KerryR
Reged: 12/05/07
Loc: SW Michigan
Understanding air-spaced achro objective spacing? new
      #3433238 - 11/06/09 04:16 PM
Hi all,
Most of us are aware that the spherical correction characteristics of air-spaced achromats (and probably ED's as well) can be altered by changing the distance between them. I've played around with this a lot on my C6-R and, more recently on my Astro Telescopes 102 achro.
My process is currently to use a yellow and/or green filter, star-test, alter the spacing, test again, repeat 'till the green/yellow star-test looks the best. Seems to work for the color it's tested under, but I can't be sure what impact it has on other colors, and how it affects contrast. I have noticed that as I improve the star test in green light the purple gets worse.
One possibility I'm toying with would be to make a Bahtinov mask, place a color filter on the eyepiece, focus on a star using the mask (in order to hopefully attain exact focus), change the color filter, re-focus and measure the difference in focal distance for red, blue, yellow, and green. Then, adjust the spacing significantly, re-test, and compare results. Hopefully this would help me understand what's going on, and help me make the best spacing choice.
I'm not really sure what color crossing I need at closest focus-- I assume that'd be yellow and green...
Anyone have some suggestions? Should this be posted in the ATM/DIY forum instead?
Kerry
drshr
Reged: 06/09/08
Loc: Darwin, Australia
Re: Understanding air-spaced achro objective spacing? [Re: KerryR]
      #3433344 - 11/06/09 05:17 PM
Spherochromatism. Not possible to correct for everything. If the spacing increases spherical correction is reduced but the colour crossings may increase separation.
Doc
14" F5 DOB.
APM 8" F6 Achro.
APM 105mm F6.2 CF APO.
120/F8.3
150/F5
80/F6.25ED
25x100 Binos.
To affect the quality of the day, that is the highest of arts.
28 registered and 27 anonymous users are browsing this forum.
Moderator:  desertstars, Remy Bosio, Jason B, LLEEGE
