a Nexstar GPS fork)
Meade DSI II Pro
DMK 21AU04.AS
KyleEdwards
Reged: 09/04/07
Re: Mars 3 Nov 2009 @ 10:58UT [Re: astrovienna]
      #3432374 - 11/06/09 06:25 AM
Great result despite the seeing. Looks like a cloud bank or frontal line or something starting to come down from the NPC.
Kyle Edwards
Solar System Imaging Simulator
My Astrophotography Gallery
6 registered and 8 anonymous users are browsing this forum.
