Privacy Policy |
Please read our Terms
of Service | Signup and
KerryR
Reged: 12/05/07
Loc: SW Michigan
Hi all,
Most of us are aware that the spherical correction characteristics of air-spaced achromats (and probably ED's as well) can be altered by changing the distance between them. I've played around with this a lot on my C6-R and, more recently on my Astro Telescopes 102 achro.
My process is currently to use a yellow and/or green filter, star-test, alter the spacing, test again, repeat 'till the green/yellow star-test looks the best. Seems to work for the color it's tested under, but I can't be sure what impact it has on other colors, and how it affects contrast. I have noticed that as I improve the star test in green light the purple gets worse.
One possibility I'm toying with would be to make a Bahtinov mask, place a color filter on the eyepiece, focus on a star using the mask (in order to hopefully attain exact focus), change the color filter, re-focus and measure the difference in focal distance for red, blue, yellow, and green. Then, adjust the spacing significantly, re-test, and compare results. Hopefully this would help me understand what's going on, and help me make the best spacing choice.
I'm not really sure what color crossing I need at closest focus-- I assume that'd be yellow and green...
Anyone have some suggestions? Should this be posted in the ATM/DIY forum instead?
-------------------- Kerry
drshr
Reged: 06/09/08
Loc: Darwin, Australia
Spherochromatism. Not possible to correct for everything. If the spacing increases spherical correction is reduced but the colour crossings may increase separation.
-------------------- Doc
14" F5 DOB.
APM 8" F6 Achro.
APM 105mm F6.2 CF APO.
120/F8.3
150/F5
80/F6.25ED
25x100 Binos.
To affect the quality of the day, that is the highest of arts.
19 registered and 14 anonymous users are browsing this forum.
Moderator: desertstars, Remy Bosio, Jason B, LLEEGE
