argonav
Reged: 10/21/06
Loc: Flagstaff, AZ
Visual Spectroscope new
      #3431138 - 11/05/09 01:38 PM
I have seen two brands of Star Spectroscope eyepiece attachments for sale. Rainbo Optics and Star Analyser.
I would like to know if one gives better performance than the other for visual observing only.
thanks,
David
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: Visual Spectroscope new [Re: argonav]
      #3431574 - 11/05/09 05:24 PM
I've wondered about these too. I guess not too many people have tried them.
- Rick
14" LX200GPS
83% of all statistics are meaningless.
nytecam
Reged: 08/20/05
Loc: London UK
      #3431585 - 11/05/09 05:29 PM
I would like to know if one gives better performance than the other for visual observing only.thanks,David
Suggest you post on Variable Star forum where you'll probably get some answers. I've used the Rainbow grating almost continuously for a decade with great success taking hundreds of spectra via my CCD cameras but only a few times visually due to the poor sensitivity of the eye in this field
Nytecam 51N 0.1W
Meade 30cm LX200+ETX-70+e-finder+C8+Ha+CaK PSTs SBIG SGS+homebuilt spectrographs
Starlight SXVF_M9+Lodestar CCDs/Canon 300D DSLR/Fuji E550
My observatory build-ETX-70 imaging-my videos
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Re: Visual Spectroscope new [Re: nytecam]
      #3433645 - 11/06/09 07:58 PM
For visual observation, you would get higher efficiency by using a prism-based spectroscope because ALL the light goes into the dispersed image. A grating, even if blazed, loses some light in the zeroth (direct) and other order images. Those employing a train of five (?) prisms cemented together work well. I've recently seen one or two models like this at Surplus Shed, although they are made for 'bench' work and would require modification. The slit mechanism must be removed and a cylindrical lens should be placed at the back end of the spectroscope so as to spread out the thin spectrum into a band havin some width.
Of course, you might be able to find a such a unit already configured for visual work at the telescope. Back in '83-'84 I purchased just such a one from Edmund, but it did cost me something like $400 (!!) back then. They'd be much less expensive today, though!
Finally, do note that *at least* an 8" scope is required so as to see spectra of anything but the brightest handful of stars.
Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
Jack Russell
Reged: 03/19/07
Loc: Sacramento, CA
Re: Visual Spectroscope [Re: nytecam]
      #3433670 - 11/06/09 08:06 PM
David,
I have used the Rainbow optics transmission grating visually a few times but my old eyes are not sensitive enough. I am planning to try my Cannon DSLR with it. Rigel Systems also offers a transmission grating http://www.rigelsys.com/
Jack
Intes Micro M809
Intes MK66
Orion 80ED
LXD75 and Orion Atlas EQ-G
Asortment of UO Konigs and orthos and
a couple of Panoptics
15 registered and 15 anonymous users are browsing this forum.
Moderator:  spaceydee, csa/montana
